This structure is used to manage the cancelation handlers. More...
#include <cancel.h>
Data Fields | |
| Chain_Node | Node |
| This field is the Chain Node so we can put these on lists. More... | |
| void(* | routine )(void *) |
| This field is the cancelation routine. More... | |
| void * | arg |
| This field is the argument to the cancelation routine. More... | |
| void* POSIX_Cancel_Handler_control::arg |
Referenced by _POSIX_Threads_cancel_run().
| Chain_Node POSIX_Cancel_Handler_control::Node |
| void(* POSIX_Cancel_Handler_control::routine) (void *) |
