#define | ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB |
| #define | ELF32_MACHDEP_ID_CASES |
#define | ELF64_MACHDEP_ENDIANNESS XXX /* break compilation */ |
#define | ELF64_MACHDEP_ID_CASES /* no 64-bit ELF machine types supported */ |
#define | ELF32_MACHDEP_ID EM_386 |
#define | ARCH_ELFSIZE 32 /* MD native binary size */ |
#define | R_386_NONE 0 |
#define | R_386_32 1 |
#define | R_386_PC32 2 |
#define | R_386_GOT32 3 |
#define | R_386_PLT32 4 |
#define | R_386_COPY 5 |
#define | R_386_GLOB_DAT 6 |
#define | R_386_JMP_SLOT 7 |
#define | R_386_RELATIVE 8 |
#define | R_386_GOTOFF 9 |
#define | R_386_GOTPC 10 |
#define | R_386_TLS_TPOFF 14 |
#define | R_386_TLS_IE 15 |
#define | R_386_TLS_GOTIE 16 |
#define | R_386_TLS_LE 17 |
#define | R_386_TLS_GD 18 |
#define | R_386_TLS_LDM 19 |
#define | R_386_16 20 |
#define | R_386_PC16 21 |
#define | R_386_8 22 |
#define | R_386_PC8 23 |
#define | R_386_TLS_GD_32 24 |
#define | R_386_TLS_GD_PUSH 25 |
#define | R_386_TLS_GD_CALL 26 |
#define | R_386_TLS_GD_POP 27 |
#define | R_386_TLS_LDM_32 28 |
#define | R_386_TLS_LDM_PUSH 29 |
#define | R_386_TLS_LDM_CALL 30 |
#define | R_386_TLS_LDM_POP 31 |
#define | R_386_TLS_LDO_32 32 |
#define | R_386_TLS_IE_32 33 |
#define | R_386_TLS_LE_32 34 |
#define | R_386_TLS_DTPMOD32 35 |
#define | R_386_TLS_DTPOFF32 36 |
#define | R_386_TLS_TPOFF32 37 |
#define | R_386_TLS_GOTDESC 39 |
#define | R_386_TLS_DESC_CALL 40 |
#define | R_386_TLS_DESC 41 |
#define | R_TYPE(name) __CONCAT(R_386_,name) |
◆ ELF32_MACHDEP_ID_CASES
| #define ELF32_MACHDEP_ID_CASES |
Value:case EM_386: \
case EM_486: \
break;
