msdos.h
1
9 /*
10  * Copyright (C) 2001 OKTET Ltd., St.-Petersburg, Russia
11  * Author: Eugeny S. Mints <Eugeny.Mints@oktet.ru>
12  *
13  * Modifications to support UTF-8 in the file system are
14  * Copyright (c) 2013 embedded brains GmbH.
15  *
16  * The license and distribution terms for this file may be
17  * found in the file LICENSE in this distribution or at
18  * http://www.rtems.org/license/LICENSE.
19  */
20
21 #ifndef __DOSFS_MSDOS_H__
22 #define __DOSFS_MSDOS_H__
23
24 #include <rtems.h>
25 #include <rtems/libio_.h>
26 #include <rtems/dosfs.h>
27
28 #include "fat.h"
29 #include "fat_file.h"
30
37 #ifdef __cplusplus
38 extern "C" {
39 #endif
40
41 #define MSDOS_NAME_NOT_FOUND_ERR 0x7D01
42
43 /*
44  * This structure identifies the instance of the filesystem on the MSDOS
45  * level.
46  */
47 typedef struct msdos_fs_info_s
48 {
49  fat_fs_info_t fat; /*
50  * volume
51  * description
52  */
53  const rtems_filesystem_file_handlers_r *directory_handlers; /*
54  * a set of routines
55  * that handles the
56  * nodes of directory
57  * type
58  */
59  const rtems_filesystem_file_handlers_r *file_handlers; /*
60  * a set of routines
61  * that handles the
62  * nodes of file
63  * type
64  */
65  rtems_id vol_sema; /*
66  * semaphore
67  * associated with
68  * the volume
69  */
70  uint8_t *cl_buf; /*
71  * just placeholder
72  * for anything
73  */
74
75  rtems_dosfs_convert_control *converter;
77
78 /* a set of routines that handle the nodes which are directories */
79 extern const rtems_filesystem_file_handlers_r msdos_dir_handlers;
80
81 /* a set of routines that handle the nodes which are files */
82 extern const rtems_filesystem_file_handlers_r msdos_file_handlers;
83
84 /* Volume semaphore timeout value. This value can be changed to a number
85  * of ticks to help debugging or if you need such a */
86 #define MSDOS_VOLUME_SEMAPHORE_TIMEOUT RTEMS_NO_TIMEOUT
87
88 /*
89  * Macros for fetching fields from 32 bytes long FAT Directory Entry
90  * Structure
91  */
92 #define MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE 32 /* 32 bytes */
93
94 #define MSDOS_DIR_NAME(x) (char *)((x) + 0)
95 #define MSDOS_DIR_ENTRY_TYPE(x) (uint8_t *)((x) + 0)
96 #define MSDOS_DIR_ATTR(x) (uint8_t *)((x) + 11)
97 #define MSDOS_DIR_NT_RES(x) (uint8_t *)((x) + 12)
98 #define MSDOS_DIR_LFN_CHECKSUM(x) (uint8_t *)((x) + 13)
99 #define MSDOS_DIR_CRT_TIME_TENTH(x) (uint8_t *)((x) + 13)
100 #define MSDOS_DIR_CRT_TIME(x) (uint16_t *)((x) + 14)
101 #define MSDOS_DIR_CRT_DATE(x) (uint16_t *)((x) + 16)
102 #define MSDOS_DIR_LAST_ACCESS_DATE(x) (uint16_t *)((x) + 18)
103 #define MSDOS_DIR_FIRST_CLUSTER_HI(x) (uint16_t *)((x) + 20)
104 #define MSDOS_DIR_WRITE_TIME(x) (uint16_t *)((x) + 22)
105 #define MSDOS_DIR_WRITE_DATE(x) (uint16_t *)((x) + 24)
106 #define MSDOS_DIR_FIRST_CLUSTER_LOW(x) (uint16_t *)((x) + 26)
107 #define MSDOS_DIR_FILE_SIZE(x) (uint32_t *)((x) + 28)
108
109 #define MSDOS_EXTRACT_CLUSTER_NUM(p) \
110  (uint32_t)( (CF_LE_W(*MSDOS_DIR_FIRST_CLUSTER_LOW(p))) | \
111  ((uint32_t)(CF_LE_W((*MSDOS_DIR_FIRST_CLUSTER_HI(p))))<<16) )
112
113 /*
114  * Fields offset in 32 bytes long FAT Directory Entry
115  * Structure
116  */
117 #define MSDOS_FILE_SIZE_OFFSET 28
118 #define MSDOS_FILE_NAME_OFFSET 0
119 #define MSDOS_FIRST_CLUSTER_HI_OFFSET 20
120 #define MSDOS_FIRST_CLUSTER_LOW_OFFSET 26
121 #define MSDOS_FILE_WDATE_OFFSET 24
122 #define MSDOS_FILE_WTIME_OFFSET 22
123 #define MSDOS_FILE_ADATE_OFFSET 18
124 #define MSDOS_FILE_CDATE_OFFSET 16
125 #define MSDOS_FILE_CTIME_OFFSET 14
126
127 /*
128  * Possible values of DIR_Attr field of 32 bytes long FAT Directory Entry
129  * Structure
130  */
131 #define MSDOS_ATTR_READ_ONLY 0x01
132 #define MSDOS_ATTR_HIDDEN 0x02
133 #define MSDOS_ATTR_SYSTEM 0x04
134 #define MSDOS_ATTR_VOLUME_ID 0x08
135 #define MSDOS_ATTR_DIRECTORY 0x10
136 #define MSDOS_ATTR_ARCHIVE 0x20
137 #define MSDOS_ATTR_LFN (MSDOS_ATTR_READ_ONLY | \
138  MSDOS_ATTR_HIDDEN | \
139  MSDOS_ATTR_SYSTEM | \
140  MSDOS_ATTR_VOLUME_ID)
141 #define MSDOS_ATTR_LFN_MASK (MSDOS_ATTR_READ_ONLY | \
142  MSDOS_ATTR_HIDDEN | \
143  MSDOS_ATTR_SYSTEM | \
144  MSDOS_ATTR_VOLUME_ID | \
145  MSDOS_ATTR_DIRECTORY | \
146  MSDOS_ATTR_ARCHIVE)
147
148 #define MSDOS_LAST_LONG_ENTRY 0x40
149 #define MSDOS_LAST_LONG_ENTRY_MASK 0x3F
150
151 #define MSDOS_DT_2SECONDS_MASK 0x1F /* seconds divided by 2 */
152 #define MSDOS_DT_2SECONDS_SHIFT 0
153 #define MSDOS_DT_MINUTES_MASK 0x7E0 /* minutes */
154 #define MSDOS_DT_MINUTES_SHIFT 5
155 #define MSDOS_DT_HOURS_MASK 0xF800 /* hours */
156 #define MSDOS_DT_HOURS_SHIFT 11
157
158 #define MSDOS_DD_DAY_MASK 0x1F /* day of month */
159 #define MSDOS_DD_DAY_SHIFT 0
160 #define MSDOS_DD_MONTH_MASK 0x1E0 /* month */
161 #define MSDOS_DD_MONTH_SHIFT 5
162 #define MSDOS_DD_YEAR_MASK 0xFE00 /* year - 1980 */
163 #define MSDOS_DD_YEAR_SHIFT 9
164
165
166 /*
167  * Possible values of DIR_Name[0] field of 32 bytes long FAT Directory Entry
168  * Structure
169  */
170 #define MSDOS_THIS_DIR_ENTRY_EMPTY 0xE5
171 #define MSDOS_THIS_DIR_ENTRY_AND_REST_EMPTY 0x00
172
173 /*
174  * Number of characters per directory entry for a long filename.
175  */
176 #define MSDOS_LFN_LEN_PER_ENTRY (13)
177
178 /*
179  * Macros for names parsing and formatting
180  */
181 #define MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR 4
182 #define MSDOS_NAME_MIN_UTF8_BYTES_PER_CHAR 1
183
184 #define MSDOS_SHORT_BASE_LEN 8 /* 8 characters */
185 #define MSDOS_SHORT_EXT_LEN 3 /* 3 characters */
186 #define MSDOS_SHORT_NAME_LEN (MSDOS_SHORT_BASE_LEN+\
187  MSDOS_SHORT_EXT_LEN) /* 11 chars */
188 #define MSDOS_NAME_MAX_LNF_LEN (255)
189 #define MSDOS_NAME_MAX MSDOS_SHORT_NAME_LEN
190 #define MSDOS_NAME_MAX_UTF8_SFN_BYTES (MSDOS_NAME_MAX *\
191  MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
192 #define MSDOS_NAME_MAX_WITH_DOT (MSDOS_NAME_MAX + 1)
193 #define MSDOS_SFN_MAX_WITH_DOT_UTF8_BYTES (MSDOS_NAME_MAX_WITH_DOT *\
194  MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
195 #define MSDOS_NAME_MAX_LFN_WITH_DOT (260)
196
197 #define MSDOS_NAME_LFN_BYTES_PER_CHAR (2)
198 #define MSDOS_NAME_MAX_LFN_BYTES (MSDOS_NAME_MAX_LFN_WITH_DOT *\
199  MSDOS_NAME_LFN_BYTES_PER_CHAR)
200 #define MSDOS_NAME_MAX_UTF8_LFN_BYTES (MSDOS_NAME_MAX_LFN_WITH_DOT *\
201  MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
202 #define MSDOS_ENTRY_LFN_UTF8_BYTES (MSDOS_LFN_LEN_PER_ENTRY *\
203  MSDOS_NAME_MAX_UTF8_BYTES_PER_CHAR)
204
205 extern const char *const MSDOS_DOT_NAME; /* ".", padded to MSDOS_NAME chars */
206 extern const char *const MSDOS_DOTDOT_NAME; /* ".", padded to MSDOS_NAME chars */
207
208 typedef enum msdos_name_types_e
209 {
210  MSDOS_NAME_INVALID = 0, /* Unknown name type. Has invalid characters. */
211  MSDOS_NAME_SHORT, /* Name can be short. */
212  MSDOS_NAME_LONG /* Name is long; cannot be short. */
213 } msdos_name_type_t;
214
215 typedef enum msdos_token_types_e
216 {
217  MSDOS_NO_MORE_PATH,
218  MSDOS_CURRENT_DIR,
219  MSDOS_UP_DIR,
220  MSDOS_NAME,
221  MSDOS_INVALID_TOKEN
222 } msdos_token_types_t;
223
224 /* Others macros */
225 #define MSDOS_RES_NT_VALUE 0x00
226 #define MSDOS_INIT_DIR_SIZE 0x00
227
228 /* "dot" entry offset in a directory */
229 #define MSDOS_DOT_DIR_ENTRY_OFFSET 0x00 /* first entry in directory */
230
231 /* "dotdot" entry offset in a directory */
232 #define MSDOS_DOTDOT_DIR_ENTRY_OFFSET 0x20 /* second entry in directory */
233
234 /* 'p' should be char* */
235 #define DOT_NODE_P(p) ((char *)(p))
236 #define DOTDOT_NODE_P(p) ((char *)((p) + MSDOS_DIRECTORY_ENTRY_STRUCT_SIZE))
237
238 /* Size limits for files and directories */
239 #define MSDOS_MAX_DIR_LENGHT 0x200000 /* 2,097,152 bytes */
240 #define MSDOS_MAX_FILE_SIZE 0xFFFFFFFF /* 4 Gb */
241
242 /*
243  * The number of 32 bytes long FAT Directory Entry
244  * Structures per 512 bytes sector
245  */
246 #define MSDOS_DPS512_NUM 16
247
254
255 void msdos_eval_path(rtems_filesystem_eval_path_context_t *ctx);
256
263
269 int msdos_mknod(
271  const char *name,
272  size_t namelen,
273  mode_t mode,
274  dev_t dev
275 );
276
282 int msdos_rmnod(
283  const rtems_filesystem_location_info_t *parentloc,
285 );
286
292 int msdos_rename(
293  const rtems_filesystem_location_info_t *old_parent_loc,
294  const rtems_filesystem_location_info_t *old_loc,
295  const rtems_filesystem_location_info_t *new_parent_loc,
296  const char *new_name,
297  size_t new_namelen
298 );
299
300 int msdos_statvfs(
301  const rtems_filesystem_location_info_t *root_loc,
302  struct statvfs *sb);
303
304 void msdos_lock(const rtems_filesystem_mount_table_entry_t *mt_entry);
305
306 void msdos_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry);
307
315  const rtems_filesystem_operations_table *op_table,
316  const rtems_filesystem_file_handlers_r *file_handlers,
317  const rtems_filesystem_file_handlers_r *directory_handlers,
318  rtems_dosfs_convert_control *converter
319 );
320
321 ssize_t msdos_file_read(
322  rtems_libio_t *iop, /* IN */
323  void *buffer, /* IN */
324  size_t count /* IN */
325 );
326
327 ssize_t msdos_file_write(
328  rtems_libio_t *iop, /* IN */
329  const void *buffer, /* IN */
330  size_t count /* IN */
331 );
332
333 int msdos_file_stat(
335  struct stat *buf
336 );
337
338 int
339 msdos_file_ftruncate(
340  rtems_libio_t *iop, /* IN */
341  off_t length /* IN */
342 );
343
344 int msdos_file_sync(rtems_libio_t *iop);
345
346 ssize_t msdos_dir_read(
347  rtems_libio_t *iop, /* IN */
348  void *buffer, /* IN */
349  size_t count /* IN */
350 );
351
352 int msdos_dir_sync(rtems_libio_t *iop);
353
354 int msdos_dir_stat(
356  struct stat *buf
357 );
358
366  fat_file_type_t type,
367  const char *name,
368  int name_len,
369  mode_t mode,
370  const fat_file_fd_t *link_fd);
371
372 /* Misc prototypes */
373
374 int msdos_find_name(
376  const char *name,
377  int name_len
378 );
379
380 int msdos_get_name_node(
381  const rtems_filesystem_location_info_t *parent_loc,
382  bool create_node,
383  const char *name,
384  int name_len,
385  msdos_name_type_t name_type,
386  fat_dir_pos_t *dir_pos,
387  char *name_dir_entry
388 );
389
390 int msdos_dir_info_remove(rtems_filesystem_location_info_t *pathloc);
391
392 ssize_t
393 msdos_format_dirent_with_dot(char *dst,const char *src);
394
395 msdos_name_type_t msdos_long_to_short(rtems_dosfs_convert_control *converter,
396  const char *lfn, int lfn_len,
397  char* sfn, int sfn_len);
398
399 ssize_t
400 msdos_filename_utf8_to_short_name_for_compare (
401  rtems_dosfs_convert_control *converter,
402  const uint8_t *utf8_name,
403  const size_t utf8_name_size,
404  void *short_name,
405  const size_t short_name_size);
406
407 ssize_t
408 msdos_filename_utf8_to_short_name_for_save (
409  rtems_dosfs_convert_control *converter,
410  const uint8_t *utf8_name,
411  const size_t utf8_name_size,
412  void *short_name,
413  const size_t short_name_size);
414
415 ssize_t
416 msdos_filename_utf8_to_long_name_for_compare (
417  rtems_dosfs_convert_control *converter,
418  const uint8_t *utf8_name,
419  const size_t utf8_name_size,
420  uint8_t *long_name,
421  const size_t long_name_size);
422
423 ssize_t
424 msdos_filename_utf8_to_long_name_for_save (
425  rtems_dosfs_convert_control *converter,
426  const uint8_t *utf8_name,
427  const size_t utf8_name_size,
428  uint16_t *long_name,
429  const size_t long_name_size);
430
431 ssize_t
432 msdos_get_utf16_string_from_long_entry (
433  const char *entry,
434  uint16_t *entry_string_buf,
435  const size_t buf_size,
436  bool is_first_entry
437 );
438
439 void msdos_date_unix2dos(
440  unsigned int tsp, uint16_t *ddp,
441  uint16_t *dtp);
442
443 unsigned int msdos_date_dos2unix(unsigned int dd, unsigned int dt);
444
445 int msdos_set_first_char4file_name(
447  fat_dir_pos_t *dir_pos,
448  unsigned char first_char
449 );
450
451 int msdos_dir_is_empty(
453  fat_file_fd_t *fat_fd,
454  bool *ret_val
455 );
456
457 int msdos_find_name_in_fat_file(
459  fat_file_fd_t *fat_fd,
460  bool create_node,
461  const uint8_t *name_utf8,
462  int name_len,
463  msdos_name_type_t name_type,
464  fat_dir_pos_t *dir_pos,
465  char *name_dir_entry
466 );
467
468 int msdos_find_node_by_cluster_num_in_fat_file(
470  fat_file_fd_t *fat_fd,
471  uint32_t cl4find,
472  fat_dir_pos_t *dir_pos,
473  char *dir_entry
474 );
475
476 int msdos_get_dotdot_dir_info_cluster_num_and_offset(
478  uint32_t cln,
479  fat_dir_pos_t *dir_pos,
480  char *dir_entry
481 );
482
483 int msdos_sync(rtems_libio_t *iop);
484
485 uint8_t msdos_lfn_checksum(const void *entry);
486
487 #ifdef __cplusplus
488 }
489 #endif
490
491 #endif /* __DOSFS_MSDOS_H__ */
Definition: msdos.h:47
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: rtems/include/rtems/rtems/types.h:80
Definition: fat.h:387
int msdos_mknod(const rtems_filesystem_location_info_t *loc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Routine for node creation in a MSDOS filesystem.
Definition: msdos_mknod.c:37
Constants/Data Structures/Prototypes for Operations on "fat-file".
int msdos_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Remove node from MSDOS directory.
Definition: msdos_rmnod.c:24
void msdos_free_node_info(const rtems_filesystem_location_info_t *pathloc)
Call the Fat-File close routine.
Definition: msdos_free.c:36
FAT filesystem convert control.
Definition: dosfs.h:182
File system node operations table.
Definition: libio.h:982
Definition: fat.h:358
int msdos_initialize_support(rtems_filesystem_mount_table_entry_t *temp_mt_entry, const rtems_filesystem_operations_table *op_table, const rtems_filesystem_file_handlers_r *file_handlers, const rtems_filesystem_file_handlers_r *directory_handlers, rtems_dosfs_convert_control *converter)
MSDOS filesystem initialization routine.
Definition: msdos_initsupp.c:51
void msdos_shut_down(rtems_filesystem_mount_table_entry_t *temp_mt_entry)
Shut down the MSDOS filesystem.
Definition: msdos_fsunmount.c:46
Descriptor of a fat-file.
Definition: fat_file.h:73
int msdos_creat_node(const rtems_filesystem_location_info_t *parent_loc, fat_file_type_t type, const char *name, int name_len, mode_t mode, const fat_file_fd_t *link_fd)
Implements wake up version of the "signal" operation.
Definition: msdos_create.c:61
Mount table entry.
Definition: libio.h:1542
File system operations table.
Definition: libio.h:471
LibIO Internal Interface.
Path evaluation context.
Definition: libio.h:83
An open file data structure.
Definition: libio.h:1281
Definition: statvfs.h:35
Definition: nfs_prot.h:234
int msdos_rename(const rtems_filesystem_location_info_t *old_parent_loc, const rtems_filesystem_location_info_t *old_loc, const rtems_filesystem_location_info_t *new_parent_loc, const char *new_name, size_t new_namelen)
Rename a MSDOS filesystem node.
Definition: msdos_rename.c:38
Constants/Data Structures/Prototypes on a Volume with FAT Filesystem.
File system location.
Definition: include/rtems/fs.h:53
