cpu.h
1
10 /*
11  * COPYRIGHT (c) 1989-2006.
12  * On-Line Applications Research Corporation (OAR).
13  *
14  * The license and distribution terms for this file may be
15  * found in the file LICENSE in this distribution or at
16  * http://www.rtems.org/license/LICENSE.
17  */
18
19 #ifndef _RTEMS_SCORE_CPU_H
20 #define _RTEMS_SCORE_CPU_H
21
22 #ifdef __cplusplus
23 extern "C" {
24 #endif
25
26 #include <rtems/score/types.h>
27 #include <rtems/score/h8300.h>
28 #ifndef ASM
29  #include <rtems/bspIo.h>
30 #endif
31
32 /* conditional compilation parameters */
33
34 /*
35  * Should the calls to _Thread_Enable_dispatch be inlined?
36  *
37  * If TRUE, then they are inlined.
38  * If FALSE, then a subroutine call is made.
39  *
40  * Basically this is an example of the classic trade-off of size
41  * versus speed. Inlining the call (TRUE) typically increases the
42  * size of RTEMS while speeding up the enabling of dispatching.
43  * [NOTE: In general, the _Thread_Dispatch_disable_level will
44  * only be 0 or 1 unless you are in an interrupt handler and that
45  * interrupt handler invokes the executive.] When not inlined
46  * something calls _Thread_Enable_dispatch which in turns calls
47  * _Thread_Dispatch. If the enable dispatch is inlined, then
48  * one subroutine call is avoided entirely.]
49  *
50  * H8300 Specific Information:
51  *
52  * XXX
53  */
54
55 #define CPU_INLINE_ENABLE_DISPATCH FALSE
56
57 /*
58  * Should this target use 16 or 32 bit object Ids?
59  *
60  */
61 #define RTEMS_USE_16_BIT_OBJECT
62
63 /*
64  * Does RTEMS manage a dedicated interrupt stack in software?
65  *
66  * If TRUE, then a stack is allocated in _ISR_Handler_initialization.
67  * If FALSE, nothing is done.
68  *
69  * If the CPU supports a dedicated interrupt stack in hardware,
70  * then it is generally the responsibility of the BSP to allocate it
71  * and set it up.
72  *
73  * If the CPU does not support a dedicated interrupt stack, then
74  * the porter has two options: (1) execute interrupts on the
75  * stack of the interrupted task, and (2) have RTEMS manage a dedicated
76  * interrupt stack.
77  *
78  * If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
79  *
80  * Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
81  * CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE. It is
82  * possible that both are FALSE for a particular CPU. Although it
83  * is unclear what that would imply about the interrupt processing
84  * procedure on that CPU.
85  *
86  * H8300 Specific Information:
87  *
88  * XXX
89  */
90
91 #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
92
93 /*
94  * Does the CPU follow the simple vectored interrupt model?
95  *
96  * If TRUE, then RTEMS allocates the vector table it internally manages.
97  * If FALSE, then the BSP is assumed to allocate and manage the vector
98  * table
99  *
100  * H8300 Specific Information:
101  *
102  * XXX document implementation including references if appropriate
103  */
104 #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
105
106 /*
107  * Does this CPU have hardware support for a dedicated interrupt stack?
108  *
109  * If TRUE, then it must be installed during initialization.
110  * If FALSE, then no installation is performed.
111  *
112  * If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
113  *
114  * Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
115  * CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE. It is
116  * possible that both are FALSE for a particular CPU. Although it
117  * is unclear what that would imply about the interrupt processing
118  * procedure on that CPU.
119  *
120  * H8300 Specific Information:
121  *
122  * XXX
123  */
124
125 #define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
126
127 /*
128  * Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
129  *
130  * If TRUE, then the memory is allocated during initialization.
131  * If FALSE, then the memory is allocated during initialization.
132  *
133  * This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
134  *
135  * H8300 Specific Information:
136  *
137  * XXX
138  */
139
140 #define CPU_ALLOCATE_INTERRUPT_STACK TRUE
141
142 /*
143  * Does the CPU have hardware floating point?
144  *
145  * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
146  * If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
147  *
148  * If there is a FP coprocessor such as the i387 or mc68881, then
149  * the answer is TRUE.
150  *
151  * The macro name "H8300_HAS_FPU" should be made CPU specific.
152  * It indicates whether or not this CPU model has FP support. For
153  * example, it would be possible to have an i386_nofp CPU model
154  * which set this to false to indicate that you have an i386 without
155  * an i387 and wish to leave floating point support out of RTEMS.
156  *
157  * H8300 Specific Information:
158  *
159  * XXX
160  */
161
162 #define CPU_HARDWARE_FP FALSE
163
164 /*
165  * Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
166  *
167  * If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
168  * If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
169  *
170  * If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
171  *
172  * H8300 Specific Information:
173  *
174  * XXX
175  */
176
177 #define CPU_ALL_TASKS_ARE_FP FALSE
178
179 /*
180  * Should the IDLE task have a floating point context?
181  *
182  * If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
183  * and it has a floating point context which is switched in and out.
184  * If FALSE, then the IDLE task does not have a floating point context.
185  *
186  * Setting this to TRUE negatively impacts the time required to preempt
187  * the IDLE task from an interrupt because the floating point context
188  * must be saved as part of the preemption.
189  *
190  * H8300 Specific Information:
191  *
192  * XXX
193  */
194
195 #define CPU_IDLE_TASK_IS_FP FALSE
196
197 /*
198  * Should the saving of the floating point registers be deferred
199  * until a context switch is made to another different floating point
200  * task?
201  *
202  * If TRUE, then the floating point context will not be stored until
203  * necessary. It will remain in the floating point registers and not
204  * disturned until another floating point task is switched to.
205  *
206  * If FALSE, then the floating point context is saved when a floating
207  * point task is switched out and restored when the next floating point
208  * task is restored. The state of the floating point registers between
209  * those two operations is not specified.
210  *
211  * If the floating point context does NOT have to be saved as part of
212  * interrupt dispatching, then it should be safe to set this to TRUE.
213  *
214  * Setting this flag to TRUE results in using a different algorithm
215  * for deciding when to save and restore the floating point context.
216  * The deferred FP switch algorithm minimizes the number of times
217  * the FP context is saved and restored. The FP context is not saved
218  * until a context switch is made to another, different FP task.
219  * Thus in a system with only one FP task, the FP context will never
220  * be saved or restored.
221  *
222  * H8300 Specific Information:
223  *
224  * XXX
225  */
226
227 #define CPU_USE_DEFERRED_FP_SWITCH TRUE
228
229 /*
230  * Does this port provide a CPU dependent IDLE task implementation?
231  *
232  * If TRUE, then the routine _CPU_Internal_threads_Idle_thread_body
233  * must be provided and is the default IDLE thread body instead of
234  * _Internal_threads_Idle_thread_body.
235  *
236  * If FALSE, then use the generic IDLE thread body if the BSP does
237  * not provide one.
238  *
239  * This is intended to allow for supporting processors which have
240  * a low power or idle mode. When the IDLE thread is executed, then
241  * the CPU can be powered down.
242  *
243  * The order of precedence for selecting the IDLE thread body is:
244  *
245  * 1. BSP provided
246  * 2. CPU dependent (if provided)
247  * 3. generic (if no BSP and no CPU dependent)
248  *
249  * H8300 Specific Information:
250  *
251  * XXX
252  * The port initially called a BSP dependent routine called
253  * IDLE_Monitor. The idle task body can be overridden by
254  * the BSP in newer versions of RTEMS.
255  */
256
257 #define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
258
259 /*
260  * Does the stack grow up (toward higher addresses) or down
261  * (toward lower addresses)?
262  *
263  * If TRUE, then the grows upward.
264  * If FALSE, then the grows toward smaller addresses.
265  *
266  * H8300 Specific Information:
267  *
268  * XXX
269  */
270
271 #define CPU_STACK_GROWS_UP FALSE
272
273 /*
274  * The following is the variable attribute used to force alignment
275  * of critical RTEMS structures. On some processors it may make
276  * sense to have these aligned on tighter boundaries than
277  * the minimum requirements of the compiler in order to have as
278  * much of the critical data area as possible in a cache line.
279  *
280  * The placement of this macro in the declaration of the variables
281  * is based on the syntactically requirements of the GNU C
282  * "__attribute__" extension. For example with GNU C, use
283  * the following to force a structures to a 32 byte boundary.
284  *
285  * __attribute__ ((aligned (32)))
286  *
287  * NOTE: Currently only the Priority Bit Map table uses this feature.
288  * To benefit from using this, the data must be heavily
289  * used so it will stay in the cache and used frequently enough
290  * in the executive to justify turning this on.
291  *
292  * H8300 Specific Information:
293  *
294  * XXX
295  */
296
297 #define CPU_STRUCTURE_ALIGNMENT
298
299 #define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
300
301 /*
302  * Define what is required to specify how the network to host conversion
303  * routines are handled.
304  */
305
306 #define CPU_BIG_ENDIAN TRUE
307 #define CPU_LITTLE_ENDIAN FALSE
308
309 /*
310  * The following defines the number of bits actually used in the
311  * interrupt field of the task mode. How those bits map to the
312  * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
313  *
314  * H8300 Specific Information:
315  *
316  * XXX
317  */
318
319 #define CPU_MODES_INTERRUPT_MASK 0x00000001
320
321 #define CPU_PER_CPU_CONTROL_SIZE 0
322
323 /*
324  * Processor defined structures required for cpukit/score.
325  *
326  * H8300 Specific Information:
327  *
328  * XXX
329  */
330
331 /* may need to put some structures here. */
332
333 /*
334  * Contexts
335  *
336  * Generally there are 2 types of context to save.
337  * 1. Interrupt registers to save
338  * 2. Task level registers to save
339  *
340  * This means we have the following 3 context items:
341  * 1. task level context stuff:: Context_Control
342  * 2. floating point task stuff:: Context_Control_fp
343  * 3. special interrupt level context :: Context_Control_interrupt
344  *
345  * On some processors, it is cost-effective to save only the callee
346  * preserved registers during a task context switch. This means
347  * that the ISR code needs to save those registers which do not
348  * persist across function calls. It is not mandatory to make this
349  * distinctions between the caller/callee saves registers for the
350  * purpose of minimizing context saved during task switch and on interrupts.
351  * If the cost of saving extra registers is minimal, simplicity is the
352  * choice. Save the same context on interrupt entry as for tasks in
353  * this case.
354  *
355  * Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
356  * care should be used in designing the context area.
357  *
358  * On some CPUs with hardware floating point support, the Context_Control_fp
359  * structure will not be used or it simply consist of an array of a
360  * fixed number of bytes. This is done when the floating point context
361  * is dumped by a "FP save context" type instruction and the format
362  * is not really defined by the CPU. In this case, there is no need
363  * to figure out the exact format -- only the size. Of course, although
364  * this is enough information for RTEMS, it is probably not enough for
365  * a debugger such as gdb. But that is another problem.
366  *
367  * H8300 Specific Information:
368  *
369  * XXX
370  */
371
372 #ifndef ASM
373
374 typedef struct {
375  /* There is no CPU specific per-CPU state */
376 } CPU_Per_CPU_control;
377
378 #define nogap __attribute__ ((packed))
379
380 typedef struct {
381  uint16_t ccr nogap;
382  void *er7 nogap;
383  void *er6 nogap;
384  uint32_t er5 nogap;
385  uint32_t er4 nogap;
386  uint32_t er3 nogap;
387  uint32_t er2 nogap;
388  uint32_t er1 nogap;
389  uint32_t er0 nogap;
390  uint32_t xxx nogap;
392
393 #define _CPU_Context_Get_SP( _context ) \
394  (_context)->er7
395
396 typedef struct {
397  double some_float_register[2];
399
400 typedef struct {
401  uint32_t special_interrupt_register;
403
404 /*
405  * This variable is optional. It is used on CPUs on which it is difficult
406  * to generate an "uninitialized" FP context. It is filled in by
407  * _CPU_Initialize and copied into the task's FP context area during
408  * _CPU_Context_Initialize.
409  *
410  * H8300 Specific Information:
411  *
412  * XXX
413  */
414
416
417 /*
418  * Nothing prevents the porter from declaring more CPU specific variables.
419  *
420  * H8300 Specific Information:
421  *
422  * XXX
423  */
424
425 /* XXX: if needed, put more variables here */
426
427 /*
428  * The size of the floating point context area. On some CPUs this
429  * will not be a "sizeof" because the format of the floating point
430  * area is not defined -- only the size is. This is usually on
431  * CPUs with a "floating point save context" instruction.
432  *
433  * H8300 Specific Information:
434  *
435  * XXX
436  */
437
438 #define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
439
440 #endif /* ASM */
441
442 /*
443  * Amount of extra stack (above minimum stack size) required by
444  * system initialization thread. Remember that in a multiprocessor
445  * system the system intialization thread becomes the MP server thread.
446  *
447  * H8300 Specific Information:
448  *
449  * It is highly unlikely the H8300 will get used in a multiprocessor system.
450  */
451
452 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
453
454 /*
455  * This defines the number of entries in the ISR_Vector_table managed
456  * by RTEMS.
457  *
458  * H8300 Specific Information:
459  *
460  * XXX
461  */
462
463 #define CPU_INTERRUPT_NUMBER_OF_VECTORS 64
464 #define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
465
466 /*
467  * This is defined if the port has a special way to report the ISR nesting
468  * level. Most ports maintain the variable _ISR_Nest_level.
469  */
470
471 #define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
472
473 /*
474  * Should be large enough to run all RTEMS tests. This ensures
475  * that a "reasonable" small application should not have any problems.
476  *
477  * H8300 Specific Information:
478  *
479  * XXX
480  */
481
482 #define CPU_STACK_MINIMUM_SIZE (1536)
483
484 #if defined(__H8300H__) || defined(__H8300S__) || defined(__H8300SX__)
485  #define CPU_SIZEOF_POINTER 4
486 #else
487  #define CPU_SIZEOF_POINTER 2
488 #endif
489
490 /*
491  * CPU's worst alignment requirement for data types on a byte boundary. This
492  * alignment does not take into account the requirements for the stack.
493  *
494  * H8300 Specific Information:
495  *
496  * XXX
497  */
498
499 #define CPU_ALIGNMENT 8
500
501 /*
502  * This number corresponds to the byte alignment requirement for the
503  * heap handler. This alignment requirement may be stricter than that
504  * for the data types alignment specified by CPU_ALIGNMENT. It is
505  * common for the heap to follow the same alignment requirement as
506  * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
507  * then this should be set to CPU_ALIGNMENT.
508  *
509  * NOTE: This does not have to be a power of 2. It does have to
510  * be greater or equal to than CPU_ALIGNMENT.
511  *
512  * H8300 Specific Information:
513  *
514  * XXX
515  */
516
517 #define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
518
519 /*
520  * This number corresponds to the byte alignment requirement for memory
521  * buffers allocated by the partition manager. This alignment requirement
522  * may be stricter than that for the data types alignment specified by
523  * CPU_ALIGNMENT. It is common for the partition to follow the same
524  * alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict
525  * enough for the partition, then this should be set to CPU_ALIGNMENT.
526  *
527  * NOTE: This does not have to be a power of 2. It does have to
528  * be greater or equal to than CPU_ALIGNMENT.
529  *
530  * H8300 Specific Information:
531  *
532  * XXX
533  */
534
535 #define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
536
537 /*
538  * This number corresponds to the byte alignment requirement for the
539  * stack. This alignment requirement may be stricter than that for the
540  * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
541  * is strict enough for the stack, then this should be set to 0.
542  *
543  * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
544  *
545  * H8300 Specific Information:
546  *
547  * XXX
548  */
549
550 #define CPU_STACK_ALIGNMENT 2
551
552 /*
553  * ISR handler macros
554  */
555
556 /*
557  * Support routine to initialize the RTEMS vector table after it is allocated.
558  */
559
560 #define _CPU_Initialize_vectors()
561
562 /* COPE With Brain dead version of GCC distributed with Hitachi HIView Tools.
563  Note requires ISR_Level be uint16_t or assembler croaks.
564 */
565
566 #if (__GNUC__ == 2 && __GNUC_MINOR__ == 7 )
567
568
569 /*
570  * Disable all interrupts for an RTEMS critical section. The previous
571  * level is returned in _level.
572  */
573
574 #define _CPU_ISR_Disable( _isr_cookie ) \
575  do { \
576  __asm__ volatile( "stc.w ccr, @-er7 ;\n orc #0xC0,ccr ;\n mov.w @er7+,%0" : : "r" (_isr_cookie) ); \
577  } while (0)
578
579
580 /*
581  * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
582  * This indicates the end of an RTEMS critical section. The parameter
583  * _level is not modified.
584  */
585
586
587 #define _CPU_ISR_Enable( _isr_cookie ) \
588  do { \
589  __asm__ volatile( "mov.w %0,@-er7 ;\n ldc.w @er7+, ccr" : : "r" (_isr_cookie) ); \
590  } while (0)
591
592
593 /*
594  * This temporarily restores the interrupt to _level before immediately
595  * disabling them again. This is used to divide long RTEMS critical
596  * sections into two or more parts. The parameter _level is not
597  * modified.
598  */
599
600
601 #define _CPU_ISR_Flash( _isr_cookie ) \
602  do { \
603  __asm__ volatile( "mov.w %0,@-er7 ;\n ldc.w @er7+, ccr ;\n orc #0xC0,ccr" : : "r" (_isr_cookie) ); \
604  } while (0)
605
606 /* end of ISR handler macros */
607
608 #else /* modern gcc version */
609
610 /*
611  * Disable all interrupts for an RTEMS critical section. The previous
612  * level is returned in _level.
613  *
614  * H8300 Specific Information:
615  *
616  * TODO: As of 8 October 2014, this method is not implemented for the SX.
617  */
618
619 #if defined(__H8300H__) || defined(__H8300S__)
620 #define _CPU_ISR_Disable( _isr_cookie ) \
621  do { \
622  unsigned char __ccr; \
623  __asm__ volatile( "stc ccr, %0 ; orc #0x80,ccr " \
624  : "=m" (__ccr) /* : "0" (__ccr) */ ); \
625  (_isr_cookie) = __ccr; \
626  } while (0)
627 #else
628 #define _CPU_ISR_Disable( _isr_cookie ) \
629  do { \
630  (_isr_cookie) = 0; \
631  } while (0)
632 #endif
633
634
635 /*
636  * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
637  * This indicates the end of an RTEMS critical section. The parameter
638  * _level is not modified.
639  *
640  * H8300 Specific Information:
641  *
642  * TODO: As of 8 October 2014, this method is not implemented for the SX.
643  */
644
645 #if defined(__H8300H__) || defined(__H8300S__)
646 #define _CPU_ISR_Enable( _isr_cookie ) \
647  do { \
648  unsigned char __ccr = (unsigned char) (_isr_cookie); \
649  __asm__ volatile( "ldc %0, ccr" : : "m" (__ccr) ); \
650  } while (0)
651 #else
652 #define _CPU_ISR_Enable( _isr_cookie ) \
653  do { \
654  (_isr_cookie) = (_isr_cookie); \
655  } while (0)
656 #endif
657
658 /*
659  * This temporarily restores the interrupt to _level before immediately
660  * disabling them again. This is used to divide long RTEMS critical
661  * sections into two or more parts. The parameter _level is not
662  * modified.
663  *
664  * H8300 Specific Information:
665  *
666  * TODO: As of 8 October 2014, this method is not implemented for the SX.
667  */
668
669 #if defined(__H8300H__) || defined(__H8300S__)
670 #define _CPU_ISR_Flash( _isr_cookie ) \
671  do { \
672  unsigned char __ccr = (unsigned char) (_isr_cookie); \
673  __asm__ volatile( "ldc %0, ccr ; orc #0x80,ccr " : : "m" (__ccr) ); \
674  } while (0)
675 #else
676 #define _CPU_ISR_Flash( _isr_cookie ) \
677  do { \
678  _CPU_ISR_Enable( _isr_cookie ); \
679  _CPU_ISR_Disable( _isr_cookie ); \
680  } while (0)
681 #endif
682
683 #endif /* end of old gcc */
684
685
686 /*
687  * Map interrupt level in task mode onto the hardware that the CPU
688  * actually provides. Currently, interrupt levels which do not
689  * map onto the CPU in a generic fashion are undefined. Someday,
690  * it would be nice if these were "mapped" by the application
691  * via a callout. For example, m68k has 8 levels 0 - 7, levels
692  * 8 - 255 would be available for bsp/application specific meaning.
693  * This could be used to manage a programmable interrupt controller
694  * via the rtems_task_mode directive.
695  *
696  * H8300 Specific Information:
697  *
698  * XXX
699  */
700
701 #define _CPU_ISR_Set_level( _new_level ) \
702  { \
703  if ( _new_level ) __asm__ volatile ( "orc #0x80,ccr\n" ); \
704  else __asm__ volatile ( "andc #0x7f,ccr\n" ); \
705  }
706
707 #ifndef ASM
708
709 uint32_t _CPU_ISR_Get_level( void );
710
711 /* end of ISR handler macros */
712
713 /* Context handler macros */
714
715 /*
716  * Initialize the context to a state suitable for starting a
717  * task after a context restore operation. Generally, this
718  * involves:
719  *
720  * - setting a starting address
721  * - preparing the stack
722  * - preparing the stack and frame pointers
723  * - setting the proper interrupt level in the context
724  * - initializing the floating point context
725  *
726  * This routine generally does not set any unnecessary register
727  * in the context. The state of the "general data" registers is
728  * undefined at task start time.
729  *
730  * NOTE: This is_fp parameter is TRUE if the thread is to be a floating
731  * point thread. This is typically only used on CPUs where the
732  * FPU may be easily disabled by software such as on the SPARC
733  * where the PSR contains an enable FPU bit.
734  *
735  * H8300 Specific Information:
736  *
737  * XXX
738  */
739
740
741 #define CPU_CCR_INTERRUPTS_ON 0x80
742 #define CPU_CCR_INTERRUPTS_OFF 0x00
743
744 #define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
745  _isr, _entry_point, _is_fp, _tls_area ) \
746  /* Locate Me */ \
747  do { \
748  uintptr_t _stack; \
749  \
750  if ( (_isr) ) (_the_context)->ccr = CPU_CCR_INTERRUPTS_OFF; \
751  else (_the_context)->ccr = CPU_CCR_INTERRUPTS_ON; \
752  \
753  (void) _is_fp; /* to eliminate set but not used warning */ \
754  _stack = ((uintptr_t)(_stack_base)) + (_size) - 4; \
755  *((proc_ptr *)(_stack)) = (_entry_point); \
756  (_the_context)->er7 = (void *) _stack; \
757  (_the_context)->er6 = (void *) _stack; \
758  (_the_context)->er5 = 0; \
759  (_the_context)->er4 = 1; \
760  (_the_context)->er3 = 2; \
761  } while (0)
762
763
764 /*
765  * This routine is responsible for somehow restarting the currently
766  * executing task. If you are lucky, then all that is necessary
767  * is restoring the context. Otherwise, there will need to be
768  * a special assembly routine which does something special in this
769  * case. Context_Restore should work most of the time. It will
770  * not work if restarting self conflicts with the stack frame
771  * assumptions of restoring a context.
772  *
773  * H8300 Specific Information:
774  *
775  * XXX
776  */
777
778 #define _CPU_Context_Restart_self( _the_context ) \
779  _CPU_Context_restore( (_the_context) );
780
781 /*
782  * The purpose of this macro is to allow the initial pointer into
783  * a floating point context area (used to save the floating point
784  * context) to be at an arbitrary place in the floating point
785  * context area.
786  *
787  * This is necessary because some FP units are designed to have
788  * their context saved as a stack which grows into lower addresses.
789  * Other FP units can be saved by simply moving registers into offsets
790  * from the base of the context area. Finally some FP units provide
791  * a "dump context" instruction which could fill in from high to low
792  * or low to high based on the whim of the CPU designers.
793  *
794  * H8300 Specific Information:
795  *
796  * XXX
797  */
798
799 #define _CPU_Context_Fp_start( _base, _offset ) \
800  ( (void *) (_base) + (_offset) )
801
802 /*
803  * This routine initializes the FP context area passed to it to.
804  * There are a few standard ways in which to initialize the
805  * floating point context. The code included for this macro assumes
806  * that this is a CPU in which a "initial" FP context was saved into
807  * _CPU_Null_fp_context and it simply copies it to the destination
808  * context passed to it.
809  *
810  * Other models include (1) not doing anything, and (2) putting
811  * a "null FP status word" in the correct place in the FP context.
812  *
813  * H8300 Specific Information:
814  *
815  * XXX
816  */
817
818 #define _CPU_Context_Initialize_fp( _destination ) \
819  { \
820  *(*(_destination)) = _CPU_Null_fp_context; \
821  }
822
823 /* end of Context handler macros */
824
825 /* Fatal Error manager macros */
826
827 /*
828  * This routine copies _error into a known place -- typically a stack
829  * location or a register, optionally disables interrupts, and
830  * halts/stops the CPU.
831  *
832  * H8300 Specific Information:
833  *
834  * XXX
835  */
836
837 #define _CPU_Fatal_halt( _source, _error ) \
838  printk("Fatal Error %d.%d Halted\n",_source, _error); \
839  for(;;)
840
841
842 /* end of Fatal Error manager macros */
843
844 /* Bitfield handler macros */
845
846 /*
847  * This routine sets _output to the bit number of the first bit
848  * set in _value. _value is of CPU dependent type Priority_bit_map_Word.
849  * This type may be either 16 or 32 bits wide although only the 16
850  * least significant bits will be used.
851  *
852  * There are a number of variables in using a "find first bit" type
853  * instruction.
854  *
855  * (1) What happens when run on a value of zero?
856  * (2) Bits may be numbered from MSB to LSB or vice-versa.
857  * (3) The numbering may be zero or one based.
858  * (4) The "find first bit" instruction may search from MSB or LSB.
859  *
860  * RTEMS guarantees that (1) will never happen so it is not a concern.
861  * (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
862  * _CPU_Priority_bits_index(). These three form a set of routines
863  * which must logically operate together. Bits in the _value are
864  * set and cleared based on masks built by _CPU_Priority_mask().
865  * The basic major and minor values calculated by _Priority_Major()
866  * and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
867  * to properly range between the values returned by the "find first bit"
868  * instruction. This makes it possible for _Priority_Get_highest() to
869  * calculate the major and directly index into the minor table.
870  * This mapping is necessary to ensure that 0 (a high priority major/minor)
871  * is the first bit found.
872  *
873  * This entire "find first bit" and mapping process depends heavily
874  * on the manner in which a priority is broken into a major and minor
875  * components with the major being the 4 MSB of a priority and minor
876  * the 4 LSB. Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
877  * priority. And (15 << 4) + 14 corresponds to priority 254 -- the next
878  * to the lowest priority.
879  *
880  * If your CPU does not have a "find first bit" instruction, then
881  * there are ways to make do without it. Here are a handful of ways
882  * to implement this in software:
883  *
884  * - a series of 16 bit test instructions
885  * - a "binary search using if's"
886  * - _number = 0
887  * if _value > 0x00ff
888  * _value >>=8
889  * _number = 8;
890  *
891  * if _value > 0x0000f
892  * _value >=8
893  * _number += 4
894  *
895  * _number += bit_set_table[ _value ]
896  *
897  * where bit_set_table[ 16 ] has values which indicate the first
898  * bit set
899  *
900  * H8300 Specific Information:
901  *
902  * XXX
903  */
904
905 #define CPU_USE_GENERIC_BITFIELD_CODE TRUE
906 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
907
908 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
909
910 #define _CPU_Bitfield_Find_first_bit( _value, _output ) \
911  { \
912  (_output) = 0; /* do something to prevent warnings */ \
913  }
914
915 #endif
916
917 /* end of Bitfield handler macros */
918
919 /*
920  * This routine builds the mask which corresponds to the bit fields
921  * as searched by _CPU_Bitfield_Find_first_bit(). See the discussion
922  * for that routine.
923  *
924  * H8300 Specific Information:
925  *
926  * XXX
927  */
928
929 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
930
931 #define _CPU_Priority_Mask( _bit_number ) \
932  ( 1 << (_bit_number) )
933
934 #endif
935
936 /*
937  * This routine translates the bit numbers returned by
938  * _CPU_Bitfield_Find_first_bit() into something suitable for use as
939  * a major or minor component of a priority. See the discussion
940  * for that routine.
941  *
942  * H8300 Specific Information:
943  *
944  * XXX
945  */
946
947 #if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
948
949 #define _CPU_Priority_bits_index( _priority ) \
950  (_priority)
951
952 #endif
953
954 /* end of Priority handler macros */
955
956 /* functions */
957
958 /*
959  * _CPU_Initialize
960  *
961  * This routine performs CPU dependent initialization.
962  *
963  * H8300 Specific Information:
964  *
965  * XXX
966  */
967
968 void _CPU_Initialize(void);
969
970 /*
971  * _CPU_ISR_install_raw_handler
972  *
973  * This routine installs a "raw" interrupt handler directly into the
974  * processor's vector table.
975  *
976  * H8300 Specific Information:
977  *
978  * XXX
979  */
980
982  uint32_t vector,
983  proc_ptr new_handler,
984  proc_ptr *old_handler
985 );
986
987 /*
988  * _CPU_ISR_install_vector
989  *
990  * This routine installs an interrupt vector.
991  *
992  * H8300 Specific Information:
993  *
994  * XXX
995  */
996
998  uint32_t vector,
999  proc_ptr new_handler,
1000  proc_ptr *old_handler
1001 );
1002
1003 /*
1004  * _CPU_Install_interrupt_stack
1005  *
1006  * This routine installs the hardware interrupt stack pointer.
1007  *
1008  * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
1009  * is TRUE.
1010  *
1011  * H8300 Specific Information:
1012  *
1013  * XXX
1014  */
1015
1016 void _CPU_Install_interrupt_stack( void );
1017
1018 /*
1019  * _CPU_Internal_threads_Idle_thread_body
1020  *
1021  * This routine is the CPU dependent IDLE thread body.
1022  *
1023  * NOTE: It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
1024  * is TRUE.
1025  *
1026  * H8300 Specific Information:
1027  *
1028  * XXX
1029  */
1030
1031 void *_CPU_Thread_Idle_body( uint32_t );
1032
1033 /*
1034  * _CPU_Context_switch
1035  *
1036  * This routine switches from the run context to the heir context.
1037  *
1038  * H8300 Specific Information:
1039  *
1040  * XXX
1041  */
1042
1043 void _CPU_Context_switch(
1044  Context_Control *run,
1045  Context_Control *heir
1046 );
1047
1048 /*
1049  * _CPU_Context_restore
1050  *
1051  * This routine is generallu used only to restart self in an
1052  * efficient manner. It may simply be a label in _CPU_Context_switch.
1053  *
1054  * NOTE: May be unnecessary to reload some registers.
1055  *
1056  * H8300 Specific Information:
1057  *
1058  * XXX
1059  */
1060
1062  Context_Control *new_context
1064
1065 /*
1066  * _CPU_Context_save_fp
1067  *
1068  * This routine saves the floating point context passed to it.
1069  *
1070  * H8300 Specific Information:
1071  *
1072  * XXX
1073  */
1074
1076  Context_Control_fp **fp_context_ptr
1077 );
1078
1079 /*
1080  * _CPU_Context_restore_fp
1081  *
1082  * This routine restores the floating point context passed to it.
1083  *
1084  * H8300 Specific Information:
1085  *
1086  * XXX
1087  */
1088
1090  Context_Control_fp **fp_context_ptr
1091 );
1092
1093 static inline void _CPU_Context_volatile_clobber( uintptr_t pattern )
1094 {
1095  /* TODO */
1096 }
1097
1098 static inline void _CPU_Context_validate( uintptr_t pattern )
1099 {
1100  while (1) {
1101  /* TODO */
1102  }
1103 }
1104
1105 /* FIXME */
1106 typedef CPU_Interrupt_frame CPU_Exception_frame;
1107
1108 void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
1109
1110 /* The following routine swaps the endian format of an unsigned int.
1111  * It must be static because it is referenced indirectly.
1112  *
1113  * This version will work on any processor, but if there is a better
1114  * way for your CPU PLEASE use it. The most common way to do this is to:
1115  *
1116  * swap least significant two bytes with 16-bit rotate
1117  * swap upper and lower 16-bits
1118  * swap most significant two bytes with 16-bit rotate
1119  *
1120  * Some CPUs have special instructions which swap a 32-bit quantity in
1121  * a single instruction (e.g. i486). It is probably best to avoid
1122  * an "endian swapping control bit" in the CPU. One good reason is
1123  * that interrupts would probably have to be disabled to ensure that
1124  * an interrupt does not try to access the same "chunk" with the wrong
1125  * endian. Another good reason is that on some CPUs, the endian bit
1126  * endianness for ALL fetches -- both code and data -- so the code
1127  * will be fetched incorrectly.
1128  *
1129  * H8300 Specific Information:
1130  *
1131  * This is the generic implementation.
1132  */
1133
1134 static inline uint32_t CPU_swap_u32(
1135  uint32_t value
1136 )
1137 {
1138  uint32_t byte1, byte2, byte3, byte4, swapped;
1139
1140  byte4 = (value >> 24) & 0xff;
1141  byte3 = (value >> 16) & 0xff;
1142  byte2 = (value >> 8) & 0xff;
1143  byte1 = value & 0xff;
1144
1145  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
1146  return( swapped );
1147 }
1148
1149 #define CPU_swap_u16( value ) \
1150  (((value&0xff) << 8) | ((value >> 8)&0xff))
1151
1152 typedef uint32_t CPU_Counter_ticks;
1153
1154 CPU_Counter_ticks _CPU_Counter_read( void );
1155
1156 static inline CPU_Counter_ticks _CPU_Counter_difference(
1157  CPU_Counter_ticks second,
1158  CPU_Counter_ticks first
1159 )
1160 {
1161  return second - first;
1162 }
1163
1164 /* to be provided by the BSP */
1165 extern void H8BD_Install_IRQ(
1166  uint32_t vector,
1167  proc_ptr new_handler,
1168  proc_ptr *old_handler );
1169
1170 #endif /* ASM */
1171
1172 #ifdef __cplusplus
1173 }
1174 #endif
1175
1176 #endif
void _CPU_ISR_install_vector(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
Definition: cpu.c:69
void _CPU_Context_validate(uintptr_t pattern)
Initializes and validates the CPU context with values derived from the pattern parameter.
Definition: cpu.h:1109
uint32_t _CPU_ISR_Get_level(void)
Return the current interrupt disable level for this task in the format used by the interrupt level po...
Definition: cpu.c:39
void _CPU_Context_restore(Context_Control *new_context)
This routine is generally used only to restart self in an efficient manner.
Definition: cpu_asm.c:112
void _CPU_Context_switch(Context_Control *run, Context_Control *heir)
CPU switch context.
Definition: cpu_asm.c:92
void _CPU_Context_volatile_clobber(uintptr_t pattern)
Clobbers all volatile registers with values derived from the pattern parameter.
Definition: cpu.h:1104
Information Required to Build RTEMS for a Particular Member of the Hitachi H8/300 Family...
This defines the minimal set of integer and processor state registers that must be saved during a vol...
Definition: cpu.h:248
CPU initialization.
Definition: cpu.c:26
void _CPU_Install_interrupt_stack(void)
Definition: cpu.c:101
SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context
Definition: cpu.h:494
Unsigned integer type for CPU counter values.
Definition: cpu.h:1461
This defines the set of integer and processor state registers that must be saved during an interrupt...
Definition: cpu.h:425
void _CPU_ISR_install_raw_handler(uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
This routine installs a "raw" interrupt handler directly into the processor&#39;s vector table...
Definition: cpu.c:57
void _CPU_Context_restore_fp(Context_Control_fp **fp_context_ptr)
Definition: cpu.c:176
CPU_Counter_ticks _CPU_Counter_read(void)
Returns the current CPU counter value.
Definition: cpu.c:96
CPU_Counter_ticks _CPU_Counter_difference(CPU_Counter_ticks second, CPU_Counter_ticks first)
Returns the difference between the second and first CPU counter value.
Definition: cpu.h:1160
This defines the complete set of floating point registers that must be saved during any context switc...
Definition: cpu.h:294
Interface to Kernel Print Methods.
void _CPU_Context_save_fp(Context_Control_fp **fp_context_ptr)
Definition: cpu.c:167
#define RTEMS_COMPILER_NO_RETURN_ATTRIBUTE
The following macro is a compiler specific way to indicate that the method will NOT return to the cal...
Definition: basedefs.h:162
void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
Prints the exception frame via printk().
Definition: arm-exception-frame-print.c:46
void * _CPU_Thread_Idle_body(uintptr_t ignored)
Definition: cpu.c:125
#define SCORE_EXTERN
The following ensures that all data is declared in the space of the initialization routine for either...
Definition: basedefs.h:81
void * proc_ptr
XXX: Eventually proc_ptr needs to disappear!!!
Definition: basedefs.h:329
