RTEMS Application Loader. More...
Typedefs | |
| typedef bool(* | rtems_rap_iterator_t) (void *handle) |
| The module iterator handle. | |
| bool | rtems_rap_load (const char *name, int mode, int argc, const char *argv[]) |
| Load an application. More... | |
| bool | rtems_rap_unload (const char *name) |
| Unload an application. More... | |
| void * | rtems_rap_find (const char *name) |
| Find the application handle given a file name. More... | |
| bool | rtems_rap_iterate (rtems_rap_iterator_t iterator) |
| Run an iterator over the modules calling the iterator function. More... | |
| const char * | rtems_rap_name (void *handle) |
| Return the name of the module given a handle. More... | |
| void * | rtems_rap_dl_handle (void *handle) |
| Return the DL handle used to load the module given the RAP handle. More... | |
| int | rtems_rap_get_error (char *message, size_t max_message) |
| Get the last error message clearing it. More... | |
This is the RTEMS Application loader for files in the RAP format.
| void* rtems_rap_dl_handle | ( | void * | handle | ) |
| handle | The module handle. |
| void* rtems_rap_find | ( | const char * | name | ) |
| name | The name of the application file. It can be absolute or relative. Relative names can the basename with an extension. |
| NULL | No application file with that name found. |
| int rtems_rap_get_error | ( | char * | message, |
| size_t | max_message | ||
This call is not thread safe is multiple threads are loading object files at the same time. This call follows the model provided by the dlopen family of calls.
| message | Pointer to a buffer to copy the message into. |
| max_message | The maximum message that can be copied. |
| bool rtems_rap_iterate | ( | rtems_rap_iterator_t | iterator | ) |
| iterator | The iterator function. |
| true | The iterator function returned did not return false. |
| false | The iterator function returned false.. |
| bool rtems_rap_load | ( | const char * | name, |
| int | mode, | ||
| int | argc, | ||
| const char * | argv[] | ||
| name | The name of the application file. |
| const char* rtems_rap_name | ( | void * | handle | ) |
| bool rtems_rap_unload | ( | const char * | name | ) |
| obj | The application descriptor. |
| true | The application file has been unloaded. |
| false | The application could not be unloaded. |
