bfin/cpu.c File Reference
Blackfin CPU Dependent Source. More...
#include <rtems/score/isr.h>
#include <rtems/score/bfin.h>
#include <rtems/bfin/bfin.h>
Include dependency graph for bfin/cpu.c:
void _ISR15_Handler (void)
void _CPU_Emulation_handler (void)
void _CPU_Reset_handler (void)
void _CPU_NMI_handler (void)
void _CPU_Exception_handler (void)
void _CPU_Unhandled_Interrupt_handler (void)
void _CPU_Initialize (void)
 CPU initialization. More...
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs an interrupt vector. More...
void * _CPU_Thread_Idle_body (uint32_t ignored)
void _CPU_Context_Initialize (Context_Control *the_context, uint32_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area)
 Initialize the context to a state suitable for starting a task after a context restore operation. More...
void _CPU_Install_interrupt_stack (void)
 This routine installs the hardware interrupt stack pointer. More...
