RTEMS Run-Time Linker Object Support. More...
| bool | rtems_rtl_find_file (const char *name, const char *paths, const char **file_name, size_t *size) |
| Find a file on disk given a name and a path. More... | |
| bool rtems_rtl_find_file | ( | const char * | name, |
| const char * | paths, | ||
| const char ** | file_name, | ||
| size_t * | size | ||
| name | The file name to find. Can be relative or absolute. |
| paths | The paths to search. |
| file_name | Place the full path in this location if found. |
| size | The size of the file if found as returned by the 'stat' call. |
| true | The file was found. |
| false | The file was not found. |
