19 #ifndef _RTEMS_POSIX_PTHREADIMPL_H 20 #define _RTEMS_POSIX_PTHREADIMPL_H 41 #define PTHREAD_MINIMUM_STACK_SIZE (_Stack_Minimum() * 2) 83 pthread_attr_t *dst_attr,
84 const pthread_attr_t *src_attr
154 struct sched_param *param,
162 int rtems_pthread_attribute_compare(
163 const pthread_attr_t *attr1,
164 const pthread_attr_t *attr2
182 pthread_attr_t *dst_attr,
183 const pthread_attr_t *src_attr
186 *dst_attr = *src_attr;
187 #if defined(RTEMS_SMP) && defined(__RTEMS_HAVE_SYS_CPUSET_H__) 189 dst_attr->affinitysetsize ==
sizeof(dst_attr->affinitysetpreallocated)
191 dst_attr->affinityset = &dst_attr->affinitysetpreallocated;
216 &_POSIX_Threads_Default_attributes
void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectfree.c:25
Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectallocate.c:39
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free(Thread_Control *the_pthread)
Free POSIX control block.
Definition: pthreadimpl.h:199
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Initialize_attributes(pthread_attr_t *attr)
POSIX threads initialize user threads body.
Definition: pthreadimpl.h:210
POSIX Threads Private Support.
POSIX Thread API Support.
pthread_attr_t _POSIX_Threads_Default_attributes
This variable contains the default POSIX Thread attributes.
Definition: pthread.c:53
void _POSIX_Threads_Sporadic_budget_TSR(Objects_Id id, void *argument)
This routine supports the sporadic scheduling algorithm.
Definition: pthread.c:106
User Defined Configuration Parameters Specific For The POSIX API.
void(* Thread_CPU_budget_algorithm_callout)(Thread_Control *)
This defines thes the entry point for the thread specific timeslice budget management algorithm...
Definition: thread.h:173
Objects_Control Object
This field is the object management structure for each thread.
Definition: thread.h:673
This structure defines the Thread Control Block (TCB).
Definition: thread.h:671
void(* _POSIX_Threads_Initialize_user_threads_p)(void)
When the user configures a set of POSIX API initialization threads, This variable will point to the m...
void _POSIX_Threads_Manager_initialization(void)
POSIX threads manager initialization.
Definition: pthread.c:356
void _POSIX_Threads_Sporadic_budget_callout(Thread_Control *the_thread)
POSIX threads sporadic budget callout.
Definition: pthread.c:160
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG.
Definition: assert.h:83
void _Thread_Kill_zombies(void)
Kills all zombie threads in the system.
Definition: threadrestart.c:149
int _POSIX_Thread_Translate_sched_param(int policy, struct sched_param *param, Thread_CPU_budget_algorithms *budget_algorithm, Thread_CPU_budget_algorithm_callout *budget_callout)
Translate sched_param into SuperCore terms.
Definition: psxtransschedparam.c:29
POSIX_EXTERN Objects_Information _POSIX_Threads_Information
The following defines the information control block used to manage this class of objects.
Definition: pthreadimpl.h:47
RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock(void)
Locks the object allocator mutex.
Definition: objectimpl.h:1007
Inlined Routines from the Thread Handler.
Inlined Routines in the Object Handler.
uint32_t Objects_Id
The following type defines the control block used to manage object IDs.
Definition: score/include/rtems/score/object.h:122
#define POSIX_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:123
The following lists the algorithms used to manage the thread cpu budget.
Definition: thread.h:159
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes(pthread_attr_t *dst_attr, const pthread_attr_t *src_attr)
Copy POSIX Thread attribute structure.
Definition: pthreadimpl.h:181
