| #define | ASM |
| #define | __USER_LABEL_PREFIX__ _ |
| Recent versions of GNU cpp define variables which indicate the need for underscores and percents. More... | |
| #define | __REGISTER_PREFIX__ |
| #define | SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x) |
| Use the right prefix for global labels. More... | |
| #define | REG(x) CONCAT1 (__REGISTER_PREFIX__, x) |
| Use the right prefix for registers. More... | |
| #define | BEGIN_CODE_DCL .text |
| This macro is used to denote the beginning of a code declaration. More... | |
| #define | END_CODE_DCL |
| This macro is used to denote the end of a code declaration. More... | |
| #define | BEGIN_DATA_DCL .data |
| This macro is used to denote the beginning of a data declaration section. | |
| #define | END_DATA_DCL |
| This macro is used to denote the end of a data declaration section. More... | |
| #define | BEGIN_CODE .text |
| This macro is used to denote the beginning of a code section. More... | |
| #define | END_CODE |
| This macro is used to denote the end of a code section. More... | |
| #define | BEGIN_DATA |
| This macro is used to denote the beginning of a data section. More... | |
| #define | END_DATA |
| This macro is used to denote the end of a data section. More... | |
| #define | BEGIN_BSS |
| This macro is used to denote the beginning of the unitialized data section. | |
| #define | END_BSS |
| This macro is used to denote the end of the unitialized data section. More... | |
| #define | END |
| This macro is used to denote the end of the assembly file. More... | |
| #define | PUBLIC(sym) .globl SYM (sym) |
| This macro is used to declare a public global symbol. More... | |
| #define | EXTERN(sym) .globl SYM (sym) |
| This macro is used to prototype a public global symbol. More... | |
| #define __REGISTER_PREFIX__ |
| #define __USER_LABEL_PREFIX__ _ |
| #define BEGIN_CODE .text |
| #define BEGIN_CODE_DCL .text |
| #define BEGIN_DATA |
| #define END |
| #define END_BSS |
| #define END_CODE |
| #define END_CODE_DCL |
| #define END_DATA |
| #define END_DATA_DCL |
| #define EXTERN | ( | sym | ) | .globl SYM (sym) |
| #define PUBLIC | ( | sym | ) | .globl SYM (sym) |
NOTE: This must be tailored for a particular flavor of the C compiler. They may need to put underscores in front of the symbols.
| #define REG | ( | x | ) | CONCAT1 (__REGISTER_PREFIX__, x) |
| #define SYM | ( | x | ) | CONCAT1 (__USER_LABEL_PREFIX__, x) |
