elf_machdep.h
1 /* $NetBSD: elf_machdep.h,v 1.10 2009/05/30 05:56:52 skrll Exp $ */
2
3 #define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
4 #define ELF32_MACHDEP_ID_CASES \
5  case EM_386: \
6  case EM_486: \
7  break;
8
9 #define ELF64_MACHDEP_ENDIANNESS XXX /* break compilation */
10 #define ELF64_MACHDEP_ID_CASES \
11  /* no 64-bit ELF machine types supported */
12
13 #define ELF32_MACHDEP_ID EM_386
14
15 #define ARCH_ELFSIZE 32 /* MD native binary size */
16
17 /* i386 relocations */
18 #define R_386_NONE 0
19 #define R_386_32 1
20 #define R_386_PC32 2
21 #define R_386_GOT32 3
22 #define R_386_PLT32 4
23 #define R_386_COPY 5
24 #define R_386_GLOB_DAT 6
25 #define R_386_JMP_SLOT 7
26 #define R_386_RELATIVE 8
27 #define R_386_GOTOFF 9
28 #define R_386_GOTPC 10
29
30 /* TLS relocations */
31 #define R_386_TLS_TPOFF 14
32 #define R_386_TLS_IE 15
33 #define R_386_TLS_GOTIE 16
34 #define R_386_TLS_LE 17
35 #define R_386_TLS_GD 18
36 #define R_386_TLS_LDM 19
37
38 /* The following relocations are GNU extensions. */
39 #define R_386_16 20
40 #define R_386_PC16 21
41 #define R_386_8 22
42 #define R_386_PC8 23
43
44 /* More TLS relocations */
45 #define R_386_TLS_GD_32 24
46 #define R_386_TLS_GD_PUSH 25
47 #define R_386_TLS_GD_CALL 26
48 #define R_386_TLS_GD_POP 27
49 #define R_386_TLS_LDM_32 28
50 #define R_386_TLS_LDM_PUSH 29
51 #define R_386_TLS_LDM_CALL 30
52 #define R_386_TLS_LDM_POP 31
53 #define R_386_TLS_LDO_32 32
54 #define R_386_TLS_IE_32 33
55 #define R_386_TLS_LE_32 34
56 #define R_386_TLS_DTPMOD32 35
57 #define R_386_TLS_DTPOFF32 36
58 #define R_386_TLS_TPOFF32 37
59 #define R_386_TLS_GOTDESC 39
60 #define R_386_TLS_DESC_CALL 40
61 #define R_386_TLS_DESC 41
62
63 #define R_TYPE(name) __CONCAT(R_386_,name)
