libdl
include
arch
mips
machine
elf_machdep.h
1
/* $NetBSD: elf_machdep.h,v 1.15 2011/03/15 07:39:22 matt Exp $ */
2
3
#ifndef _MIPS_ELF_MACHDEP_H_
4
#define _MIPS_ELF_MACHDEP_H_
5
6
#ifdef _LP64
7
#define ARCH_ELFSIZE 64
/* MD native binary size */
8
#else
9
#define ARCH_ELFSIZE 32
10
#endif
11
12
#if ARCH_ELFSIZE == 32
13
#define ELF32_MACHDEP_ID_CASES \
14
case EM_MIPS: \
15
break;
16
17
#define ELF32_MACHDEP_ID EM_MIPS
18
19
#elif ARCH_ELFSIZE == 64
20
#define ELF64_MACHDEP_ID_CASES \
21
case EM_MIPS: \
22
break;
23
24
#define ELF64_MACHDEP_ID EM_MIPS
25
26
#endif
27
28
29
/* mips relocs. */
30
31
#define R_MIPS_NONE 0
32
#define R_MIPS_16 1
33
#define R_MIPS_32 2
34
#define R_MIPS_REL32 3
35
#define R_MIPS_REL R_MIPS_REL32
36
#define R_MIPS_26 4
37
#define R_MIPS_HI16 5
/* high 16 bits of symbol value */
38
#define R_MIPS_LO16 6
/* low 16 bits of symbol value */
39
#define R_MIPS_GPREL16 7
/* GP-relative reference */
40
#define R_MIPS_LITERAL 8
/* Reference to literal section */
41
#define R_MIPS_GOT16 9
/* Reference to global offset table */
42
#define R_MIPS_GOT R_MIPS_GOT16
43
#define R_MIPS_PC16 10
/* 16 bit PC relative reference */
44
#define R_MIPS_CALL16 11
/* 16 bit call thru glbl offset tbl */
45
#define R_MIPS_CALL R_MIPS_CALL16
46
#define R_MIPS_GPREL32 12
47
48
/* 13, 14, 15 are not defined at this point. */
49
#define R_MIPS_UNUSED1 13
50
#define R_MIPS_UNUSED2 14
51
#define R_MIPS_UNUSED3 15
52
53
54
* The remaining relocs are apparently part of the 64-bit Irix ELF ABI.
55
56
#define R_MIPS_SHIFT5 16
57
#define R_MIPS_SHIFT6 17
58
59
#define R_MIPS_64 18
60
#define R_MIPS_GOT_DISP 19
61
#define R_MIPS_GOT_PAGE 20
62
#define R_MIPS_GOT_OFST 21
63
#define R_MIPS_GOT_HI16 22
64
#define R_MIPS_GOT_LO16 23
65
#define R_MIPS_SUB 24
66
#define R_MIPS_INSERT_A 25
67
#define R_MIPS_INSERT_B 26
68
#define R_MIPS_DELETE 27
69
#define R_MIPS_HIGHER 28
70
#define R_MIPS_HIGHEST 29
71
#define R_MIPS_CALL_HI16 30
72
#define R_MIPS_CALL_LO16 31
73
#define R_MIPS_SCN_DISP 32
74
#define R_MIPS_REL16 33
75
#define R_MIPS_ADD_IMMEDIATE 34
76
#define R_MIPS_PJUMP 35
77
#define R_MIPS_RELGOT 36
78
#define R_MIPS_JALR 37
79
/* TLS relocations */
80
81
#define R_MIPS_TLS_DTPMOD32 38
/* Module number 32 bit */
82
#define R_MIPS_TLS_DTPREL32 39
/* Module-relative offset 32 bit */
83
#define R_MIPS_TLS_DTPMOD64 40
/* Module number 64 bit */
84
#define R_MIPS_TLS_DTPREL64 41
/* Module-relative offset 64 bit */
85
#define R_MIPS_TLS_GD 42
/* 16 bit GOT offset for GD */
86
#define R_MIPS_TLS_LDM 43
/* 16 bit GOT offset for LDM */
87
#define R_MIPS_TLS_DTPREL_HI16 44
/* Module-relative offset, high 16 bits */
88
#define R_MIPS_TLS_DTPREL_LO16 45
/* Module-relative offset, low 16 bits */
89
#define R_MIPS_TLS_GOTTPREL 46
/* 16 bit GOT offset for IE */
90
#define R_MIPS_TLS_TPREL32 47
/* TP-relative offset, 32 bit */
91
#define R_MIPS_TLS_TPREL64 48
/* TP-relative offset, 64 bit */
92
#define R_MIPS_TLS_TPREL_HI16 49
/* TP-relative offset, high 16 bits */
93
#define R_MIPS_TLS_TPREL_LO16 50
/* TP-relative offset, low 16 bits */
94
95
#define R_MIPS_max 51
96
97
#define R_TYPE(name) __CONCAT(R_MIPS_,name)
98
99
#define R_MIPS16_min 100
100
#define R_MIPS16_26 100
101
#define R_MIPS16_GPREL 101
102
#define R_MIPS16_GOT16 102
103
#define R_MIPS16_CALL16 103
104
#define R_MIPS16_HI16 104
105
#define R_MIPS16_LO16 105
106
#define R_MIPS16_max 106
107
108
109
/* mips dynamic tags */
110
111
#define DT_MIPS_RLD_VERSION 0x70000001
112
#define DT_MIPS_TIME_STAMP 0x70000002
113
#define DT_MIPS_ICHECKSUM 0x70000003
114
#define DT_MIPS_IVERSION 0x70000004
115
#define DT_MIPS_FLAGS 0x70000005
116
#define DT_MIPS_BASE_ADDRESS 0x70000006
117
#define DT_MIPS_CONFLICT 0x70000008
118
#define DT_MIPS_LIBLIST 0x70000009
119
#define DT_MIPS_CONFLICTNO 0x7000000b
120
#define DT_MIPS_LOCAL_GOTNO 0x7000000a
/* number of local got ents */
121
#define DT_MIPS_LIBLISTNO 0x70000010
122
#define DT_MIPS_SYMTABNO 0x70000011
/* number of .dynsym entries */
123
#define DT_MIPS_UNREFEXTNO 0x70000012
124
#define DT_MIPS_GOTSYM 0x70000013
/* first dynamic sym in got */
125
#define DT_MIPS_HIPAGENO 0x70000014
126
#define DT_MIPS_RLD_MAP 0x70000016
/* address of loader map */
127
128
129
* ELF Flags
130
131
#define EF_MIPS_PIC 0x00000002
/* Contains PIC code */
132
#define EF_MIPS_CPIC 0x00000004
/* STD PIC calling sequence */
133
#define EF_MIPS_ABI2 0x00000020
/* N32 */
134
135
#define EF_MIPS_ARCH_ASE 0x0f000000
/* Architectural extensions */
136
#define EF_MIPS_ARCH_MDMX 0x08000000
/* MDMX multimedia extension */
137
#define EF_MIPS_ARCH_M16 0x04000000
/* MIPS-16 ISA extensions */
138
139
#define EF_MIPS_ARCH 0xf0000000
/* Architecture field */
140
#define EF_MIPS_ARCH_1 0x00000000
/* -mips1 code */
141
#define EF_MIPS_ARCH_2 0x10000000
/* -mips2 code */
142
#define EF_MIPS_ARCH_3 0x20000000
/* -mips3 code */
143
#define EF_MIPS_ARCH_4 0x30000000
/* -mips4 code */
144
#define EF_MIPS_ARCH_5 0x40000000
/* -mips5 code */
145
#define EF_MIPS_ARCH_32 0x50000000
/* -mips32 code */
146
#define EF_MIPS_ARCH_64 0x60000000
/* -mips64 code */
147
#define EF_MIPS_ARCH_32R2 0x70000000
/* -mips32r2 code */
148
#define EF_MIPS_ARCH_64R2 0x80000000
/* -mips64r2 code */
149
150
#define EF_MIPS_ABI 0x0000f000
151
#define EF_MIPS_ABI_O32 0x00001000
152
#define EF_MIPS_ABI_O64 0x00002000
153
#define EF_MIPS_ABI_EABI32 0x00003000
154
#define EF_MIPS_ABI_EABI64 0x00004000
155
156
#if defined(__MIPSEB__)
157
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
158
#define ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB
159
#elif defined(__MIPSEL__)
160
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
161
#define ELF64_MACHDEP_ENDIANNESS ELFDATA2LSB
162
#elif !defined(HAVE_NBTOOL_CONFIG_H)
163
#error neither __MIPSEL__ nor __MIPSEB__ are defined.
164
#endif
165
166
#ifdef _KERNEL
167
#ifdef _KERNEL_OPT
168
#include "opt_compat_netbsd.h"
169
#endif
170
#ifdef COMPAT_16
171
172
* Up to 1.6, the ELF dynamic loader (ld.elf_so) was not relocatable.
173
* Tell the kernel ELF exec code not to try relocating the interpreter
174
* for dynamically-linked ELF binaries.
175
176
#define ELF_INTERP_NON_RELOCATABLE
177
#endif
/* COMPAT_16 */
178
179
180
* We need to be able to include the ELF header so we can pick out the
181
* ABI being used.
182
183
#ifdef ELFSIZE
184
#define ELF_MD_PROBE_FUNC ELFNAME2(mips_netbsd,probe)
185
#define ELF_MD_COREDUMP_SETUP ELFNAME2(coredump,setup)
186
#endif
187
188
struct
exec_package;
189
190
int
mips_netbsd_elf32_probe(
struct
lwp *,
struct
exec_package *,
void
char
191
vaddr_t *);
192
void
coredump_elf32_setup(
struct
lwp *,
void
193
194
int
mips_netbsd_elf64_probe(
struct
lwp *,
struct
exec_package *,
void
char
195
vaddr_t *);
196
void
coredump_elf64_setup(
struct
lwp *,
void
197
#endif
/* _KERNEL */
198
199
#endif
/* _MIPS_ELF_MACHDEP_H_ */
