RTEMS termios device support internal data structures. More...
#include <rtems.h>#include <rtems/libio.h>#include <rtems/assoc.h>#include <rtems/chain.h>#include <stdint.h>#include <termios.h>
| struct | ttywakeup |
| struct | rtems_termios_rawbuf |
| struct | rtems_termios_device_context |
| Termios device context. More... | |
| struct | rtems_termios_device_handler |
| Termios device handler. More... | |
| struct | rtems_termios_device_flow |
| Termios device flow control handler. More... | |
| struct | rtems_termios_device_node |
| Termios device node for installed devices. More... | |
| struct | rtems_termios_tty |
| struct | rtems_termios_linesw |
| #define | RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER(name) { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) } |
| Initializer for static initialization of Termios device contexts. More... | |
| #define | TTYDISC 0 /* termios tty line discipline */ |
| #define | TABLDISC 3 /* tablet discipline */ |
| #define | SLIPDISC 4 /* serial IP discipline */ |
| #define | PPPDISC 5 /* PPP discipline */ |
| #define | MAXLDISC 8 |
Typedefs | |
| typedef struct rtems_termios_device_context | rtems_termios_device_context |
| typedef struct rtems_termios_device_node | rtems_termios_device_node |
| typedef struct rtems_termios_tty | rtems_termios_tty |
| typedef uint32_t | rtems_termios_baud_t |
Enumerations | |
| enum | rtems_termios_device_mode { TERMIOS_POLLED, TERMIOS_IRQ_DRIVEN, TERMIOS_TASK_DRIVEN } |
| RTEMS_INLINE_ROUTINE void | rtems_termios_device_context_initialize (rtems_termios_device_context *context, const char *name) |
| Initializes a device context. More... | |
| rtems_status_code | rtems_termios_device_install (const char *device_file, rtems_device_major_number major, rtems_device_minor_number minor, const rtems_termios_device_handler *handler, const rtems_termios_device_flow *flow, rtems_termios_device_context *context) |
| Installs a Termios device. More... | |
| rtems_status_code | rtems_termios_device_remove (const char *device_file, rtems_device_major_number major, rtems_device_minor_number minor) |
| Removes a Termios device. More... | |
| rtems_status_code | rtems_termios_device_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Opens an installed Termios device. More... | |
| rtems_status_code | rtems_termios_device_close (void *arg) |
| Closes an installed Termios device. More... | |
| RTEMS_INLINE_ROUTINE void * | rtems_termios_get_device_context (const rtems_termios_tty *tty) |
| Returns the device context of an installed Termios device. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_termios_device_lock_acquire (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context) |
| Acquires the device lock. More... | |
| RTEMS_INLINE_ROUTINE void | rtems_termios_device_lock_release (rtems_termios_device_context *context, rtems_interrupt_lock_context *lock_context) |
| Releases the device lock. More... | |
| void | rtems_termios_set_best_baud (struct termios *term, uint32_t baud) |
| Sets the best baud value in the Termios control. More... | |
| void | rtems_termios_rxirq_occured (struct rtems_termios_tty *tty) |
| void | rtems_termios_puts (const void *buf, size_t len, struct rtems_termios_tty *tty) |
| tcflag_t | rtems_termios_number_to_baud (rtems_termios_baud_t baud) |
| Converts the Integral Baud value baud to the Termios Control Flag Representation. More... | |
| rtems_termios_baud_t | rtems_termios_baud_to_number (tcflag_t c_cflag) |
| Convert Baud Part of Termios control flags to an integral Baud Value. More... | |
| int | rtems_termios_baud_to_index (rtems_termios_baud_t termios_baud) |
| Convert Bxxx Constant to Index. | |
| int | rtems_termios_set_initial_baud (struct rtems_termios_tty *tty, rtems_termios_baud_t baud) |
| Sets the initial baud in the Termios context tty. More... | |
| struct rtems_termios_linesw | rtems_termios_linesw [] |
| int | rtems_termios_nlinesw |
| const rtems_assoc_t | rtems_termios_baud_table [] |
| RTEMS Termios Baud Table. | |
| #define RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER | ( | name | ) | { RTEMS_INTERRUPT_LOCK_INITIALIZER( name ) } |
| name | The name for the interrupt lock. It must be a string. The name is only used if profiling is enabled. |
| typedef struct rtems_termios_device_context rtems_termios_device_context |
| typedef struct rtems_termios_device_node rtems_termios_device_node |
| rtems_termios_baud_t rtems_termios_baud_to_number | ( | tcflag_t | c_cflag | ) |
There is no need to mask the c_cflag with CBAUD.
| 0 | Invalid baud value or a baud value of B0. |
| other | Integral baud value. |
| rtems_status_code rtems_termios_device_close | ( | void * | arg | ) |
| RTEMS_SUCCESSFUL | Successful operation. |
References rtems_fatal_error_occurred(), RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
| RTEMS_INLINE_ROUTINE void rtems_termios_device_context_initialize | ( | rtems_termios_device_context * | context, |
| const char * | name | ||
| [in] | context | The Termios device context. |
| [in] | name | The name for the interrupt lock. This name must be a string persistent throughout the life time of this lock. The name is only used if profiling is enabled. |
References rtems_interrupt_lock_initialize.
| rtems_status_code rtems_termios_device_install | ( | const char * | device_file, |
| rtems_device_major_number | major, | ||
| rtems_device_minor_number | minor, | ||
| const rtems_termios_device_handler * | handler, | ||
| const rtems_termios_device_flow * | flow, | ||
| rtems_termios_device_context * | context | ||
| [in] | device_file | If not NULL, then a device file for the specified major and minor number will be created. |
| [in] | major | The device major number of the corresponding device driver. |
| [in] | minor | The device minor number of the corresponding device driver. |
| [in] | handler | The device handler. It must be persistent throughout the installed time of the device. |
| [in] | flow | The device flow control handler. The device flow control handler are optional and may be NULL. If present must be persistent throughout the installed time of the device. |
| [in] | context | The device context. It must be persistent throughout the installed time of the device. |
| RTEMS_NO_MEMORY | Not enough memory to create a device node. |
| RTEMS_UNSATISFIED | Creation of the device file failed. |
| RTEMS_RESOURCE_IN_USE | There exists a device node for this major and minor number pair. |
| RTEMS_INCORRECT_STATE | Termios is not initialized. |
| RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_acquire | ( | rtems_termios_device_context * | context, |
| rtems_interrupt_lock_context * | lock_context | ||
| [in] | context | The device context. |
| [in] | lock_context | The local interrupt lock context for an acquire and release pair. |
References rtems_interrupt_lock_acquire.
| RTEMS_INLINE_ROUTINE void rtems_termios_device_lock_release | ( | rtems_termios_device_context * | context, |
References rtems_interrupt_lock_release, and rtems_termios_set_best_baud().
| rtems_status_code rtems_termios_device_open | ( | rtems_device_major_number | major, |
| void * | arg | ||
References rtems_termios_tty::device_node, RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
| rtems_status_code rtems_termios_device_remove | ( | const char * | device_file, |
| rtems_device_minor_number | minor | ||
| [in] | device_file | If not NULL, then the device file to remove. |
| RTEMS_INVALID_ID | There is no device installed with this major and minor number pair. |
| RTEMS_RESOURCE_IN_USE | This device is currently in use. |
| RTEMS_UNSATISFIED | Removal of the device file failed. |
References rtems_termios_tty::device_node, RTEMS_INCORRECT_STATE, RTEMS_NO_TIMEOUT, rtems_semaphore_obtain(), RTEMS_SUCCESSFUL, and RTEMS_WAIT.
| RTEMS_INLINE_ROUTINE void* rtems_termios_get_device_context | ( | const rtems_termios_tty * | tty | ) |
| [in] | tty | The Termios control. |
References rtems_termios_tty::device_context.
| tcflag_t rtems_termios_number_to_baud | ( | rtems_termios_baud_t | baud | ) |
| B0 | Invalid baud value or a baud value of 0. |
| other | Baud constant according to baud. |
Referenced by rtems_termios_set_initial_baud().
| void rtems_termios_set_best_baud | ( | struct termios * | term, |
| uint32_t | baud | ||
The valid Termios baud values are between 0 and 460800. The Termios baud value is chosen which minimizes the difference to the value specified.
| [in] | term | The Termios attributes. |
| [in] | baud | The current baud setting of the device. |
References rtems_termios_baud_table.
Referenced by rtems_termios_device_lock_release().
| int rtems_termios_set_initial_baud | ( | struct rtems_termios_tty * | tty, |
| rtems_termios_baud_t | baud | ||
| 0 | Successful operation. |
| -1 | Invalid baud value. |
References rtems_termios_number_to_baud().
