| #define | SCHEDULER_CBS_ENTRY_POINTS |
| | Entry points for the Constant Bandwidth Server Scheduler. More...
#define | SCHEDULER_CBS_OK 0 |
#define | SCHEDULER_CBS_ERROR_GENERIC -16 |
#define | SCHEDULER_CBS_ERROR_NO_MEMORY -17 |
#define | SCHEDULER_CBS_ERROR_INVALID_PARAMETER -18 |
#define | SCHEDULER_CBS_ERROR_UNAUTHORIZED -19 |
#define | SCHEDULER_CBS_ERROR_UNIMPLEMENTED -20 |
#define | SCHEDULER_CBS_ERROR_MISSING_COMPONENT -21 |
#define | SCHEDULER_CBS_ERROR_INCONSISTENT_STATE -22 |
#define | SCHEDULER_CBS_ERROR_SYSTEM_OVERLOAD -23 |
#define | SCHEDULER_CBS_ERROR_INTERNAL_ERROR -24 |
#define | SCHEDULER_CBS_ERROR_NOT_FOUND -25 |
#define | SCHEDULER_CBS_ERROR_FULL -26 |
#define | SCHEDULER_CBS_ERROR_EMPTY -27 |
#define | SCHEDULER_CBS_ERROR_NOSERVER SCHEDULER_CBS_ERROR_NOT_FOUND |
| Scheduler_Void_or_thread | _Scheduler_CBS_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| | Unblocks a thread from the queue. More...
| void | _Scheduler_CBS_Release_job (const Scheduler_Control *scheduler, Thread_Control *the_thread, uint32_t length) |
| | Called when a new job of task is released. More...
| int | _Scheduler_CBS_Initialize (void) |
| | _Scheduler_CBS_Initialize More...
| int | _Scheduler_CBS_Attach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id) |
| | Attach a task to an already existing server. More...
| int | _Scheduler_CBS_Detach_thread (Scheduler_CBS_Server_id server_id, rtems_id task_id) |
| | Detach from the CBS Server. More...
| int | _Scheduler_CBS_Cleanup (void) |
| | Cleanup resources associated to the CBS Library. More...
| int | _Scheduler_CBS_Create_server (Scheduler_CBS_Parameters *params, Scheduler_CBS_Budget_overrun budget_overrun_callback, rtems_id *server_id) |
| | Create a new server with specified parameters. More...
| int | _Scheduler_CBS_Destroy_server (Scheduler_CBS_Server_id server_id) |
| | Detach all tasks from a server and destroy it. More...
| int | _Scheduler_CBS_Get_approved_budget (Scheduler_CBS_Server_id server_id, time_t *approved_budget) |
| | Retrieve the approved budget. More...
| int | _Scheduler_CBS_Get_remaining_budget (Scheduler_CBS_Server_id server_id, time_t *remaining_budget) |
| | Retrieve remaining budget for the current server instance. More...
| int | _Scheduler_CBS_Get_execution_time (Scheduler_CBS_Server_id server_id, time_t *exec_time, time_t *abs_time) |
| | Get relative time info. More...
| int | _Scheduler_CBS_Get_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *params) |
| | Retrieve CBS scheduling parameters. More...
| int | _Scheduler_CBS_Get_server_id (rtems_id task_id, Scheduler_CBS_Server_id *server_id) |
| | Get a thread server id. More...
| int | _Scheduler_CBS_Set_parameters (Scheduler_CBS_Server_id server_id, Scheduler_CBS_Parameters *parameters) |
| | Set parameters for CBS scheduling. More...
| void | _Scheduler_CBS_Budget_callout (Thread_Control *the_thread) |
| | Invoked when a limited time quantum is exceeded. More...
void | _Scheduler_CBS_Node_initialize (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| | Initializes a CBS specific scheduler node of the_thread.
Thread manipulation for the CBS scheduler.
This include file contains all the constants and structures associated with the manipulation of threads for the CBS scheduler.
