elf_machdep.h File Reference
#define ARCH_ELFSIZE   32 /* MD native binary size */
#define ELF32_MACHDEP_ID_CASES
#define ELF32_MACHDEP_ID   EM_MIPS
#define R_MIPS_NONE   0
#define R_MIPS_16   1
#define R_MIPS_32   2
#define R_MIPS_REL32   3
#define R_MIPS_REL   R_MIPS_REL32
#define R_MIPS_26   4
#define R_MIPS_HI16   5 /* high 16 bits of symbol value */
#define R_MIPS_LO16   6 /* low 16 bits of symbol value */
#define R_MIPS_GPREL16   7 /* GP-relative reference */
#define R_MIPS_LITERAL   8 /* Reference to literal section */
#define R_MIPS_GOT16   9 /* Reference to global offset table */
#define R_MIPS_GOT   R_MIPS_GOT16
#define R_MIPS_PC16   10 /* 16 bit PC relative reference */
#define R_MIPS_CALL16   11 /* 16 bit call thru glbl offset tbl */
#define R_MIPS_CALL   R_MIPS_CALL16
#define R_MIPS_GPREL32   12
#define R_MIPS_UNUSED1   13
#define R_MIPS_UNUSED2   14
#define R_MIPS_UNUSED3   15
#define R_MIPS_SHIFT5   16
#define R_MIPS_SHIFT6   17
#define R_MIPS_64   18
#define R_MIPS_GOT_DISP   19
#define R_MIPS_GOT_PAGE   20
#define R_MIPS_GOT_OFST   21
#define R_MIPS_GOT_HI16   22
#define R_MIPS_GOT_LO16   23
#define R_MIPS_SUB   24
#define R_MIPS_INSERT_A   25
#define R_MIPS_INSERT_B   26
#define R_MIPS_DELETE   27
#define R_MIPS_HIGHER   28
#define R_MIPS_HIGHEST   29
#define R_MIPS_CALL_HI16   30
#define R_MIPS_CALL_LO16   31
#define R_MIPS_SCN_DISP   32
#define R_MIPS_REL16   33
#define R_MIPS_ADD_IMMEDIATE   34
#define R_MIPS_PJUMP   35
#define R_MIPS_RELGOT   36
#define R_MIPS_JALR   37
#define R_MIPS_TLS_DTPMOD32   38 /* Module number 32 bit */
#define R_MIPS_TLS_DTPREL32   39 /* Module-relative offset 32 bit */
#define R_MIPS_TLS_DTPMOD64   40 /* Module number 64 bit */
#define R_MIPS_TLS_DTPREL64   41 /* Module-relative offset 64 bit */
#define R_MIPS_TLS_GD   42 /* 16 bit GOT offset for GD */
#define R_MIPS_TLS_LDM   43 /* 16 bit GOT offset for LDM */
#define R_MIPS_TLS_DTPREL_HI16   44 /* Module-relative offset, high 16 bits */
#define R_MIPS_TLS_DTPREL_LO16   45 /* Module-relative offset, low 16 bits */
#define R_MIPS_TLS_GOTTPREL   46 /* 16 bit GOT offset for IE */
#define R_MIPS_TLS_TPREL32   47 /* TP-relative offset, 32 bit */
#define R_MIPS_TLS_TPREL64   48 /* TP-relative offset, 64 bit */
#define R_MIPS_TLS_TPREL_HI16   49 /* TP-relative offset, high 16 bits */
#define R_MIPS_TLS_TPREL_LO16   50 /* TP-relative offset, low 16 bits */
#define R_MIPS_max   51
#define R_TYPE(name)   __CONCAT(R_MIPS_,name)
#define R_MIPS16_min   100
#define R_MIPS16_26   100
#define R_MIPS16_GPREL   101
#define R_MIPS16_GOT16   102
#define R_MIPS16_CALL16   103
#define R_MIPS16_HI16   104
#define R_MIPS16_LO16   105
#define R_MIPS16_max   106
#define DT_MIPS_RLD_VERSION   0x70000001
#define DT_MIPS_TIME_STAMP   0x70000002
#define DT_MIPS_ICHECKSUM   0x70000003
#define DT_MIPS_IVERSION   0x70000004
#define DT_MIPS_FLAGS   0x70000005
#define DT_MIPS_BASE_ADDRESS   0x70000006
#define DT_MIPS_CONFLICT   0x70000008
#define DT_MIPS_LIBLIST   0x70000009
#define DT_MIPS_CONFLICTNO   0x7000000b
#define DT_MIPS_LOCAL_GOTNO   0x7000000a /* number of local got ents */
#define DT_MIPS_LIBLISTNO   0x70000010
#define DT_MIPS_SYMTABNO   0x70000011 /* number of .dynsym entries */
#define DT_MIPS_UNREFEXTNO   0x70000012
#define DT_MIPS_GOTSYM   0x70000013 /* first dynamic sym in got */
#define DT_MIPS_HIPAGENO   0x70000014
#define DT_MIPS_RLD_MAP   0x70000016 /* address of loader map */
#define EF_MIPS_PIC   0x00000002 /* Contains PIC code */
#define EF_MIPS_CPIC   0x00000004 /* STD PIC calling sequence */
#define EF_MIPS_ABI2   0x00000020 /* N32 */
#define EF_MIPS_ARCH_ASE   0x0f000000 /* Architectural extensions */
#define EF_MIPS_ARCH_MDMX   0x08000000 /* MDMX multimedia extension */
#define EF_MIPS_ARCH_M16   0x04000000 /* MIPS-16 ISA extensions */
#define EF_MIPS_ARCH   0xf0000000 /* Architecture field */
#define EF_MIPS_ARCH_1   0x00000000 /* -mips1 code */
#define EF_MIPS_ARCH_2   0x10000000 /* -mips2 code */
#define EF_MIPS_ARCH_3   0x20000000 /* -mips3 code */
#define EF_MIPS_ARCH_4   0x30000000 /* -mips4 code */
#define EF_MIPS_ARCH_5   0x40000000 /* -mips5 code */
#define EF_MIPS_ARCH_32   0x50000000 /* -mips32 code */
#define EF_MIPS_ARCH_64   0x60000000 /* -mips64 code */
#define EF_MIPS_ARCH_32R2   0x70000000 /* -mips32r2 code */
#define EF_MIPS_ARCH_64R2   0x80000000 /* -mips64r2 code */
#define EF_MIPS_ABI   0x0000f000
#define EF_MIPS_ABI_O32   0x00001000
#define EF_MIPS_ABI_O64   0x00002000
#define EF_MIPS_ABI_EABI32   0x00003000
#define EF_MIPS_ABI_EABI64   0x00004000
◆ ELF32_MACHDEP_ID_CASES
Value:
case EM_MIPS: \
break;
