asm.h File Reference
#include <rtems/score/bfin.h>
#include <rtems/concat.h>
Include dependency graph for asm.h:
#define ASM
#define __USER_LABEL_PREFIX__   _
 Recent versions of GNU cpp define variables which indicate the need for underscores and percents. More...
#define __REGISTER_PREFIX__
 Use the right prefix for global labels. More...
 Use the right prefix for registers. More...
 This macro is used to denote the beginning of a code declaration. More...
#define END_CODE_DCL
 This macro is used to denote the end of a code declaration. More...
 This macro is used to denote the beginning of a data declaration section. More...
#define END_DATA_DCL
 This macro is used to denote the end of a data declaration section. More...
#define BEGIN_CODE   .text
 This macro is used to denote the beginning of a code section. More...
#define END_CODE
 This macro is used to denote the end of a code section. More...
#define BEGIN_DATA
 This macro is used to denote the beginning of a data section. More...
#define END_DATA
 This macro is used to denote the end of a data section. More...
#define BEGIN_BSS
 This macro is used to denote the beginning of the unitialized data section.
#define END_BSS
 This macro is used to denote the end of the unitialized data section. More...
#define END
 This macro is used to denote the end of the assembly file. More...
 This macro is used to declare a public global symbol. More...
 This macro is used to prototype a public global symbol. More...
Note
The spacing in the use of these macros is critical to them working as advertised.
◆ __REGISTER_PREFIX__
◆ __USER_LABEL_PREFIX__
◆ BEGIN_CODE
◆ BEGIN_CODE_DCL
#define BEGIN_CODE_DCL   .text
◆ BEGIN_DATA
#define BEGIN_DATA
◆ BEGIN_DATA_DCL
#define BEGIN_DATA_DCL   .data
◆ END
#define END
◆ END_BSS
#define END_BSS
◆ END_CODE
#define END_CODE
◆ END_CODE_DCL
◆ END_DATA
#define END_DATA
◆ END_DATA_DCL
◆ EXTERN
#define EXTERN (   sym)    .globl SYM (sym)
Note
This must be tailored for a particular flavor of the C compiler. They may need to put underscores in front of the symbols.
◆ PUBLIC
#define PUBLIC (   sym)    .globl SYM (sym)
Note
◆ REG
#define REG (   x)    CONCAT1 (__REGISTER_PREFIX__, x)
◆ SYM
#define SYM (   x)    CONCAT1 (__USER_LABEL_PREFIX__, x)
