rtems_rate_monotonic_period_statistics Struct Reference
The following defines the PUBLIC data structure that has the statistics kept on each period instance. More...
#include <ratemon.h>
uint32_t count
 This field contains the number of periods executed. More...
uint32_t missed_count
 This field contains the number of periods missed. More...
rtems_thread_cpu_usage_t min_cpu_time
 This field contains the least amount of CPU time used in a period. More...
rtems_thread_cpu_usage_t max_cpu_time
 This field contains the highest amount of CPU time used in a period. More...
rtems_thread_cpu_usage_t total_cpu_time
 This field contains the total amount of wall time used in a period. More...
rtems_rate_monotonic_period_time_t min_wall_time
 This field contains the least amount of wall time used in a period. More...
rtems_rate_monotonic_period_time_t max_wall_time
 This field contains the highest amount of wall time used in a period. More...
rtems_rate_monotonic_period_time_t total_wall_time
 This field contains the total amount of CPU time used in a period. More...
Note
The public structure uses struct timespec while the internal one uses Timestamp_Control.
Field Documentation
◆ count
uint32_t rtems_rate_monotonic_period_statistics::count
◆ max_cpu_time
rtems_thread_cpu_usage_t rtems_rate_monotonic_period_statistics::max_cpu_time
◆ max_wall_time
rtems_rate_monotonic_period_time_t rtems_rate_monotonic_period_statistics::max_wall_time
◆ min_cpu_time
rtems_thread_cpu_usage_t rtems_rate_monotonic_period_statistics::min_cpu_time
◆ min_wall_time
rtems_rate_monotonic_period_time_t rtems_rate_monotonic_period_statistics::min_wall_time
◆ missed_count
uint32_t rtems_rate_monotonic_period_statistics::missed_count
◆ total_cpu_time
rtems_thread_cpu_usage_t rtems_rate_monotonic_period_statistics::total_cpu_time
◆ total_wall_time
rtems_rate_monotonic_period_time_t rtems_rate_monotonic_period_statistics::total_wall_time
