Modules | Files | Functions
Directives provided are: More...
Collaboration diagram for Signals:
 Signals Implementation
file  rtems/include/rtems/rtems/signal.h
 Signals API.
file  signal.c
 Signal Manager Initialization.
file  signalcatch.c
 RTEMS Catch Signal.
file  signalsend.c
 RTEMS Send Signal.
rtems_status_code rtems_signal_catch (rtems_asr_entry asr_handler, rtems_mode mode_set)
 RTEMS Catch Signal. More...
rtems_status_code rtems_signal_send (rtems_id id, rtems_signal_set signal_set)
 RTEMS Send Signal. More...
◆ rtems_signal_catch()
rtems_status_code rtems_signal_catch ( rtems_asr_entry  asr_handler,
rtems_mode  mode_set
RTEMS Catch Signal.
This routine implements the rtems_signal_catch directive. This directive is used to establish asr_handler as the Asynchronous Signal Routine (RTEMS_ASR) for the calling task. The asr_handler will execute with a mode of mode_set.
Parameters
[in]asr_handleris the address of asynchronous signal routine (asr) ( NULL indicates asr is invalid )
[in]mode_setis the mode value for asr
Return values
RTEMS_SUCCESSFUL
References _ASR_Initialize(), _ASR_Is_null_handler(), _Thread_Disable_dispatch(), _Thread_Enable_dispatch(), _Thread_Get_executing(), Thread_Control::API_Extensions, ASR_Information::handler, ASR_Information::mode_set, RTEMS_SUCCESSFUL, RTEMS_API_Control::Signal, and THREAD_API_RTEMS.
◆ rtems_signal_send()
rtems_status_code rtems_signal_send ( rtems_id  id,
RTEMS Send Signal.
This routine implements the rtems_signal_send directive. This directive sends the signal_set to the task specified by ID.
Parameters
[in]idis the thread thread id
[in]signal_setis the signal set
Return values
RTEMS_SUCCESSFULif successful or error code if unsuccessful
References _Thread_Get(), and RTEMS_INVALID_NUMBER.
