#define | PPP_MTU 1500 /* Default MTU (size of Info field) */ |
#define | PPP_MAXMRU 65000 /* Largest MRU we allow */ |
#define | PPP_MAXMTU 16384 /* Largest MTU we allow */ |
#define | SC_COMP_PROT 0x00000001 /* protocol compression (output) */ |
#define | SC_COMP_AC 0x00000002 /* header compression (output) */ |
#define | SC_COMP_TCP 0x00000004 /* TCP (VJ) compression (output) */ |
#define | SC_NO_TCP_CCID 0x00000008 /* disable VJ connection-id comp. */ |
#define | SC_REJ_COMP_AC 0x00000010 /* reject adrs/ctrl comp. on input */ |
#define | SC_REJ_COMP_TCP 0x00000020 /* reject TCP (VJ) comp. on input */ |
#define | SC_CCP_OPEN 0x00000040 /* Look at CCP packets */ |
#define | SC_CCP_UP 0x00000080 /* May send/recv compressed packets */ |
#define | SC_DEBUG 0x00010000 /* enable debug messages */ |
#define | SC_LOG_INPKT 0x00020000 /* log contents of good pkts recvd */ |
#define | SC_LOG_OUTPKT 0x00040000 /* log contents of pkts sent */ |
#define | SC_LOG_RAWIN 0x00080000 /* log all chars received */ |
#define | SC_LOG_FLUSH 0x00100000 /* log all chars flushed */ |
#define | SC_RCV_B7_0 0x01000000 /* have rcvd char with bit 7 = 0 */ |
#define | SC_RCV_B7_1 0x02000000 /* have rcvd char with bit 7 = 1 */ |
#define | SC_RCV_EVNP 0x04000000 /* have rcvd char with even parity */ |
#define | SC_RCV_ODDP 0x08000000 /* have rcvd char with odd parity */ |
#define | SC_SYNC 0x00200000 /* use synchronous HDLC framing */ |
#define | SC_MASK 0x0fff00ff /* bits that user can change */ |
#define | SC_TIMEOUT 0x00000400 /* timeout is currently pending */ |
#define | SC_VJ_RESET 0x00000800 /* need to reset VJ decomp */ |
#define | SC_COMP_RUN 0x00001000 /* compressor has been initiated */ |
#define | SC_DECOMP_RUN 0x00002000 /* decompressor has been initiated */ |
#define | SC_DC_ERROR 0x00004000 /* non-fatal decomp error detected */ |
#define | SC_DC_FERROR 0x00008000 /* fatal decomp error detected */ |
#define | SC_TBUSY 0x10000000 /* xmitter doesn't need a packet yet */ |
#define | SC_PKTLOST 0x20000000 /* have lost or dropped a packet */ |
#define | SC_FLUSH 0x40000000 /* flush input until next PPP_FLAG */ |
#define | SC_ESCAPED 0x80000000 /* saw a PPP_ESCAPE */ |
#define | PPPIOCSTASK _IOW('t', 91, int) /* set pppd task id */ |
#define | PPPIOCGFLAGS _IOR('t', 90, int) /* get configuration flags */ |
#define | PPPIOCSFLAGS _IOW('t', 89, int) /* set configuration flags */ |
#define | PPPIOCGASYNCMAP _IOR('t', 88, int) /* get async map */ |
#define | PPPIOCSASYNCMAP _IOW('t', 87, int) /* set async map */ |
#define | PPPIOCGUNIT _IOR('t', 86, int) /* get ppp unit number */ |
#define | PPPIOCGRASYNCMAP _IOR('t', 85, int) /* get receive async map */ |
#define | PPPIOCSRASYNCMAP _IOW('t', 84, int) /* set receive async map */ |
#define | PPPIOCGMRU _IOR('t', 83, int) /* get max receive unit */ |
#define | PPPIOCSMRU _IOW('t', 82, int) /* set max receive unit */ |
#define | PPPIOCSMAXCID _IOW('t', 81, int) /* set VJ max slot ID */ |
#define | PPPIOCGXASYNCMAP _IOR('t', 80, ext_accm) /* get extended ACCM */ |
#define | PPPIOCSXASYNCMAP _IOW('t', 79, ext_accm) /* set extended ACCM */ |
#define | PPPIOCXFERUNIT _IO('t', 78) /* transfer PPP unit */ |
#define | PPPIOCSCOMPRESS _IOW('t', 77, struct ppp_option_data) |
#define | PPPIOCGNPMODE _IOWR('t', 76, struct npioctl) /* get NP mode */ |
#define | PPPIOCSNPMODE _IOW('t', 75, struct npioctl) /* set NP mode */ |
#define | PPPIOCGIDLE _IOR('t', 74, struct ppp_idle) /* get idle time */ |
#define | PPPIOCGMTU _IOR('t', 73, int) /* get interface MTU */ |
#define | PPPIOCSMTU _IOW('t', 72, int) /* set interface MTU */ |
#define | SIOCGPPPSTATS _IOWR('i', 123, struct ifpppstatsreq) |
#define | SIOCGPPPCSTATS _IOWR('i', 122, struct ifpppcstatsreq) |
#define | ifr_mtu ifr_ifru.ifru_metric |
