iotn26.h File Reference
Definitions for ATtiny26. More...
#define _AVR_IOXXX_H_   "iotn26.h"
#define _AVR_IOTN26_H_   1
#define ADCW   _SFR_IO16(0x04)
#define ADC   _SFR_IO16(0x04)
#define ADCL   _SFR_IO8(0x04)
#define ADCH   _SFR_IO8(0x05)
#define ADCSR   _SFR_IO8(0x06)
#define ADPS0   0
#define ADPS1   1
#define ADPS2   2
#define ADIE   3
#define ADIF   4
#define ADFR   5
#define ADSC   6
#define ADEN   7
#define ADMUX   _SFR_IO8(0x07)
#define MUX0   0
#define MUX1   1
#define MUX2   2
#define MUX3   3
#define MUX4   4
#define ADLAR   5
#define REFS0   6
#define REFS1   7
#define ACSR   _SFR_IO8(0x08)
#define ACIS0   0
#define ACIS1   1
#define ACME   2
#define ACIE   3
#define ACI   4
#define ACO   5
#define ACBG   6
#define ACD   7
#define USICR   _SFR_IO8(0x0D)
#define USITC   0
#define USICLK   1
#define USICS0   2
#define USICS1   3
#define USIWM0   4
#define USIWM1   5
#define USIOIE   6
#define USISIE   7
#define USISR   _SFR_IO8(0x0E)
#define USICNT0   0
#define USICNT1   1
#define USICNT2   2
#define USICNT3   3
#define USIDC   4
#define USIPF   5
#define USIOIF   6
#define USISIF   7
#define USIDR   _SFR_IO8(0x0F)
#define PINB   _SFR_IO8(0x16)
#define PINB0   0
#define PINB1   1
#define PINB2   2
#define PINB3   3
#define PINB4   4
#define PINB5   5
#define PINB6   6
#define PINB7   7
#define DDRB   _SFR_IO8(0x17)
#define DDB0   0
#define DDB1   1
#define DDB2   2
#define DDB3   3
#define DDB4   4
#define DDB5   5
#define DDB6   6
#define DDB7   7
#define PORTB   _SFR_IO8(0x18)
#define PB0   0
#define PB1   1
#define PB2   2
#define PB3   3
#define PB4   4
#define PB5   5
#define PB6   6
#define PB7   7
#define PINA   _SFR_IO8(0x19)
#define PINA0   0
#define PINA1   1
#define PINA2   2
#define PINA3   3
#define PINA4   4
#define PINA5   5
#define PINA6   6
#define PINA7   7
#define DDRA   _SFR_IO8(0x1A)
#define DDA0   0
#define DDA1   1
#define DDA2   2
#define DDA3   3
#define DDA4   4
#define DDA5   5
#define DDA6   6
#define DDA7   7
#define PORTA   _SFR_IO8(0x1B)
#define PA0   0
#define PA1   1
#define PA2   2
#define PA3   3
#define PA4   4
#define PA5   5
#define PA6   6
#define PA7   7
#define EECR   _SFR_IO8(0x1C)
#define EERE   0
#define EEWE   1
#define EEMWE   2
#define EERIE   3
#define EEDR   _SFR_IO8(0x1D)
#define EEAR   _SFR_IO8(0x1E)
#define EEARL   _SFR_IO8(0x1E)
#define WDTCR   _SFR_IO8(0x21)
#define WDP0   0
#define WDP1   1
#define WDP2   2
#define WDE   3
#define WDCE   4
#define PLLCSR   _SFR_IO8(0x29)
#define PLOCK   0
#define PLLE   1
#define PCKE   2
#define OCR1C   _SFR_IO8(0x2B)
#define OCR1B   _SFR_IO8(0x2C)
#define OCR1A   _SFR_IO8(0x2D)
#define TCNT1   _SFR_IO8(0x2E)
#define TCCR1B   _SFR_IO8(0x2F)
#define CS10   0
#define CS11   1
#define CS12   2
#define CS13   3
#define PSR1   6
#define CTC1   7
#define TCCR1A   _SFR_IO8(0x30)
#define PWM1B   0
#define PWM1A   1
#define FOC1B   2
#define FOC1A   3
#define COM1B0   4
#define COM1B1   5
#define COM1A0   6
#define COM1A1   7
#define OSCCAL   _SFR_IO8(0x31)
#define TCNT0   _SFR_IO8(0x32)
#define TCCR0   _SFR_IO8(0x33)
#define CS00   0
#define CS01   1
#define CS02   2
#define PSR0   3
#define MCUSR   _SFR_IO8(0x34)
#define PORF   0
#define EXTRF   1
#define BORF   2
#define WDRF   3
#define MCUCR   _SFR_IO8(0x35)
#define ISC00   0
#define ISC01   1
#define SM0   3
#define SM1   4
#define SE   5
#define PUD   6
#define TIFR   _SFR_IO8(0x38)
#define TOV0   1
#define TOV1   2
#define OCF1B   5
#define OCF1A   6
#define TIMSK   _SFR_IO8(0x39)
#define TOIE0   1
#define TOIE1   2
#define OCIE1B   5
#define OCIE1A   6
#define GIFR   _SFR_IO8(0x3A)
#define PCIF   5
#define INTF0   6
#define GIMSK   _SFR_IO8(0x3B)
#define PCIE0   4
#define PCIE1   5
#define INT0   6
#define INT0_vect   _VECTOR(1)
#define SIG_INTERRUPT0   _VECTOR(1)
#define IO_PINS_vect   _VECTOR(2)
#define SIG_PIN_CHANGE   _VECTOR(2)
#define TIMER1_CMPA_vect   _VECTOR(3)
#define SIG_OUTPUT_COMPARE1A   _VECTOR(3)
#define TIMER1_CMPB_vect   _VECTOR(4)
#define SIG_OUTPUT_COMPARE1B   _VECTOR(4)
#define TIMER1_OVF1_vect   _VECTOR(5)
#define SIG_OVERFLOW1   _VECTOR(5)
#define TIMER0_OVF0_vect   _VECTOR(6)
#define SIG_OVERFLOW0   _VECTOR(6)
#define USI_STRT_vect   _VECTOR(7)
#define SIG_USI_START   _VECTOR(7)
#define USI_OVF_vect   _VECTOR(8)
#define SIG_USI_OVERFLOW   _VECTOR(8)
#define EE_RDY_vect   _VECTOR(9)
#define SIG_EEPROM_READY   _VECTOR(9)
#define ANA_COMP_vect   _VECTOR(10)
#define SIG_ANA_COMP   _VECTOR(10)
#define SIG_COMPARATOR   _VECTOR(10)
#define ADC_vect   _VECTOR(11)
#define SIG_ADC   _VECTOR(11)
#define _VECTORS_SIZE   24
#define RAMEND   0xDF
#define XRAMEND   RAMEND
#define E2END   0x7F
#define E2PAGESIZE   4
#define FLASHEND   0x07FF
#define FUSE_MEMORY_SIZE   2
#define FUSE_CKSEL0   (unsigned char)~_BV(0)
#define FUSE_CKSEL1   (unsigned char)~_BV(1)
#define FUSE_CKSEL2   (unsigned char)~_BV(2)
#define FUSE_CKSEL3   (unsigned char)~_BV(3)
#define FUSE_SUT0   (unsigned char)~_BV(4)
#define FUSE_SUT1   (unsigned char)~_BV(5)
#define FUSE_CKOPT   (unsigned char)~_BV(6)
#define FUSE_PLLCK   (unsigned char)~_BV(7)
#define LFUSE_DEFAULT   (FUSE_CKSEL1 & FUSE_CKSEL2 & FUSE_CKSEL3 & FUSE_SUT0)
#define FUSE_BODEN   (unsigned char)~_BV(0)
#define FUSE_BODLEVEL   (unsigned char)~_BV(1)
#define FUSE_EESAVE   (unsigned char)~_BV(2)
#define FUSE_SPIEN   (unsigned char)~_BV(3)
#define FUSE_RSTDISBL   (unsigned char)~_BV(4)
#define HFUSE_DEFAULT   (FUSE_SPIEN)
#define __LOCK_BITS_EXIST
#define SIGNATURE_0   0x1E
#define SIGNATURE_1   0x91
#define SIGNATURE_2   0x09
This file should only be included from <avr/io.h>, never directly.
