Register Fork Handlers. More...
| int | pthread_atfork (void(*prepare)(void), void(*parent)(void), void(*child)(void)) |
| POSIX 1003.1b 3.1.3. More... | |
| int pthread_atfork | ( | void(*)(void) | prepare, |
| void(*)(void) | parent, | ||
| void(*)(void) | child | ||
3.1.3 Register Fork Handlers, P1003.1c/Draft 10, P1003.1c/Draft 10, p. 27
RTEMS does not support processes, so we fall under this and do not provide this routine:
"Either the implementation shall support the pthread_atfork() function as described above or the pthread_atfork() funciton shall not be provided."
References rtems_set_errno_and_return_minus_one.
