POSIX Termios Implementation for RTEMS Console Device Driver. More...
#include <sys/types.h>
| struct | termios |
| #define | NCCS 19 |
| #define | _POSIX_VDISABLE 0 |
| This value is used to disable processing of a member of c_cc in the struct termios. | |
| #define | VINTR 0 |
| #define | VQUIT 1 |
| #define | VERASE 2 |
| #define | VKILL 3 |
| #define | VEOF 4 |
| #define | VTIME 5 |
| #define | VMIN 6 |
| #define | VSWTC 7 |
| #define | VSTART 8 |
| #define | VSTOP 9 |
| #define | VSUSP 10 |
| #define | VEOL 11 |
| #define | VREPRINT 12 |
| #define | VDISCARD 13 |
| #define | VWERASE 14 |
| #define | VLNEXT 15 |
| #define | VEOL2 16 |
| #define | IGNBRK 0000001 |
| #define | BRKINT 0000002 |
| #define | IGNPAR 0000004 |
| #define | PARMRK 0000010 |
| #define | INPCK 0000020 |
| #define | ISTRIP 0000040 |
| #define | INLCR 0000100 |
| #define | IGNCR 0000200 |
| #define | ICRNL 0000400 |
| #define | IUCLC 0001000 |
| #define | IXON 0002000 |
| #define | IXANY 0004000 |
| #define | IXOFF 0010000 |
| #define | IMAXBEL 0020000 |
| #define | OPOST 0000001 |
| #define | OLCUC 0000002 |
| #define | ONLCR 0000004 |
| #define | OCRNL 0000010 |
| #define | ONOCR 0000020 |
| #define | ONLRET 0000040 |
| #define | OFILL 0000100 |
| #define | OFDEL 0000200 |
| #define | NLDLY 0000400 |
| #define | NL0 0000000 |
| #define | NL1 0000400 |
| #define | CRDLY 0003000 |
| #define | CR0 0000000 |
| #define | CR1 0001000 |
| #define | CR2 0002000 |
| #define | CR3 0003000 |
| #define | TABDLY 0014000 |
| #define | TAB0 0000000 |
| #define | TAB1 0004000 |
| #define | TAB2 0010000 |
| #define | TAB3 0014000 |
| #define | XTABS 0014000 |
| #define | BSDLY 0020000 |
| #define | BS0 0000000 |
| #define | BS1 0020000 |
| #define | VTDLY 0040000 |
| #define | VT0 0000000 |
| #define | VT1 0040000 |
| #define | FFDLY 0100000 |
| #define | FF0 0000000 |
| #define | FF1 0100000 |
| #define | CBAUD 0010017 |
| #define | B0 0000000 /* hang up */ |
| #define | B50 0000001 |
| #define | B75 0000002 |
| #define | B110 0000003 |
| #define | B134 0000004 |
| #define | B150 0000005 |
| #define | B200 0000006 |
| #define | B300 0000007 |
| #define | B600 0000010 |
| #define | B1200 0000011 |
| #define | B1800 0000012 |
| #define | B2400 0000013 |
| #define | B4800 0000014 |
| #define | B9600 0000015 |
| #define | B19200 0000016 |
| #define | B38400 0000017 |
| #define | EXTA B19200 |
| #define | EXTB B38400 |
| #define | CSIZE 0000060 |
| #define | CS5 0000000 |
| #define | CS6 0000020 |
| #define | CS7 0000040 |
| #define | CS8 0000060 |
| #define | CSTOPB 0000100 |
| #define | CREAD 0000200 |
| #define | PARENB 0000400 |
| #define | PARODD 0001000 |
| #define | HUPCL 0002000 |
| #define | CLOCAL 0004000 |
| #define | CBAUDEX 0010000 |
| #define | B57600 0010001 |
| #define | B115200 0010002 |
| #define | B230400 0010003 |
| #define | B460800 0010004 |
| #define | CIBAUD 002003600000 /* input baud rate (not used) */ |
| #define | CRTSCTS 020000000000 /* flow control */ |
| #define | RTEMS_TERMIOS_NUMBER_BAUD_RATES 20 |
| #define | ISIG 0000001 |
| #define | ICANON 0000002 |
| #define | XCASE 0000004 |
| #define | ECHO 0000010 |
| #define | ECHOE 0000020 |
| #define | ECHOK 0000040 |
| #define | ECHONL 0000100 |
| #define | NOFLSH 0000200 |
| #define | TOSTOP 0000400 |
| #define | ECHOCTL 0001000 |
| #define | ECHOPRT 0002000 |
| #define | ECHOKE 0004000 |
| #define | FLUSHO 0010000 |
| #define | PENDIN 0040000 |
| #define | IEXTEN 0100000 |
| #define | TCOOFF 0 |
| #define | TCOON 1 |
| #define | TCIOFF 2 |
| #define | TCION 3 |
| #define | TCIFLUSH 0 |
| #define | TCOFLUSH 1 |
| #define | TCIOFLUSH 2 |
| #define | TCSANOW 0 |
| #define | TCSADRAIN 1 |
| #define | TCSAFLUSH 2 |
| typedef unsigned char | cc_t |
| POSIX Termios Implementation. More... | |
| typedef unsigned int | speed_t |
| typedef unsigned int | tcflag_t |
| int | tcdrain (int) |
| int | tcflow (int, int) |
| int | tcflush (int, int) |
| int | tcgetattr (int, struct termios *) |
| int | tcsetattr (int, int, struct termios *) |
| pid_t | tcgetprgrp (int) |
| int | tcsetprgrp (int, pid_t) |
| int | tcsendbreak (int, int) |
| speed_t | cfgetospeed (const struct termios *tp) |
| int | cfsetospeed (struct termios *tp, speed_t speed) |
| speed_t | cfgetispeed (const struct termios *tp) |
| int | cfsetispeed (struct termios *tp, speed_t speed) |
| void | cfmakeraw (struct termios *tp) |
| int | cfsetspeed (struct termios *tp, speed_t speed) |
The Open Group Base Specifications Issue 6 IEEE Std 1003.1, 2004 Edition Chapter 11, General Terminal Interface
