#include <linux/kernel.h>#include <linux/mtd/mtd.h>#include <linux/compiler.h>#include <linux/sched.h>#include "nodelist.h"#include "debug.h"
| #define | pr_fmt(fmt) KBUILD_MODNAME ": " fmt |
| int | jffs2_reserve_space (struct jffs2_sb_info *c, uint32_t minsize, uint32_t *len, int prio, uint32_t sumsize) |
| int | jffs2_reserve_space_gc (struct jffs2_sb_info *c, uint32_t minsize, uint32_t *len, uint32_t sumsize) |
| struct jffs2_raw_node_ref * | jffs2_add_physical_node_ref (struct jffs2_sb_info *c, uint32_t ofs, uint32_t len, struct jffs2_inode_cache *ic) |
jffs2_add_physical_node_ref - add a physical node reference to the list : superblock info : new node reference to add : length of this physical node More... | |
| void | jffs2_complete_reservation (struct jffs2_sb_info *c) |
| void | jffs2_mark_node_obsolete (struct jffs2_sb_info *c, struct jffs2_raw_node_ref *ref) |
| int | jffs2_thread_should_wake (struct jffs2_sb_info *c) |
| struct jffs2_raw_node_ref* jffs2_add_physical_node_ref | ( | struct jffs2_sb_info * | c, |
| uint32_t | ofs, | ||
| uint32_t | len, | ||
| struct jffs2_inode_cache * | ic | ||
Should only be used to report nodes for which space has been allocated by jffs2_reserve_space.
Must be called with the alloc_sem held.
