#define | ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB |
| #define | ELF32_MACHDEP_ID_CASES |
#define | ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB |
| #define | ELF64_MACHDEP_ID_CASES |
#define | ELF32_MACHDEP_ID EM_SPARC /* XXX right? */ |
#define | ARCH_ELFSIZE 32 /* MD native binary size */ |
#define | R_SPARC_NONE 0 |
#define | R_SPARC_8 1 |
#define | R_SPARC_16 2 |
#define | R_SPARC_32 3 |
#define | R_SPARC_DISP8 4 |
#define | R_SPARC_DISP16 5 |
#define | R_SPARC_DISP32 6 |
#define | R_SPARC_WDISP30 7 |
#define | R_SPARC_WDISP22 8 |
#define | R_SPARC_HI22 9 |
#define | R_SPARC_22 10 |
#define | R_SPARC_13 11 |
#define | R_SPARC_LO10 12 |
#define | R_SPARC_GOT10 13 |
#define | R_SPARC_GOT13 14 |
#define | R_SPARC_GOT22 15 |
#define | R_SPARC_PC10 16 |
#define | R_SPARC_PC22 17 |
#define | R_SPARC_WPLT30 18 |
#define | R_SPARC_COPY 19 |
#define | R_SPARC_GLOB_DAT 20 |
#define | R_SPARC_JMP_SLOT 21 |
#define | R_SPARC_RELATIVE 22 |
#define | R_SPARC_UA32 23 |
#define | R_SPARC_PLT32 24 |
#define | R_SPARC_HIPLT22 25 |
#define | R_SPARC_LOPLT10 26 |
#define | R_SPARC_PCPLT32 27 |
#define | R_SPARC_PCPLT22 28 |
#define | R_SPARC_PCPLT10 29 |
#define | R_SPARC_10 30 |
#define | R_SPARC_11 31 |
#define | R_SPARC_64 32 |
#define | R_SPARC_OLO10 33 |
#define | R_SPARC_HH22 34 |
#define | R_SPARC_HM10 35 |
#define | R_SPARC_LM22 36 |
#define | R_SPARC_PC_HH22 37 |
#define | R_SPARC_PC_HM10 38 |
#define | R_SPARC_PC_LM22 39 |
#define | R_SPARC_WDISP16 40 |
#define | R_SPARC_WDISP19 41 |
#define | R_SPARC_GLOB_JMP 42 |
#define | R_SPARC_7 43 |
#define | R_SPARC_5 44 |
#define | R_SPARC_6 45 |
#define | R_SPARC_TLS_GD_HI22 56 |
#define | R_SPARC_TLS_GD_LO10 57 |
#define | R_SPARC_TLS_GD_ADD 58 |
#define | R_SPARC_TLS_GD_CALL 59 |
#define | R_SPARC_TLS_LDM_HI22 60 |
#define | R_SPARC_TLS_LDM_LO10 61 |
#define | R_SPARC_TLS_LDM_ADD 62 |
#define | R_SPARC_TLS_LDM_CALL 63 |
#define | R_SPARC_TLS_LDO_HIX22 64 |
#define | R_SPARC_TLS_LDO_LOX10 65 |
#define | R_SPARC_TLS_LDO_ADD 66 |
#define | R_SPARC_TLS_IE_HI22 67 |
#define | R_SPARC_TLS_IE_LO10 68 |
#define | R_SPARC_TLS_IE_LD 69 |
#define | R_SPARC_TLS_IE_LDX 70 |
#define | R_SPARC_TLS_IE_ADD 71 |
#define | R_SPARC_TLS_LE_HIX22 72 |
#define | R_SPARC_TLS_LE_LOX10 73 |
#define | R_SPARC_TLS_DTPMOD32 74 |
#define | R_SPARC_TLS_DTPMOD64 75 |
#define | R_SPARC_TLS_DTPOFF32 76 |
#define | R_SPARC_TLS_DTPOFF64 77 |
#define | R_SPARC_TLS_TPOFF32 78 |
#define | R_SPARC_TLS_TPOFF64 79 |
#define | R_TYPE(name) __CONCAT(R_SPARC_,name) |
◆ ELF32_MACHDEP_ID_CASES
| #define ELF32_MACHDEP_ID_CASES |
Value:case EM_SPARC: \
case EM_SPARC32PLUS: \
break;
◆ ELF64_MACHDEP_ID_CASES
| #define ELF64_MACHDEP_ID_CASES |
Value:case EM_SPARC32PLUS: \
case EM_SPARCV9: \
