20 #ifndef CONFIGURE_SCHEDULER_CBS 21 #error "cbs.h available only with CONFIGURE_SCHEDULER_CBS" 34 #define RTEMS_CBS_OK SCHEDULER_CBS_OK 35 #define RTEMS_CBS_ERROR_GENERIC SCHEDULER_CBS_ERROR_GENERIC 36 #define RTEMS_CBS_ERROR_NO_MEMORY SCHEDULER_CBS_ERROR_NO_MEMORY 37 #define RTEMS_CBS_ERROR_INVALID_PARAMETER SCHEDULER_CBS_ERROR_INVALID_PARAM 38 #define RTEMS_CBS_ERROR_UNAUTHORIZED SCHEDULER_CBS_ERROR_UNAUTHORIZED 39 #define RTEMS_CBS_ERROR_UNIMPLEMENTED SCHEDULER_CBS_ERROR_UNIMPLEMENTED 40 #define RTEMS_CBS_ERROR_MISSING_COMPONENT SCHEDULER_CBS_ERROR_MISSING_COMPONENT 41 #define RTEMS_CBS_ERROR_INCONSISTENT_STATE SCHEDULER_CBS_ERROR_INCONSISTENT_STATE 42 #define RTEMS_CBS_ERROR_SYSTEM_OVERLOAD SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD 43 #define RTEMS_CBS_ERROR_INTERNAL_ERROR SCHEDULER_CBS_ERROR_INTERNAL_ERROR 44 #define RTEMS_CBS_ERROR_NOT_FOUND SCHEDULER_CBS_ERROR_NOT_FOUND 45 #define RTEMS_CBS_ERROR_FULL SCHEDULER_CBS_ERROR_FULL 46 #define RTEMS_CBS_ERROR_EMPTY SCHEDULER_CBS_ERROR_EMPTY 47 #define RTEMS_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOSERVER 90 rtems_cbs_parameters *params,
91 rtems_cbs_budget_overrun budget_overrun_callback,
92 rtems_cbs_server_id *server_id
97 budget_overrun_callback,
110 rtems_cbs_server_id server_id,
125 rtems_cbs_server_id server_id,
140 rtems_cbs_server_id server_id
156 rtems_cbs_server_id *server_id
170 rtems_cbs_server_id server_id,
171 rtems_cbs_parameters *params
185 rtems_cbs_server_id server_id,
186 rtems_cbs_parameters *params
200 rtems_cbs_server_id server_id,
216 rtems_cbs_server_id server_id,
217 time_t *remaining_budget
232 rtems_cbs_server_id server_id,
RTEMS_INLINE_ROUTINE int rtems_cbs_get_server_id(rtems_id task_id, rtems_cbs_server_id *server_id)
Get CBS server id.
Definition: cbs.h:154
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: rtems/include/rtems/rtems/types.h:80
int _Scheduler_CBS_Attach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Attach a task to an already existing server.
Definition: schedulercbsattachthread.c:24
RTEMS_INLINE_ROUTINE int rtems_cbs_get_approved_budget(rtems_cbs_server_id server_id, time_t *appr_budget)
Get the approved CBS budget.
Definition: cbs.h:231
Scheduler_CBS_Budget_overrun rtems_cbs_budget_overrun
Callback function invoked when a budget overrun of a task occurs.
Definition: cbs.h:50
int _Scheduler_CBS_Get_server_id(rtems_id task_id, Scheduler_CBS_Server_id *server_id)
Get a thread server id.
Definition: schedulercbsgetserverid.c:26
int _Scheduler_CBS_Get_execution_time(Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time)
Get relative time info.
Definition: schedulercbsgetexecutiontime.c:25
#define RTEMS_INLINE_ROUTINE
The following (in conjunction with compiler arguments) are used to choose between the use of static i...
Definition: basedefs.h:135
RTEMS_INLINE_ROUTINE int rtems_cbs_initialize(void)
Initialize the CBS library.
Definition: cbs.h:65
RTEMS_INLINE_ROUTINE int rtems_cbs_detach_thread(rtems_cbs_server_id server_id, rtems_id task_id)
Detach from the CBS server.
Definition: cbs.h:124
Scheduler_CBS_Server_id rtems_cbs_server_id
Server id.
Definition: cbs.h:53
RTEMS_INLINE_ROUTINE int rtems_cbs_destroy_server(rtems_cbs_server_id server_id)
Detach all tasks from a server and destroy it.
Definition: cbs.h:139
void(* Scheduler_CBS_Budget_overrun)(Scheduler_CBS_Server_id server_id)
Definition: schedulercbs.h:90
uint32_t Scheduler_CBS_Server_id
Server id.
Definition: schedulercbs.h:87
int _Scheduler_CBS_Set_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters)
Set parameters for CBS scheduling.
Definition: schedulercbssetparameters.c:27
RTEMS_INLINE_ROUTINE int rtems_cbs_get_parameters(rtems_cbs_server_id server_id, rtems_cbs_parameters *params)
Get CBS parameters.
Definition: cbs.h:169
RTEMS_INLINE_ROUTINE int rtems_cbs_create_server(rtems_cbs_parameters *params, rtems_cbs_budget_overrun budget_overrun_callback, rtems_cbs_server_id *server_id)
Create a new server with specified parameters.
Definition: cbs.h:89
int _Scheduler_CBS_Initialize(void)
Definition: schedulercbs.c:49
int _Scheduler_CBS_Get_approved_budget(Scheduler_CBS_Server_id server_id, time_t *approved_budget)
Retrieve the approved budget.
Definition: schedulercbsgetapprovedbudget.c:26
int _Scheduler_CBS_Get_parameters(Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params)
Retrieve CBS scheduling parameters.
Definition: schedulercbsgetparameters.c:26
This structure handles server parameters.
Definition: schedulercbs.h:97
RTEMS_INLINE_ROUTINE int rtems_cbs_attach_thread(rtems_cbs_server_id server_id, rtems_id task_id)
Definition: cbs.h:109
int _Scheduler_CBS_Destroy_server(Scheduler_CBS_Server_id server_id)
Definition: schedulercbsdestroyserver.c:25
RTEMS_INLINE_ROUTINE int rtems_cbs_set_parameters(rtems_cbs_server_id server_id, rtems_cbs_parameters *params)
Set CBS parameters.
Definition: cbs.h:184
int _Scheduler_CBS_Create_server(Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id)
Definition: schedulercbscreateserver.c:23
int _Scheduler_CBS_Cleanup(void)
Cleanup resources associated to the CBS Library.
Definition: schedulercbscleanup.c:24
RTEMS_INLINE_ROUTINE int rtems_cbs_cleanup(void)
Definition: cbs.h:77
int _Scheduler_CBS_Detach_thread(Scheduler_CBS_Server_id server_id, rtems_id task_id)
Detach from the CBS Server.
Definition: schedulercbsdetachthread.c:25
Scheduler_CBS_Parameters rtems_cbs_parameters
Server parameters.
Definition: cbs.h:56
int _Scheduler_CBS_Get_remaining_budget(Scheduler_CBS_Server_id server_id, time_t *remaining_budget)
Retrieve remaining budget for the current server instance.
Definition: schedulercbsgetremainingbudget.c:24
RTEMS_INLINE_ROUTINE int rtems_cbs_get_execution_time(rtems_cbs_server_id server_id, time_t *exec_time, time_t *abs_time)
Get the CBS get execution time.
Definition: cbs.h:199
RTEMS_INLINE_ROUTINE int rtems_cbs_get_remaining_budget(rtems_cbs_server_id server_id, time_t *remaining_budget)
Get the remaining CBS budget.
Definition: cbs.h:215
Thread manipulation for the CBS scheduler.
