LM32 CPU Dependent Source. More...
void | _CPU_Initialize (void) |
CPU initialization. More... | |
uint32_t | _CPU_ISR_Get_level (void) |
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
This routine installs an interrupt vector. More... | |
void | _CPU_Install_interrupt_stack (void) |
This routine installs the hardware interrupt stack pointer. More... | |
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
This routine is the CPU dependent IDLE thread body. More... | |
