mutexget.c File Reference
Convert POSIX Mutex ID to local object pointer. More...
#include <rtems/score/apimutex.h>
Include dependency graph for mutexget.c:
POSIX_Mutex_Control_POSIX_Mutex_Get (pthread_mutex_t *mutex, Objects_Locations *location)
 POSIX Mutex Get (Thread Dispatch Disable) More...
POSIX_Mutex_Control_POSIX_Mutex_Get_interrupt_disable (pthread_mutex_t *mutex, Objects_Locations *location, ISR_lock_Context *lock_context)
 POSIX Mutex Get (Interrupt Disable) More...
◆ _POSIX_Mutex_Get()
POSIX_Mutex_Control* _POSIX_Mutex_Get ( pthread_mutex_t *  mutex,
Objects_Locations location
A support routine which translates the mutex id into a local pointer. As a side-effect, it may create the mutex.
Note
This version of the method uses a dispatching critical section.
Referenced by _POSIX_Mutex_Translate_core_mutex_return_code(), and pthread_mutex_init().
◆ _POSIX_Mutex_Get_interrupt_disable()
POSIX_Mutex_Control* _POSIX_Mutex_Get_interrupt_disable ( pthread_mutex_t *  mutex,
Objects_Locations location,
ISR_lock_Context lock_context
Note
: This version of the method uses an interrupt critical section.
Referenced by _POSIX_Mutex_Translate_core_mutex_return_code().
