This group assists in issues related to timestamp implementation. More...
#define | CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
Selects the timestamp implementation using struct timespec. More... | |
#define | CPU_TIMESTAMP_USE_INT64 TRUE |
Selects the timestamp implementation using int64_t and no inlined methods. More... | |
#define | CPU_TIMESTAMP_USE_INT64_INLINE TRUE |
Selects the timestamp implementation using int64_t and inlined methods. More... | |
The port must choose exactly one of the following defines:
On PowerPC/psim, inlined int64_t saves ~50 instructions on each _Thread_Dispatch operation which results in a context switch. This works out to be about 10% faster dispatches and 7.5% faster blocking semaphore obtains. The following numbers are in instructions and from tm02 and tm26.
timespec int64 inlined int64
dispatch: 446 446 400 blocking sem obtain: 627 626 581
On SPARC/sis, inlined int64_t shows the same percentage gains. The following numbers are in microseconds and from tm02 and tm26.
dispatch: 59 61 53 blocking sem obtain: 98 100 92
Inlining appears to have a tendency to increase the size of some executables. Not inlining reduces the execution improvement but does not seem to be an improvement on the PowerPC and SPARC. The struct timespec and the executables with int64 not inlined are about the same size.
#define CPU_TIMESTAMP_USE_INT64 TRUE |
Port Specific Information:
XXX document implementation including references if appropriate
#define CPU_TIMESTAMP_USE_INT64_INLINE TRUE |
#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
