Modules | Files | Data Structures | Functions
API Mutex Handler
Provides routines to ensure mutual exclusion on API level. More...
Collaboration diagram for API Mutex Handler:
 RTEMS Allocator Mutex
 Protection for all memory allocations and deallocations in RTEMS.
file  apimutex.h
 API Mutex Handler API.
file  apimutex.c
 Initialization and Allocation for API Mutex Handler.
file  apimutexisowner.c
file  apimutexlock.c
 Acquires the specified API mutex.
file  apimutexunlock.c
 Releases the Specified API Mutex.
struct  API_Mutex_Control
 Control block used to manage each API mutex. More...
void _API_Mutex_Initialization (uint32_t maximum_mutexes)
 Initialization for the API Mutexe Handler. More...
void _API_Mutex_Allocate (API_Mutex_Control **mutex)
 Allocates an API mutex from the inactive set and returns it in mutex.
void _API_Mutex_Lock (API_Mutex_Control *mutex)
 Acquires the specified API mutex. More...
void _API_Mutex_Unlock (API_Mutex_Control *mutex)
 Releases the specified API mutex. More...
bool _API_Mutex_Is_owner (const API_Mutex_Control *mutex)
 Checks if the specified API mutex is owned by the executing thread. More...
◆ _API_Mutex_Initialization()
void _API_Mutex_Initialization ( uint32_t  maximum_mutexes)
The value maximum_mutexes is the maximum number of API mutexes that may exist at any time.
Parameters
[in]maximum_mutexesis the maximum number of API mutexes.
References _Objects_Initialize_information().
◆ _API_Mutex_Is_owner()
bool _API_Mutex_Is_owner ( const API_Mutex_Control mutex)
Parameters
[in]mutexThe API mutex.
References _Thread_Get_executing(), CORE_mutex_Control::holder, and API_Mutex_Control::Mutex.
◆ _API_Mutex_Lock()
void _API_Mutex_Lock ( API_Mutex_Control mutex)
Parameters
◆ _API_Mutex_Unlock()
void _API_Mutex_Unlock ( API_Mutex_Control mutex)
