19 #ifndef _RTEMS_POSIX_TIMERIMPL_H 20 #define _RTEMS_POSIX_TIMERIMPL_H 30 #define POSIX_TIMER_STATE_FREE 0x01 33 #define POSIX_TIMER_STATE_CREATE_NEW 0x02 36 #define POSIX_TIMER_STATE_CREATE_RUN 0x03 39 #define POSIX_TIMER_STATE_CREATE_STOP 0x04 42 #define POSIX_TIMER_RELATIVE 0 49 #if (POSIX_TIMER_RELATIVE == TIMER_ABSTIME) 50 #error "POSIX_TIMER_RELATIVE == TIMER_ABSTIME" 105 _Objects_Free( &_POSIX_Timer_Information, &the_timer->Object );
void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectfree.c:25
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Get(timer_t id, Objects_Locations *location)
POSIX Timer Get.
Definition: posix/include/rtems/posix/timerimpl.h:117
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:101
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
RTEMS_INLINE_ROUTINE POSIX_Timer_Control * _POSIX_Timer_Allocate(void)
POSIX Timer Allocate.
Definition: posix/include/rtems/posix/timerimpl.h:90
POSIX_EXTERN Objects_Information _POSIX_Timer_Information
The following defines the information control block used to manage this class of objects.
Definition: posix/include/rtems/posix/timerimpl.h:82
The control block used to manage each watchdog timer.
Definition: watchdog.h:98
bool _POSIX_Timer_Insert_helper(Watchdog_Control *timer, Watchdog_Interval ticks, Objects_Id id, Watchdog_Service_routine_entry TSR, void *arg)
POSIX Timer Watchdog Insertion Helper.
Definition: timerinserthelper.c:32
POSIX Timers Internal Support.
Objects_Control * _Objects_Get(Objects_Information *information, Objects_Id id, Objects_Locations *location)
Maps object ids to object control blocks.
Definition: objectget.c:23
RTEMS_INLINE_ROUTINE void _POSIX_Timer_Free(POSIX_Timer_Control *the_timer)
POSIX Timer Free.
Definition: posix/include/rtems/posix/timerimpl.h:101
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdog.h:47
Objects_Locations
This enumerated type lists the locations which may be returned by _Objects_Get.
Definition: objectimpl.h:117
Watchdog_Service_routine(* Watchdog_Service_routine_entry)(Objects_Id, void *)
Pointer to a watchdog service routine.
Definition: watchdog.h:61
Inlined Routines in the Object Handler.
void _POSIX_Timer_TSR(Objects_Id timer, void *data)
POSIX Timer Manager Timer Service Routine Helper.
Definition: timertsr.c:35
Definition: posix/include/rtems/posix/timer.h:41
uint32_t Objects_Id
The following type defines the control block used to manage object IDs.
Definition: score/include/rtems/score/object.h:122
void _POSIX_Timer_Manager_initialization(void)
POSIX Timer Manager Initialization.
Definition: ptimer.c:57
#define POSIX_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:123
