This structure defines the type of device table.
More...
| file | devclose.c |
| | Maps Close Operation to rtems_io_close.
| file | devfs_eval.c |
| | Evaluate Patch.
| file | devfs_init.c |
| | Creates the Main Device Table.
| file | devfs_mknod.c |
| | Creates an item in the main device table.
| file | devfs_show.c |
| | Retrieves and Prints all the Device Registered in System.
| file | devioctl.c |
| | Maps ioctl Operation to rtems_io_ioctl.
| file | devopen.c |
| | Maps Open Operation to rtems_io_open.
| file | devstat.c |
| | Gets the Device File Information.
| file | devwrite.c |
| | Writes Operation to rtems_io_write.
void | devFS_eval_path (rtems_filesystem_eval_path_context_t *ctx) |
| | Evaluate Path.
| int | devFS_open (rtems_libio_t *iop, const char *pathname, int oflag, mode_t mode) |
| | Maps Open Operation to rtems_io_open. More...
| int | devFS_close (rtems_libio_t *iop) |
| | Maps Close Operation to rtems_io_close. More...
| ssize_t | devFS_read (rtems_libio_t *iop, void *buffer, size_t count) |
| | Maps Read Operation to rtems_io_read. More...
| ssize_t | devFS_write (rtems_libio_t *iop, const void *buffer, size_t count) |
| | Writes Operation to rtems_io_write. More...
| int | devFS_ioctl (rtems_libio_t *iop, ioctl_command_t command, void *buffer) |
| | Maps ioctl Operation to rtems_io_ioctl. More...
| int | devFS_stat (const rtems_filesystem_location_info_t *loc, struct stat *buf) |
| | Gets the Device File Information. More...
| int | devFS_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
| | Creates an item in the main device table. More...
| int | devFS_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| | Creates the Main Device Table. More...
| void | devFS_Show (void) |
| | Retrieves and Prints all the Device Registered in System. More...
◆ devFS_close()
This handler maps close operation to rtems_io_close.
- Parameters
| iop | This is the RTEMS's internal representation of file |
- Return values
◆ devFS_initialize()
This routine is invoked upon rtems filesystem initialization. It is responsible for creating the main device table, initializing it to a known state, and set device file operation handlers. After this, the device-only filesytem is ready for use
- Parameters
| mt_entry | The filesystem mount table entry. |
| data | Filesystem specific data. |
- Return values
| upon | success, this routine returns 0; otherwise it returns -1 and errno is set to proper value. The only error is when malloc failed, and errno is set to NOMEM. |
References devFS_file_handlers, and devFS_ops.
◆ devFS_ioctl()
| int devFS_ioctl |
rtems_libio_t * |
iop, |
ioctl_command_t |
command, |
void * |
buffer |
This handler maps ioctl operation to rtems_io_ioctl.
- Parameters
| command | io control command |
| buffer | io control parameters |
- Return values
| On | successful, this routine returns total bytes written. On error it returns -1 and errno is set to proper value. |
◆ devFS_mknod()
This routine is invoked upon registration of a new device file. It is responsible for creating a item in the main device table. This routine searches the device table in sequential order, when found a empty slot, it fills the slot with proper values.
- See also
- rtems_filesystem_mknod_t.
◆ devFS_open()
| int devFS_open |
rtems_libio_t * |
iop, |
const char * |
pathname, |
int |
oflag, |
mode_t |
mode |
This handler maps open operation to rtems_io_open.
- Parameters
| iop | This is the RTEMS's internal representation of file. |
| pathname | a null-terminated string that starts with /dev. |
| oflag | access flags |
| mode | access mode |
- Return values
References devFS_node::major, devFS_node::minor, and rtems_deviceio_open().
◆ devFS_read()
| ssize_t devFS_read |
rtems_libio_t * |
iop, |
void * |
buffer, |
size_t |
count |
This handler maps read operation to rtems_io_read.
- Parameters
| buffer | memory location to store read data |
| count | how many bytes to read |
- Return values
| On | successful, this routine returns total bytes read. On error it returns -1 and errno is set to proper value. |
◆ devFS_Show()
This routine retrieves all the device registered in system, and prints out their detail information. For example, on one system, devFS_show will print out following message:
/dev/console 0 0
/dev/clock 1 0
/dev/tty0 0 0
/flash 2 0
This routine is intended for debugging, and can be used by shell program to provide user with the system information.
◆ devFS_stat()
This handler gets the device file information. This routine only set the following member of struct stat:
- st_dev: device number
- st_mode: device file creation mode, only two mode are accepted:
- S_IFCHR: character device file
- S_IFBLK: block device file
- Parameters
| loc | contains filesystem access information |
| buf | buffer to hold the device file's information |
- Return values
| On | successful, this routine returns 0. On error it returns -1 and errno is set to proper value. |
◆ devFS_write()
| ssize_t devFS_write |
rtems_libio_t * |
iop, |
const void * |
buffer, |
size_t |
count |
This handler maps write operation to rtems_io_write.
- Parameters
| buffer | data to be written |
| count | how many bytes to write |
- Return values
