Maps Blocks to the Media Interface Layers. More...
#include <errno.h>#include <rtems/rfs/rtems-rfs-file-system-fwd.h>#include <rtems/rfs/rtems-rfs-trace.h>
| struct | _rtems_rfs_buffer |
| struct | rtems_rfs_buffer_handle_t |
| RFS Buffer handle. More... | |
| #define | rtems_rfs_buffer_io_request rtems_rfs_buffer_deviceio_request |
| #define | rtems_rfs_buffer_io_release rtems_rfs_buffer_deviceio_release |
| #define | rtems_rfs_buffer_link(_h) (&(_h)->buffer->link) |
| The buffer linkage. | |
| #define | rtems_rfs_buffer_data(_h) ((void*)((_h)->buffer->buffer)) |
| Return the start of the data area of the buffer given a handle. | |
| #define | rtems_rfs_buffer_size(_h) ((_h)->buffer->size) |
| Return the size of the buffer given a handle. | |
| #define | rtems_rfs_buffer_bnum(_h) ((_h)->bnum) |
| Return the block number. | |
| #define | rtems_rfs_buffer_dirty(_h) ((_h)->dirty) |
| Return the buffer dirty status. | |
| #define | rtems_rfs_buffer_handle_has_block(_h) ((_h)->buffer ? true : false) |
| Does the handle have a valid block attached ? | |
| #define | rtems_rfs_buffer_mark_dirty(_h) ((_h)->dirty = true) |
| Mark the buffer as dirty. | |
| #define | rtems_rfs_buffer_refs(_h) ((_h)->buffer->references) |
| Return the reference count. | |
| #define | rtems_rfs_buffer_refs_up(_h) ((_h)->buffer->references += 1) |
| Increment the reference count. | |
| #define | rtems_rfs_buffer_refs_down(_h) ((_h)->buffer->references -= 1) |
| Decrement the reference count. | |
Typedefs | |
| typedef uint32_t | rtems_rfs_buffer_block |
| Define the method used to interface to the buffers. More... | |
| typedef struct _rtems_rfs_buffer | rtems_rfs_buffer |
| typedef struct rtems_rfs_buffer_handle_t | rtems_rfs_buffer_handle |
| RFS Buffer handle. | |
These functions map blocks to the media interface layers.
| typedef uint32_t rtems_rfs_buffer_block |
It can be libblock or device I/O. The libblock interface is to the RTEMS cache and block devices and device I/O accesses the media via a device file handle. The RTEMS RFS I/O Layering.
| int rtems_rfs_buffer_close | ( | rtems_rfs_file_system * | fs | ) |
Close the buffer interface.
| [in] | fs | is the file system data. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_buffer_handle_release | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_buffer_handle * | handle | ||
Release a buffer.
If the buffer is dirty the buffer is written to disk. The result does not indicate if the data was successfully written to the disk as this operation may be performed in asynchronously to this release.
| [in] | handle | is the handle the requested buffer is attached to. |
Referenced by rtems_rfs_file_io_release().
| int rtems_rfs_buffer_handle_request | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_buffer_handle * | handle, | ||
| rtems_rfs_buffer_block | block, | ||
| bool | read | ||
Request a buffer.
The buffer can be filled with data from the media (read == true) or you can request a buffer to fill with data.
| [in] | block | is the block number. |
| [in] | read | Read the data from the disk. |
| int rtems_rfs_buffer_open | ( | const char * | name, |
| rtems_rfs_file_system * | fs | ||
Open the buffer interface.
| [in] | name | is a pointer to the device name to the media. |
| int rtems_rfs_buffer_setblksize | ( | rtems_rfs_file_system * | fs, |
| size_t | size | ||
Set the block size of the device.
| [in] | size | is the new block size. |
| int rtems_rfs_buffer_sync | ( | rtems_rfs_file_system * | fs | ) |
Sync all buffers to the media.
Referenced by rtems_rfs_rtems_fdatasync().
| int rtems_rfs_buffers_release | ( | rtems_rfs_file_system * | fs | ) |
Release any chained buffers.
