Files | Data Structures | Macros | Functions | Variables
Time of Day Handler
The following constants are related to the time of day and are independent of RTEMS. More...
Collaboration diagram for Time of Day Handler:
file  score/include/rtems/score/tod.h
 Time of Day Handler API.
file  todimpl.h
file  coretod.c
 Initializes the Time of Day Handler.
file  coretodadjust.c
 Adjust the Time of Time.
file  coretodset.c
 Set Time of Day Given a Timestamp.
file  coretodtickle.c
 Increments time of day at each clock tick.
file  coretodtickspersec.c
 Convert Ticks To Seconds.
struct  TOD_Control
 TOD control. More...
#define TOD_SECONDS_PER_MINUTE   (uint32_t)60
 This constant represents the number of seconds in a minute.
#define TOD_MINUTES_PER_HOUR   (uint32_t)60
 This constant represents the number of minutes per hour.
#define TOD_MONTHS_PER_YEAR   (uint32_t)12
 This constant represents the number of months in a year.
#define TOD_DAYS_PER_YEAR   (uint32_t)365
 This constant represents the number of days in a non-leap year.
#define TOD_HOURS_PER_DAY   (uint32_t)24
 This constant represents the number of hours per day.
#define TOD_SECONDS_PER_DAY
 This constant represents the number of seconds in a day which does not include a leap second. More...
#define TOD_SECONDS_PER_NON_LEAP_YEAR   (365 * TOD_SECONDS_PER_DAY)
 This constant represents the number of seconds in a non-leap year.
#define TOD_MILLISECONDS_PER_SECOND   (uint32_t)1000
 This constant represents the number of millisecond in a second.
#define TOD_MICROSECONDS_PER_SECOND   (uint32_t)1000000
 This constant represents the number of microseconds in a second.
#define TOD_NANOSECONDS_PER_SECOND   (uint32_t)1000000000
 This constant represents the number of nanoseconds in a second.
#define TOD_NANOSECONDS_PER_MICROSECOND   (uint32_t)1000
 This constant represents the number of nanoseconds in a mircosecond.
#define TOD_TICKS_PER_SECOND   TOD_TICKS_PER_SECOND_method()
 Gets number of ticks in a second. More...
void _TOD_Handler_initialization (void)
 Initializes the time of day handler. More...
void _TOD_Set_with_timestamp (const Timestamp_Control *tod_as_timestamp)
 Sets the time of day from timestamp. More...
void _TOD_Tickle_ticks (void)
 Increments time of day at each clock tick. More...
uint32_t TOD_TICKS_PER_SECOND_method (void)
RTEMS_INLINE_ROUTINE void _TOD_Get_timeval (struct timeval *time)
 This routine returns a timeval based upon the internal timespec format TOD.
void _TOD_Adjust (const Timestamp_Control timestamp)
 Adjust the Time of Time. More...
RTEMS_INLINE_ROUTINE bool _TOD_Is_set (void)
 Check if the TOD is Set. More...
SCORE_EXTERN TOD_Control _TOD
This handler encapsulates functionality used to manage time of day.
◆ TOD_SECONDS_PER_DAY
Value:
(uint32_t) (TOD_SECONDS_PER_MINUTE * \
Definition: todimpl.h:50
Definition: todimpl.h:45
Definition: todimpl.h:65
◆ TOD_TICKS_PER_SECOND
This method exists to hide the fact that TOD_TICKS_PER_SECOND can not be implemented as a macro in a .h file due to visibility issues. The Configuration Table is not available to SuperCore .h files but is available to their .c files.
Referenced by _Timespec_To_ticks().
◆ _TOD_Adjust()
void _TOD_Adjust ( const Timestamp_Control  timestamp)
This method is used to adjust the current time of day by the specified amount.
Parameters
[in]deltais the amount to adjust
References _Thread_Disable_dispatch().
Referenced by _TOD_Get_timeval(), and adjtime().
◆ _TOD_Handler_initialization()
void _TOD_Handler_initialization ( void  )
Performs the initialization necessary for the Time Of Day handler.
◆ _TOD_Is_set()
RTEMS_INLINE_ROUTINE bool _TOD_Is_set ( void  )
◆ _TOD_Set_with_timestamp()
void _TOD_Set_with_timestamp ( const Timestamp_Control tod_as_timestamp)
The tod_as_timestamp timestamp represents the time since UNIX epoch. The watchdog seconds chain will be adjusted.
Parameters
[in]tod_as_timestampis the constant of the time of day as a timestamp
References _Thread_Disable_dispatch(), and _Timestamp_To_timespec().
◆ _TOD_Tickle_ticks()
void _TOD_Tickle_ticks ( void  )
This routine increments the ticks field of the current time of day at each clock tick.
References _Watchdog_Ticks_since_boot.
Referenced by _Watchdog_Tick().
◆ TOD_TICKS_PER_SECOND_method()
uint32_t TOD_TICKS_PER_SECOND_method ( void  )
This method returns the number of ticks in a second.
Note
If the clock tick value does not multiply evenly into a second then this number of ticks will be slightly shorter than a second.
References TOD_MICROSECONDS_PER_SECOND.
