#include <stdint.h>#include <rtems/score/object.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>
| struct | rtems_object_api_class_information |
| This structure is used to return information to the application about the objects configured for a specific API/Class combination. More... | |
| #define | rtems_build_id(_api, _class, _node, _index) _Objects_Build_id( _api, _class, _node, _index ) |
| Build Object Id. More... | |
| #define | rtems_build_name(_C1, _C2, _C3, _C4) _Objects_Build_name( _C1, _C2, _C3, _C4 ) |
| Build Thirty-Two Bit Object Name. More... | |
| #define | rtems_object_id_get_api(_id) _Objects_Get_API( _id ) |
| Get API Portion of Object Id. More... | |
| #define | rtems_object_id_get_class(_id) _Objects_Get_class( _id ) |
| Get Class Portion of Object Id. More... | |
| #define | rtems_object_id_get_node(_id) _Objects_Get_node( _id ) |
| Get Node Portion of Object Id. More... | |
| #define | rtems_object_id_get_index(_id) _Objects_Get_index( _id ) |
| Get Index Portion of Object Id. More... | |
| #define | rtems_object_id_api_minimum() OBJECTS_INTERNAL_API |
| Get Lowest Valid API Index. More... | |
| #define | rtems_object_id_api_maximum() OBJECTS_APIS_LAST |
| Get Highest Valid API Index. More... | |
| rtems_status_code | rtems_object_get_classic_name (rtems_id id, rtems_name *name) |
| Obtain Name of Object. More... | |
| char * | rtems_object_get_name (rtems_id id, size_t length, char *name) |
| Obtain Object Name as String. More... | |
| rtems_status_code | rtems_object_set_name (rtems_id id, const char *name) |
| Set Name of Object. More... | |
| int | rtems_object_api_minimum_class (int api) |
| Get Lowest Valid Class Value. More... | |
| int | rtems_object_api_maximum_class (int api) |
| Get Highest Valid Class Value. More... | |
| int | rtems_object_id_api_maximum_class (int api) |
| const char * | rtems_object_get_api_name (int api) |
| Get API Name. More... | |
| const char * | rtems_object_get_api_class_name (int the_api, int the_class) |
| Get Class Name. More... | |
| rtems_status_code | rtems_object_get_class_information (int the_api, int the_class, rtems_object_api_class_information *info) |
| Get Class Information. More... | |
