Enable the Monitor to Show bdbuf InformationThis module inspects the bdbuf data structures, assuming they are static, but in fact they are used very dynamically. More...
#include <rtems.h>#include <rtems/monitor.h>#include <rtems/bdbuf.h>#include <string.h>#include <ctype.h>#include <stdio.h>#include <rtems/libio.h>#include <inttypes.h>
| struct | show_bdbuf_filter_t |
| struct | show_bdbuf_selector_t |
| struct | show_bdbuf_bdbuf_info_t |
| #define | DISABLE_PREEMPTION(key) |
| #define | ENABLE_PREEMPTION(key) |
| #define | ARRAY_CNT(arr) (sizeof((arr))/sizeof((arr)[0])) |
Typedefs | |
| typedef rtems_mode | preemption_key_t |
Enumerations | |
| enum | bdbuf_chain_identifier_t { bdbuf_chain_ident_none, bdbuf_chain_ident_free, bdbuf_chain_ident_lru, bdbuf_chain_ident_mod } |
| rtems_status_code | rtems_bdbuf_show_follow_chain_node_to_head (const Chain_Node *the_node, Chain_Control **the_head) |
| rtems_status_code | rtems_bdbuf_show_determine_chain_of_bdbuf (const bdbuf_buffer *the_bdbuf, const bdbuf_pool *curr_pool, bdbuf_chain_identifier_t *chn_ident) |
| rtems_status_code | rtems_bdbuf_show_getargs (int argc, char **argv, show_bdbuf_filter_t *filter, show_bdbuf_selector_t *selector) |
| rtems_status_code | rtems_bdbuf_show_get_bufpool (struct bdbuf_pool **pool_base_pptr, int *pool_cnt_ptr) |
| rtems_status_code | rtems_bdbuf_show_pool_header (int pool_idx, bdbuf_pool *pool_ptr) |
| rtems_status_code | rtems_show_bdbuf_get_bdbuf_info (const bdbuf_buffer *the_bdbuf, int bdbuf_idx, const bdbuf_pool *curr_pool, show_bdbuf_bdbuf_info_t *bdbuf_info) |
| rtems_status_code | rtems_show_bdbuf_match_filter (const show_bdbuf_bdbuf_info_t *bdbuf_info, const show_bdbuf_filter_t *filter, bool *is_match) |
| rtems_status_code | rtems_show_bdbuf_print_wait_chain (bdbuf_buffer *the_bdbuf) |
| rtems_status_code | rtems_show_bdbuf_print (const show_bdbuf_bdbuf_info_t *bdbuf_info, show_bdbuf_selector_t *selector, bool print_header) |
| void | rtems_bdbuf_show_fnc (int argc, char **argv, rtems_monitor_command_arg_t *command_arg, bool verbose) |
| rtems_status_code | rtems_bdbuf_show_init (void) |
Therefore the results show MAY BE INCORRECT in some cases. And, to cure this a bit, this module may block preemption for a rather long time and therefore it may BREAK THE REALTIME BEHAVIOUR OF YOUR SYSTEM (when in use)
| #define DISABLE_PREEMPTION | ( | key | ) |
| #define ENABLE_PREEMPTION | ( | key | ) |
