Data Structures | Functions
capture_support.c File Reference
#include <ctype.h>
#include <inttypes.h>
#include <rtems/monitor.h>
#include <rtems/captureimpl.h>
Include dependency graph for capture_support.c:
struct  ctrace_per_cpu_t
void rtems_capture_print_timestamp (uint64_t uptime)
 Capture print timestamp. More...
void rtems_capture_print_record_task (uint32_t cpu, rtems_capture_record_t *rec)
 Capture print record task. More...
void rtems_capture_print_record_capture (uint32_t cpu, rtems_capture_record_t *rec, uint64_t diff)
 Capture print capture record. More...
void rtems_capture_print_trace_records (int total, bool csv)
 Capture print trace records. More...
void rtems_capture_print_watch_list ()
 Capture print watch list. More...
◆ rtems_capture_print_record_capture()
void rtems_capture_print_record_capture ( uint32_t  cpu,
rtems_capture_record_t rec,
uint64_t  diff
This function prints a user extension capture record.
Parameters
[in]cpuspecifies the cpu the cpu the record was logged on.
[in]recspecifies the record.
[in]diffspecifies the time between this and the last capture record.
◆ rtems_capture_print_record_task()
void rtems_capture_print_record_task ( uint32_t  cpu,
This function prints a capture record task. This record contains information to identify a task. It is refrenced in other records by the task id.
Parameters
[in]recspecifies the task record.
References rtems_capture_print_timestamp().
Referenced by rtems_capture_print_timestamp().
◆ rtems_capture_print_timestamp()
void rtems_capture_print_timestamp ( uint64_t  uptime)
This function prints uptime in a timestamp format.
Parameters
[in]uptimespecifies the timestamp to print
References rtems_capture_print_record_task().
Referenced by rtems_capture_print_record_task().
◆ rtems_capture_print_trace_records()
void rtems_capture_print_trace_records ( int  total,
bool  csv
This function reads, prints and releases up to total trace records in either a csv format or an ascii table format.
Parameters
[in]totalspecifies the number of records to print
[in]csvspecifies a comma seperated value format
References read(), rtems_capture_read(), rtems_get_processor_count(), rtems_status_text(), and RTEMS_SUCCESSFUL.
◆ rtems_capture_print_watch_list()
void rtems_capture_print_watch_list ( void  )
This function prints a capture watch list
References rtems_capture_get_control_list(), rtems_capture_watch_get_ceiling(), rtems_capture_watch_get_floor(), and rtems_capture_watch_global_on().
