RTEMS Run-Time Linker Indirect Pointer Management allows memory compaction in the allocator. More...
#include <rtems/chain.h>
| struct | rtems_rtl_ptr_s |
| The RTL Indirect pointer. More... | |
| struct | rtems_rtl_sptr_s |
| The RTL Indirect size and pointer. More... | |
| struct | rtems_rtl_ptr_chain_s |
| A chain of indirect pointers for users to chain in applications. More... | |
| struct | rtems_rtl_sptr_chain_s |
| A chain of indirect sized pointers for users to chain in applications. More... | |
| #define | rtems_rtl_ptr_type_get(_h, _t) ((_t*) rtems_rtl_ptr_get (_h)) |
| Return the pointer as the type provided. More... | |
| #define | rtems_rtl_sptr_type_get(_h, _t) ((_t*) rtems_rtl_sptr_get (_h)) |
Typedefs | |
| typedef struct rtems_rtl_ptr_s | rtems_rtl_ptr_t |
| typedef struct rtems_rtl_sptr_s | rtems_rtl_sptr_t |
| typedef struct rtems_rtl_ptr_chain_s | rtems_rtl_ptr_chain_t |
| typedef struct rtems_rtl_sptr_chain_s | rtems_rtl_sptr_chain_t |
| #define rtems_rtl_ptr_type_get | ( | _h, | |
| _t | |||
| ) | ((_t*) rtems_rtl_ptr_get (_h)) |
| _h | The handle. |
| _t | The type. |
| #define rtems_rtl_sptr_type_get | ( | _h, | |
| _t | |||
| ) | ((_t*) rtems_rtl_sptr_get (_h)) |
| _h | The handle. |
| _t | The type. |
