#define | CTL_MAXNAME 24 /* largest number of components supported */ |
#define | CTLTYPE 0xf /* Mask for the type */ |
#define | CTLTYPE_NODE 1 /* name is a node */ |
#define | CTLTYPE_INT 2 /* name describes an integer */ |
#define | CTLTYPE_STRING 3 /* name describes a string */ |
#define | CTLTYPE_QUAD 4 /* name describes a 64-bit number */ |
#define | CTLTYPE_OPAQUE 5 /* name describes a structure */ |
#define | CTLTYPE_STRUCT CTLTYPE_OPAQUE /* name describes a structure */ |
#define | CTLTYPE_UINT 6 /* name describes an unsigned integer */ |
#define | CTLTYPE_LONG 7 /* name describes a long */ |
#define | CTLTYPE_ULONG 8 /* name describes an unsigned long */ |
#define | CTLFLAG_RD 0x80000000 /* Allow reads of variable */ |
#define | CTLFLAG_WR 0x40000000 /* Allow writes to the variable */ |
#define | CTLFLAG_RW (CTLFLAG_RD|CTLFLAG_WR) |
#define | CTLFLAG_NOLOCK 0x20000000 /* XXX Don't Lock */ |
#define | CTLFLAG_ANYBODY 0x10000000 /* All users can set this var */ |
#define | CTLFLAG_SECURE 0x08000000 /* Permit set only if securelevel<=0 */ |
#define | CTLFLAG_PRISON 0x04000000 /* Prisoned roots can fiddle */ |
#define | CTLFLAG_DYN 0x02000000 /* Dynamic oid - can be freed */ |
#define | CTLFLAG_SKIP 0x01000000 /* Skip this sysctl when listing */ |
#define | CTLMASK_SECURE 0x00F00000 /* Secure level */ |
#define | CTLFLAG_TUN 0x00080000 /* Tunable variable */ |
#define | CTLFLAG_RDTUN (CTLFLAG_RD|CTLFLAG_TUN) |
#define | CTLSHIFT_SECURE 20 |
#define | CTLFLAG_SECURE1 (CTLFLAG_SECURE | (0 << CTLSHIFT_SECURE)) |
#define | CTLFLAG_SECURE2 (CTLFLAG_SECURE | (1 << CTLSHIFT_SECURE)) |
#define | CTLFLAG_SECURE3 (CTLFLAG_SECURE | (2 << CTLSHIFT_SECURE)) |
#define | OID_AUTO (-1) |
#define | CTL_AUTO_START 0x100 |
#define | CTL_UNSPEC 0 /* unused */ |
#define | CTL_KERN 1 /* "high kernel": proc, limits */ |
#define | CTL_VM 2 /* virtual memory */ |
#define | CTL_VFS 3 /* filesystem, mount type is next */ |
#define | CTL_NET 4 /* network, see socket.h */ |
#define | CTL_DEBUG 5 /* debugging parameters */ |
#define | CTL_HW 6 /* generic cpu/io */ |
#define | CTL_MACHDEP 7 /* machine dependent */ |
#define | CTL_USER 8 /* user-level */ |
#define | CTL_P1003_1B 9 /* POSIX 1003.1B */ |
#define | CTL_MAXID 10 /* number of valid top-level ids */ |
| #define | CTL_NAMES |
#define | KERN_OSTYPE 1 /* string: system version */ |
#define | KERN_OSRELEASE 2 /* string: system release */ |
#define | KERN_OSREV 3 /* int: system revision */ |
#define | KERN_VERSION 4 /* string: compile time info */ |
#define | KERN_MAXVNODES 5 /* int: max vnodes */ |
#define | KERN_MAXPROC 6 /* int: max processes */ |
#define | KERN_MAXFILES 7 /* int: max open files */ |
#define | KERN_ARGMAX 8 /* int: max arguments to exec */ |
#define | KERN_SECURELVL 9 /* int: system security level */ |
#define | KERN_HOSTNAME 10 /* string: hostname */ |
#define | KERN_HOSTID 11 /* int: host identifier */ |
#define | KERN_CLOCKRATE 12 /* struct: struct clockrate */ |
#define | KERN_VNODE 13 /* struct: vnode structures */ |
#define | KERN_PROC 14 /* struct: process entries */ |
#define | KERN_FILE 15 /* struct: file entries */ |
#define | KERN_PROF 16 /* node: kernel profiling info */ |
#define | KERN_POSIX1 17 /* int: POSIX.1 version */ |
#define | KERN_NGROUPS 18 /* int: # of supplemental group ids */ |
#define | KERN_JOB_CONTROL 19 /* int: is job control available */ |
#define | KERN_SAVED_IDS 20 /* int: saved set-user/group-ID */ |
#define | KERN_BOOTTIME 21 /* struct: time kernel was booted */ |
#define | KERN_NISDOMAINNAME 22 /* string: YP domain name */ |
#define | KERN_UPDATEINTERVAL 23 /* int: update process sleep time */ |
#define | KERN_OSRELDATE 24 /* int: kernel release date */ |
#define | KERN_NTP_PLL 25 /* node: NTP PLL control */ |
#define | KERN_BOOTFILE 26 /* string: name of booted kernel */ |
#define | KERN_MAXFILESPERPROC 27 /* int: max open files per proc */ |
#define | KERN_MAXPROCPERUID 28 /* int: max processes per uid */ |
#define | KERN_DUMPDEV 29 /* struct cdev *: device to dump on */ |
#define | KERN_IPC 30 /* node: anything related to IPC */ |
#define | KERN_DUMMY 31 /* unused */ |
#define | KERN_PS_STRINGS 32 /* int: address of PS_STRINGS */ |
#define | KERN_USRSTACK 33 /* int: address of USRSTACK */ |
#define | KERN_LOGSIGEXIT 34 /* int: do we log sigexit procs? */ |
#define | KERN_IOV_MAX 35 /* int: value of UIO_MAXIOV */ |
#define | KERN_MAXID 36 /* number of valid kern ids */ |
#define | CTL_KERN_NAMES |
| #define | CTL_VFS_NAMES |
#define | KERN_PROC_ALL 0 /* everything */ |
#define | KERN_PROC_PID 1 /* by process id */ |
#define | KERN_PROC_PGRP 2 /* by process group id */ |
#define | KERN_PROC_SESSION 3 /* by session of pid */ |
#define | KERN_PROC_TTY 4 /* by controlling tty */ |
#define | KERN_PROC_UID 5 /* by effective uid */ |
#define | KERN_PROC_RUID 6 /* by real uid */ |
#define | KERN_PROC_ARGS 7 /* get/set arguments/proctitle */ |
#define | KERN_PROC_PROC 8 /* only return procs */ |
#define | KERN_PROC_SV_NAME 9 /* get syscall vector name */ |
#define | KERN_PROC_RGID 10 /* by real group id */ |
#define | KERN_PROC_GID 11 /* by effective group id */ |
| #define | KERN_PROC_INC_THREAD |
#define | KIPC_MAXSOCKBUF 1 /* int: max size of a socket buffer */ |
#define | KIPC_SOCKBUF_WASTE 2 /* int: wastage factor in sockbuf */ |
#define | KIPC_SOMAXCONN 3 /* int: max length of connection q */ |
#define | KIPC_MAX_LINKHDR 4 /* int: max length of link header */ |
#define | KIPC_MAX_PROTOHDR 5 /* int: max length of network header */ |
#define | KIPC_MAX_HDR 6 /* int: max total length of headers */ |
#define | KIPC_MAX_DATALEN 7 /* int: max length of data? */ |
#define | HW_MACHINE 1 /* string: machine class */ |
#define | HW_MODEL 2 /* string: specific machine model */ |
#define | HW_NCPU 3 /* int: number of cpus */ |
#define | HW_BYTEORDER 4 /* int: machine byte order */ |
#define | HW_PHYSMEM 5 /* int: total memory */ |
#define | HW_USERMEM 6 /* int: non-kernel memory */ |
#define | HW_PAGESIZE 7 /* int: software page size */ |
#define | HW_DISKNAMES 8 /* strings: disk drive names */ |
#define | HW_DISKSTATS 9 /* struct: diskstats[] */ |
#define | HW_FLOATINGPT 10 /* int: has HW floating point? */ |
#define | HW_MACHINE_ARCH 11 /* string: machine architecture */ |
#define | HW_MAXID 12 /* number of valid hw ids */ |
| #define | CTL_HW_NAMES |
#define | USER_CS_PATH 1 /* string: _CS_PATH */ |
#define | USER_BC_BASE_MAX 2 /* int: BC_BASE_MAX */ |
#define | USER_BC_DIM_MAX 3 /* int: BC_DIM_MAX */ |
#define | USER_BC_SCALE_MAX 4 /* int: BC_SCALE_MAX */ |
#define | USER_BC_STRING_MAX 5 /* int: BC_STRING_MAX */ |
#define | USER_COLL_WEIGHTS_MAX 6 /* int: COLL_WEIGHTS_MAX */ |
#define | USER_EXPR_NEST_MAX 7 /* int: EXPR_NEST_MAX */ |
#define | USER_LINE_MAX 8 /* int: LINE_MAX */ |
#define | USER_RE_DUP_MAX 9 /* int: RE_DUP_MAX */ |
#define | USER_POSIX2_VERSION 10 /* int: POSIX2_VERSION */ |
#define | USER_POSIX2_C_BIND 11 /* int: POSIX2_C_BIND */ |
#define | USER_POSIX2_C_DEV 12 /* int: POSIX2_C_DEV */ |
#define | USER_POSIX2_CHAR_TERM 13 /* int: POSIX2_CHAR_TERM */ |
#define | USER_POSIX2_FORT_DEV 14 /* int: POSIX2_FORT_DEV */ |
#define | USER_POSIX2_FORT_RUN 15 /* int: POSIX2_FORT_RUN */ |
#define | USER_POSIX2_LOCALEDEF 16 /* int: POSIX2_LOCALEDEF */ |
#define | USER_POSIX2_SW_DEV 17 /* int: POSIX2_SW_DEV */ |
#define | USER_POSIX2_UPE 18 /* int: POSIX2_UPE */ |
#define | USER_STREAM_MAX 19 /* int: POSIX2_STREAM_MAX */ |
#define | USER_TZNAME_MAX 20 /* int: POSIX2_TZNAME_MAX */ |
#define | USER_MAXID 21 /* number of valid user ids */ |
| #define | CTL_USER_NAMES |
#define | CTL_P1003_1B_ASYNCHRONOUS_IO 1 /* boolean */ |
#define | CTL_P1003_1B_MAPPED_FILES 2 /* boolean */ |
#define | CTL_P1003_1B_MEMLOCK 3 /* boolean */ |
#define | CTL_P1003_1B_MEMLOCK_RANGE 4 /* boolean */ |
#define | CTL_P1003_1B_MEMORY_PROTECTION 5 /* boolean */ |
#define | CTL_P1003_1B_MESSAGE_PASSING 6 /* boolean */ |
#define | CTL_P1003_1B_PRIORITIZED_IO 7 /* boolean */ |
#define | CTL_P1003_1B_PRIORITY_SCHEDULING 8 /* boolean */ |
#define | CTL_P1003_1B_REALTIME_SIGNALS 9 /* boolean */ |
#define | CTL_P1003_1B_SEMAPHORES 10 /* boolean */ |
#define | CTL_P1003_1B_FSYNC 11 /* boolean */ |
#define | CTL_P1003_1B_SHARED_MEMORY_OBJECTS 12 /* boolean */ |
#define | CTL_P1003_1B_SYNCHRONIZED_IO 13 /* boolean */ |
#define | CTL_P1003_1B_TIMERS 14 /* boolean */ |
#define | CTL_P1003_1B_AIO_LISTIO_MAX 15 /* int */ |
#define | CTL_P1003_1B_AIO_MAX 16 /* int */ |
#define | CTL_P1003_1B_AIO_PRIO_DELTA_MAX 17 /* int */ |
#define | CTL_P1003_1B_DELAYTIMER_MAX 18 /* int */ |
#define | CTL_P1003_1B_MQ_OPEN_MAX 19 /* int */ |
#define | CTL_P1003_1B_PAGESIZE 20 /* int */ |
#define | CTL_P1003_1B_RTSIG_MAX 21 /* int */ |
#define | CTL_P1003_1B_SEM_NSEMS_MAX 22 /* int */ |
#define | CTL_P1003_1B_SEM_VALUE_MAX 23 /* int */ |
#define | CTL_P1003_1B_SIGQUEUE_MAX 24 /* int */ |
#define | CTL_P1003_1B_TIMER_MAX 25 /* int */ |
#define | CTL_P1003_1B_MAXID 26 |
| #define | CTL_P1003_1B_NAMES |
