Constants and Structures Associated with the QoS RES library in RTEMS. More...
struct | qres_params_t |
Server parameters. More... | |
Typedefs | |
typedef int | qos_rv |
Return values. More... | |
typedef Scheduler_CBS_Server_id | qres_sid_t |
Server id. More... | |
typedef rtems_id | tid_t |
Task id. More... | |
typedef time_t | qres_time_t |
Time value. More... | |
typedef time_t | qres_atime_t |
Absolute time value. | |
This include file contains all the constants and structures associated with the QoS RES library in RTEMS.
typedef int qos_rv |
Return values.
typedef Scheduler_CBS_Server_id qres_sid_t |
Server id.
typedef time_t qres_time_t |
Time value.
RTEMS_INLINE_ROUTINE qos_rv qres_attach_thread | ( | qres_sid_t | server_id, |
pid_t | pid, | ||
tid_t | task_id | ||
qres attach thread
Attach a task to an already existing server.
RTEMS_INLINE_ROUTINE qos_rv qres_cleanup | ( | void | ) |
qres cleanup
Cleanup resources associated to the QoS RES Library.
References _Scheduler_CBS_Cleanup().
RTEMS_INLINE_ROUTINE qos_rv qres_create_server | ( | qres_params_t * | params, |
qres_sid_t * | server_id | ||
qres create server
Create a new server with specified parameters.
RTEMS_INLINE_ROUTINE qos_rv qres_destroy_server | ( | qres_sid_t | server_id | ) |
qres destroy server
Detach all tasks from a server and destroy it.
RTEMS_INLINE_ROUTINE qos_rv qres_detach_thread | ( | qres_sid_t | server_id, |
pid_t | pid, | ||
qres detach thread
Detach from the QoS Server.
RTEMS_INLINE_ROUTINE qos_rv qres_get_appr_budget | ( | qres_sid_t | server_id, |
qres_time_t * | appr_budget | ||
qres get approved budget
Retrieve the budget that has been approved for the subsequent server instances.
RTEMS_INLINE_ROUTINE qos_rv qres_get_curr_budget | ( | qres_sid_t | server_id, |
qres_time_t * | current_budget | ||
qres get current budget
Retrieve remaining budget for the current server instance.
RTEMS_INLINE_ROUTINE qos_rv qres_get_exec_time | ( | qres_sid_t | server_id, |
qres_time_t * | exec_time, | ||
qres_atime_t * | abs_time | ||
qres get execution time
Retrieve time info relative to the current server.
RTEMS_INLINE_ROUTINE qos_rv qres_get_params | ( | qres_sid_t | server_id, |
qres_params_t * | params | ||
qres get params
Retrieve QoS scheduling parameters.
RTEMS_INLINE_ROUTINE qos_rv qres_get_sid | ( | pid_t | pid, |
tid_t | task_id, | ||
qres get server id
Get a thread server id, or QOS_E_NOT_FOUND if it is not attached to any server.
RTEMS_INLINE_ROUTINE qos_rv qres_init | ( | void | ) |
qres init
Initializes the QoS RES library.
References _Scheduler_CBS_Initialize().
RTEMS_INLINE_ROUTINE qos_rv qres_set_params | ( | qres_sid_t | server_id, |
qres set params
Change QoS scheduling parameters.
