Files | Data Structures | Macros | Functions
Collaboration diagram for I2C Bus Driver:
file  i2c-bus.c
 Inter-Integrated Circuit (I2C) Bus Implementation.
struct  i2c_bus
 I2C bus control. More...
#define I2C_BUS_CLOCK_DEFAULT   100000
 Default I2C bus clock in Hz.
int i2c_bus_init (i2c_bus *bus)
 Initializes a bus control. More...
i2c_busi2c_bus_alloc_and_init (size_t size)
 Allocates a bus control from the heap and initializes it. More...
void i2c_bus_destroy (i2c_bus *bus)
 Destroys a bus control. More...
void i2c_bus_destroy_and_free (i2c_bus *bus)
 Destroys a bus control and frees its memory. More...
int i2c_bus_register (i2c_bus *bus, const char *bus_path)
 Registers a bus control. More...
void i2c_bus_obtain (i2c_bus *bus)
 Obtains the bus. More...
void i2c_bus_release (i2c_bus *bus)
 Releases the bus. More...
int i2c_bus_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
 Transfers I2C messages. More...
I2C IO Control Commands
#define I2C_BUS_OBTAIN   0x800
#define I2C_BUS_RELEASE   0x801
#define I2C_BUS_GET_CONTROL   0x802
 Gets the bus control. More...
#define I2C_BUS_SET_CLOCK   0x803
 Sets the bus clock in Hz. More...
◆ I2C_BUS_GET_CONTROL
The argument type is a pointer to i2c_bus pointer.
◆ I2C_BUS_OBTAIN
Obtains the bus.
This command has no argument.
◆ I2C_BUS_RELEASE
Releases the bus.
◆ I2C_BUS_SET_CLOCK
The argument type is unsigned long.
◆ i2c_bus_alloc_and_init()
i2c_bus* i2c_bus_alloc_and_init ( size_t  size)
After a sucessful allocation and initialization the bus control must be destroyed via i2c_bus_destroy_and_free(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy_and_free() in a custom destruction handler.
Parameters
[in]sizeThe size of the bus control. This enables the addition of bus controller specific data to the base bus control. The bus control is zero initialized.
Return values
non-NULLThe new bus control.
NULLAn error occurred. The errno is set to indicate the error.
See also
i2c_bus_register()
◆ i2c_bus_destroy()
void i2c_bus_destroy ( i2c_bus bus)
Parameters
[in]busThe bus control.
References _Assert, i2c_bus::mutex, rtems_semaphore_delete(), and RTEMS_SUCCESSFUL.
Referenced by i2c_bus_destroy_and_free().
◆ i2c_bus_destroy_and_free()
void i2c_bus_destroy_and_free ( i2c_bus bus)
Parameters
References i2c_bus_destroy().
◆ i2c_bus_init()
int i2c_bus_init ( i2c_bus bus)
After a sucessful initialization the bus control must be destroyed via i2c_bus_destroy(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy() in a custom destruction handler.
Parameters
Return values
0Successful operation.
-1An error occurred. The errno is set to indicate the error.
See also
i2c_bus_register()
◆ i2c_bus_obtain()
void i2c_bus_obtain ( i2c_bus bus)
Obtains the bus.
Parameters
References _Assert, i2c_bus::mutex, RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
◆ i2c_bus_register()
int i2c_bus_register ( i2c_bus bus,
const char *  bus_path
This function claims ownership of the bus control regardless if the registration is successful or not.
Parameters
[in]bus_pathThe path to the bus device file.
Return values
References i2c_bus::destroy, and IMFS_make_generic_node().
◆ i2c_bus_release()
void i2c_bus_release ( i2c_bus bus)
Releases the bus.
Parameters
References _Assert, i2c_bus::mutex, rtems_semaphore_release(), and RTEMS_SUCCESSFUL.
◆ i2c_bus_transfer()
int i2c_bus_transfer ( i2c_bus bus,
i2c_msg msgs,
uint32_t  msg_count
The bus is obtained before the transfer and released afterwards.
Parameters
[in]msgsThe messages to transfer.
[in]msg_countThe count of messages to transfer. It must be positive.
Return values
negativeNegative error number in case of an error.
