RTEMS File System Location Support. More...
RTEMS_INTERRUPT_LOCK_DEFINE (static, deferred_release_lock, "Filesystem Deferred Release") | |
void | rtems_filesystem_location_detach (rtems_filesystem_location_info_t *detach) |
void | rtems_filesystem_location_copy_and_detach (rtems_filesystem_location_info_t *copy, rtems_filesystem_location_info_t *detach) |
rtems_filesystem_global_location_t * | rtems_filesystem_location_transform_to_global (rtems_filesystem_location_info_t *loc) |
void | rtems_filesystem_global_location_assign (rtems_filesystem_global_location_t **lhs_global_loc_ptr, rtems_filesystem_global_location_t *rhs_global_loc) |
Assigns a global file system location. More... | |
rtems_filesystem_global_location_t * | rtems_filesystem_global_location_obtain (rtems_filesystem_global_location_t *const *global_loc_ptr) |
Obtains a global file system location. More... | |
void | rtems_filesystem_global_location_release (rtems_filesystem_global_location_t *global_loc, bool deferred) |
Releases a global file system location. More... | |
void | rtems_filesystem_location_remove_from_mt_entry (rtems_filesystem_location_info_t *loc) |
void | rtems_filesystem_do_unmount (rtems_filesystem_mount_table_entry_t *mt_entry) |
rtems_interrupt_lock | rtems_filesystem_mt_entry_lock_control |
