Miscellaneous Routines Implementation for MSDOS FileSystem. More...
#include <ctype.h>
#include <sys/time.h>
#include <unistd.h>
#include <assert.h>
#include <inttypes.h>
#include <rtems/libio_.h>
#include "fat.h"
#include "fat_fat_operations.h"
#include "fat_file.h"
#include "msdos.h"
uint8_t | msdos_lfn_checksum (const void *entry) |
msdos_name_type_t | msdos_long_to_short (rtems_dosfs_convert_control *converter, const char *lfn, int lfn_len, char *sfn, int sfn_len) |
int | msdos_find_name (rtems_filesystem_location_info_t *parent_loc, const char *name, int name_len) |
int | msdos_get_name_node (const rtems_filesystem_location_info_t *parent_loc, bool create_node, const char *name, int name_len, msdos_name_type_t name_type, fat_dir_pos_t *dir_pos, char *name_dir_entry) |
int | msdos_get_dotdot_dir_info_cluster_num_and_offset (rtems_filesystem_mount_table_entry_t *mt_entry, uint32_t cln, fat_dir_pos_t *dir_pos, char *dir_entry) |
int | fat_file_write_time_and_date (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd) |
int | fat_file_write_first_cluster_num (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd) |
int | fat_file_write_file_size (fat_fs_info_t *fs_info, fat_file_fd_t *fat_fd) |
int | msdos_set_first_char4file_name (rtems_filesystem_mount_table_entry_t *mt_entry, fat_dir_pos_t *dir_pos, unsigned char fchar) |
int | msdos_dir_is_empty (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, bool *ret_val) |
ssize_t | msdos_get_utf16_string_from_long_entry (const char *entry, uint16_t *entry_string_buf, const size_t buf_size, bool is_first_entry) |
ssize_t | msdos_format_dirent_with_dot (char *dst, const char *src) |
int | msdos_find_name_in_fat_file (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, bool create_node, const uint8_t *name_utf8, int name_utf8_len, msdos_name_type_t name_type, fat_dir_pos_t *dir_pos, char *name_dir_entry) |
int | msdos_find_node_by_cluster_num_in_fat_file (rtems_filesystem_mount_table_entry_t *mt_entry, fat_file_fd_t *fat_fd, uint32_t cl4find, fat_dir_pos_t *dir_pos, char *dir_entry) |
int | msdos_sync (rtems_libio_t *iop) |
const char *const | MSDOS_DOT_NAME = ". " |
const char *const | MSDOS_DOTDOT_NAME = ".. " |
#define MSDOS_LFN_ENTRY_SIZE_UTF8 |
