libdl
include
arch
sparc
machine
elf_machdep.h
1
/* $NetBSD: elf_machdep.h,v 1.7 2009/05/30 05:56:53 skrll Exp $ */
2
3
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
4
#define ELF32_MACHDEP_ID_CASES \
5
case EM_SPARC: \
6
case EM_SPARC32PLUS: \
7
break;
8
9
#define ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB
10
#define ELF64_MACHDEP_ID_CASES \
11
12
case EM_SPARCV9: \
13
/* no 64-bit ELF machine types supported */
14
15
#define ELF32_MACHDEP_ID EM_SPARC
/* XXX right? */
16
17
#define ARCH_ELFSIZE 32
/* MD native binary size */
18
19
#define R_SPARC_NONE 0
20
#define R_SPARC_8 1
21
#define R_SPARC_16 2
22
#define R_SPARC_32 3
23
#define R_SPARC_DISP8 4
24
#define R_SPARC_DISP16 5
25
#define R_SPARC_DISP32 6
26
#define R_SPARC_WDISP30 7
27
#define R_SPARC_WDISP22 8
28
#define R_SPARC_HI22 9
29
#define R_SPARC_22 10
30
#define R_SPARC_13 11
31
#define R_SPARC_LO10 12
32
#define R_SPARC_GOT10 13
33
#define R_SPARC_GOT13 14
34
#define R_SPARC_GOT22 15
35
#define R_SPARC_PC10 16
36
#define R_SPARC_PC22 17
37
#define R_SPARC_WPLT30 18
38
#define R_SPARC_COPY 19
39
#define R_SPARC_GLOB_DAT 20
40
#define R_SPARC_JMP_SLOT 21
41
#define R_SPARC_RELATIVE 22
42
#define R_SPARC_UA32 23
43
#define R_SPARC_PLT32 24
44
#define R_SPARC_HIPLT22 25
45
#define R_SPARC_LOPLT10 26
46
#define R_SPARC_PCPLT32 27
47
#define R_SPARC_PCPLT22 28
48
#define R_SPARC_PCPLT10 29
49
#define R_SPARC_10 30
50
#define R_SPARC_11 31
51
#define R_SPARC_64 32
52
#define R_SPARC_OLO10 33
53
#define R_SPARC_HH22 34
54
#define R_SPARC_HM10 35
55
#define R_SPARC_LM22 36
56
#define R_SPARC_PC_HH22 37
57
#define R_SPARC_PC_HM10 38
58
#define R_SPARC_PC_LM22 39
59
#define R_SPARC_WDISP16 40
60
#define R_SPARC_WDISP19 41
61
#define R_SPARC_GLOB_JMP 42
62
#define R_SPARC_7 43
63
#define R_SPARC_5 44
64
#define R_SPARC_6 45
65
66
/* TLS relocations */
67
#define R_SPARC_TLS_GD_HI22 56
68
#define R_SPARC_TLS_GD_LO10 57
69
#define R_SPARC_TLS_GD_ADD 58
70
#define R_SPARC_TLS_GD_CALL 59
71
#define R_SPARC_TLS_LDM_HI22 60
72
#define R_SPARC_TLS_LDM_LO10 61
73
#define R_SPARC_TLS_LDM_ADD 62
74
#define R_SPARC_TLS_LDM_CALL 63
75
#define R_SPARC_TLS_LDO_HIX22 64
76
#define R_SPARC_TLS_LDO_LOX10 65
77
#define R_SPARC_TLS_LDO_ADD 66
78
#define R_SPARC_TLS_IE_HI22 67
79
#define R_SPARC_TLS_IE_LO10 68
80
#define R_SPARC_TLS_IE_LD 69
81
#define R_SPARC_TLS_IE_LDX 70
82
#define R_SPARC_TLS_IE_ADD 71
83
#define R_SPARC_TLS_LE_HIX22 72
84
#define R_SPARC_TLS_LE_LOX10 73
85
#define R_SPARC_TLS_DTPMOD32 74
86
#define R_SPARC_TLS_DTPMOD64 75
87
#define R_SPARC_TLS_DTPOFF32 76
88
#define R_SPARC_TLS_DTPOFF64 77
89
#define R_SPARC_TLS_TPOFF32 78
90
#define R_SPARC_TLS_TPOFF64 79
91
92
#define R_TYPE(name) __CONCAT(R_SPARC_,name)
