ISR Level Type. More...
| #define | _ISR_Disable(_level) |
| Disables interrupts on this processor. More... | |
| #define | _ISR_Enable(_level) |
| Enables interrupts on this processor. More... | |
| #define | _ISR_Flash(_level) |
| Temporarily enables interrupts on this processor. More... | |
| #define | _ISR_Get_level() _CPU_ISR_Get_level() |
| Return current interrupt level. More... | |
| #define | _ISR_Set_level(_new_level) |
| Set current interrupt level. More... | |
| #define | _ISR_Disable_without_giant(_level) |
| #define | _ISR_Enable_without_giant(_level) |
Typedefs | |
| typedef uint32_t | ISR_Level |
| The following type defines the control block used to manage the interrupt level portion of the status register. | |
ISR Level Type.
This include file defines the ISR Level type. It exists to simplify include dependencies. It is part of the ISR Handler.
