#define | _LARGEFILE_SOURCE |
#define | __STDC_FORMAT_MACROS |
#define | __STDC_LIMIT_MACROS |
#define | SSL_LIB "libssl.so" |
#define | CRYPTO_LIB "libcrypto.so" |
#define | O_BINARY 0 |
#define | closesocket(a) close(a) |
#define | mg_mkdir(x, y) mkdir(x, y) |
#define | mg_remove(x) remove(x) |
#define | mg_sleep(x) usleep((x) * 1000) |
#define | ERRNO errno |
#define | INVALID_SOCKET (-1) |
#define | INT64_FMT PRId64 |
#define | WINCDECL |
#define | POLLIN 1 |
#define | MONGOOSE_VERSION "3.9" |
#define | PASSWORDS_FILE_NAME ".htpasswd" |
#define | CGI_ENVIRONMENT_SIZE 4096 |
#define | MAX_CGI_ENVIR_VARS 64 |
#define | MG_BUF_LEN 8192 |
#define | MAX_REQUEST_SIZE 16384 |
#define | ARRAY_SIZE(array) (sizeof(array) / sizeof(array[0])) |
#define | DEBUG_TRACE(x) |
#define | _DARWIN_UNLIMITED_SELECT |
#define | IP_ADDR_STR_LEN 50 |
#define | MSG_NOSIGNAL 0 |
#define | SOMAXCONN 100 |
#define | PATH_MAX 4096 |
#define | MGSQLEN 20 |
#define | SSL_free (* (void (*)(SSL *)) ssl_sw[0].ptr) |
#define | SSL_accept (* (int (*)(SSL *)) ssl_sw[1].ptr) |
#define | SSL_connect (* (int (*)(SSL *)) ssl_sw[2].ptr) |
#define | SSL_read (* (int (*)(SSL *, void *, int)) ssl_sw[3].ptr) |
#define | SSL_write (* (int (*)(SSL *, const void *,int)) ssl_sw[4].ptr) |
#define | SSL_get_error (* (int (*)(SSL *, int)) ssl_sw[5].ptr) |
#define | SSL_set_fd (* (int (*)(SSL *, SOCKET)) ssl_sw[6].ptr) |
#define | SSL_new (* (SSL * (*)(SSL_CTX *)) ssl_sw[7].ptr) |
#define | SSL_CTX_new (* (SSL_CTX * (*)(SSL_METHOD *)) ssl_sw[8].ptr) |
#define | SSLv23_server_method (* (SSL_METHOD * (*)(void)) ssl_sw[9].ptr) |
#define | SSL_library_init (* (int (*)(void)) ssl_sw[10].ptr) |
#define | SSL_CTX_use_PrivateKey_file |
#define | SSL_CTX_use_certificate_file |
#define | SSL_CTX_set_default_passwd_cb (* (void (*)(SSL_CTX *, mg_callback_t)) ssl_sw[13].ptr) |
#define | SSL_CTX_free (* (void (*)(SSL_CTX *)) ssl_sw[14].ptr) |
#define | SSL_load_error_strings (* (void (*)(void)) ssl_sw[15].ptr) |
#define | SSL_CTX_use_certificate_chain_file (* (int (*)(SSL_CTX *, const char *)) ssl_sw[16].ptr) |
#define | SSLv23_client_method (* (SSL_METHOD * (*)(void)) ssl_sw[17].ptr) |
#define | SSL_pending (* (int (*)(SSL *)) ssl_sw[18].ptr) |
#define | SSL_CTX_set_verify (* (void (*)(SSL_CTX *, int, int)) ssl_sw[19].ptr) |
#define | SSL_shutdown (* (int (*)(SSL *)) ssl_sw[20].ptr) |
#define | CRYPTO_num_locks (* (int (*)(void)) crypto_sw[0].ptr) |
#define | CRYPTO_set_locking_callback (* (void (*)(void (*)(int, int, const char *, int))) crypto_sw[1].ptr) |
#define | CRYPTO_set_id_callback (* (void (*)(unsigned long (*)(void))) crypto_sw[2].ptr) |
#define | ERR_get_error (* (unsigned long (*)(void)) crypto_sw[3].ptr) |
#define | ERR_error_string (* (char * (*)(unsigned long,char *)) crypto_sw[4].ptr) |
#define | STRUCT_FILE_INITIALIZER {0, 0, 0, NULL, NULL, 0} |
#define | HEXTOI(x) (isdigit(x) ? x - '0' : x - 'W') |
#define | F1(x, y, z) (z ^ (x & (y ^ z))) |
#define | F2(x, y, z) F1(z, x, y) |
#define | F3(x, y, z) (x ^ y ^ z) |
#define | F4(x, y, z) (y ^ (x | ~z)) |
#define | MD5STEP(f, w, x, y, z, data, s) ( w += f(x, y, z) + data, w = w<<s | w>>(32-s), w += x ) |
enum | {
CGI_EXTENSIONS,
CGI_ENVIRONMENT,
PUT_DELETE_PASSWORDS_FILE,
CGI_INTERPRETER,
PROTECT_URI,
AUTHENTICATION_DOMAIN,
SSI_EXTENSIONS,
THROTTLE,
ACCESS_LOG_FILE,
ENABLE_DIRECTORY_LISTING,
ERROR_LOG_FILE,
GLOBAL_PASSWORDS_FILE,
INDEX_FILES,
ENABLE_KEEP_ALIVE,
ACCESS_CONTROL_LIST,
EXTRA_MIME_TYPES,
LISTENING_PORTS,
DOCUMENT_ROOT,
SSL_CERTIFICATE,
NUM_THREADS,
RUN_AS_USER,
REWRITE,
HIDE_FILES,
REQUEST_TIMEOUT,
THREAD_STACK_SIZE,
THREAD_PRIORITY,
THREAD_POLICY,
NUM_OPTIONS
const char ** | mg_get_valid_option_names (void) |
const char * | mg_get_option (const struct mg_context *ctx, const char *name) |
const char * | mg_version (void) |
struct mg_request_info * | mg_get_request_info (struct mg_connection *conn) |
const char * | mg_get_header (const struct mg_connection *conn, const char *name) |
int | mg_start_thread (mg_thread_func_t func, void *param) |
int | mg_read (struct mg_connection *conn, void *buf, size_t len) |
int | mg_write (struct mg_connection *conn, const void *buf, size_t len) |
int | mg_printf (struct mg_connection *conn, const char *fmt,...) |
int | mg_url_decode (const char *src, int src_len, char *dst, int dst_len, int is_form_url_encoded) |
int | mg_get_var (const char *data, size_t data_len, const char *name, char *dst, size_t dst_len) |
int | mg_get_cookie (const char *cookie_header, const char *var_name, char *dst, size_t dst_size) |
const char * | mg_get_builtin_mime_type (const char *path) |
char * | mg_md5 (char buf[33],...) |
int | mg_modify_passwords_file (const char *fname, const char *domain, const char *user, const char *pass) |
void | mg_send_file (struct mg_connection *conn, const char *path) |
int | mg_upload (struct mg_connection *conn, const char *destination_dir) |
void | mg_close_connection (struct mg_connection *conn) |
struct mg_connection * | mg_download (const char *host, int port, int use_ssl, char *ebuf, size_t ebuf_len, const char *fmt,...) |
void | mg_stop (struct mg_context *ctx) |
struct mg_context * | mg_start (const struct mg_callbacks *callbacks, void *user_data, const char **options) |
