Print Macros | |
| #define | RTEMS_DEBUG_PRINT(fmt, ...) |
| General purpose debug print macro. | |
| #define | RTEMS_DEBUG_OK(msg) RTEMS_DEBUG_PRINT( "Ok: %s\n", msg) |
| Macro to print debug messages for successful operations. | |
| #define | RTEMS_SYSLOG_PRINT(fmt, ...) printf( fmt, ##__VA_ARGS__) |
| General purpose system log print macro. | |
| #define | RTEMS_SYSLOG(fmt, ...) RTEMS_SYSLOG_PRINT( "%s: " fmt, __func__, ##__VA_ARGS__) |
| General purpose system log macro. | |
| #define | RTEMS_SYSLOG_WARNING(fmt, ...) RTEMS_SYSLOG( "Warning: " fmt, ##__VA_ARGS__) |
| General purpose system log macro for warnings. | |
| #define | RTEMS_SYSLOG_WARNING_SC(sc, msg) |
| Macro to generate a system log warning message if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_SYSLOG_ERROR(fmt, ...) RTEMS_SYSLOG( "Error: " fmt, ##__VA_ARGS__) |
| General purpose system log macro for errors. | |
| #define | RTEMS_SYSLOG_ERROR_WITH_SC(sc, msg) RTEMS_SYSLOG_ERROR( "SC = %i: %s\n", (int) sc, msg); |
| Macro for system log error messages with status code. | |
| #define | RTEMS_SYSLOG_ERROR_WITH_RV(rv, msg) RTEMS_SYSLOG_ERROR( "RV = %i: %s\n", (int) rv, msg); |
| Macro for system log error messages with return value. | |
| #define | RTEMS_SYSLOG_ERROR_SC(sc, msg) |
| Macro to generate a system log error message if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_SYSLOG_ERROR_RV(rv, msg) |
| Macro to generate a system log error message if the return value rv is less than zero. More... | |
Check Macros | |
| #define | RTEMS_CHECK_SC(sc, msg) |
| Prints message msg and returns with status code sc if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_CHECK_SC_RV(sc, msg) |
| Prints message msg and returns with a return value of negative sc if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_CHECK_SC_VOID(sc, msg) |
| Prints message msg and returns if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_CHECK_SC_TASK(sc, msg) |
| Prints message msg and delete the current task if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_CHECK_RV(rv, msg) |
| Prints message msg and returns with a return value rv if the return value rv is less than zero. More... | |
| #define | RTEMS_CHECK_RV_SC(rv, msg) |
| Prints message msg and returns with status code RTEMS_IO_ERROR if the return value rv is less than zero. More... | |
| #define | RTEMS_CHECK_RV_VOID(rv, msg) |
| Prints message msg and returns if the return value rv is less than zero. More... | |
| #define | RTEMS_CHECK_RV_TASK(rv, msg) |
| Prints message msg and delete the current task if the return value rv is less than zero. More... | |
Cleanup Macros | |
| #define | RTEMS_CLEANUP_SC(sc, label, msg) |
| Prints message msg and jumps to label if the status code sc is not equal to RTEMS_SUCCESSFUL. More... | |
| #define | RTEMS_CLEANUP_SC_RV(sc, rv, label, msg) |
| #define | RTEMS_CLEANUP_RV(rv, label, msg) |
| Prints message msg and jumps to label if the return value rv is less than zero. More... | |
| #define | RTEMS_CLEANUP_RV_SC(rv, sc, label, msg) |
| #define | RTEMS_DO_CLEANUP(label, msg) |
| Prints message msg and jumps to label. More... | |
| #define | RTEMS_DO_CLEANUP_SC(val, sc, label, msg) |
| Prints message msg, sets the status code variable sc to val and jumps to label. More... | |
| #define | RTEMS_DO_CLEANUP_RV(val, rv, label, msg) |
| Prints message msg, sets the return value variable rv to val and jumps to label. More... | |
| #define RTEMS_CHECK_RV | ( | rv, | |
| msg | |||
| #define RTEMS_CHECK_RV_SC | ( | rv, | |
| msg | |||
| #define RTEMS_CHECK_RV_TASK | ( | rv, | |
| msg | |||
| #define RTEMS_CHECK_RV_VOID | ( | rv, | |
| msg | |||
| #define RTEMS_CHECK_SC | ( | sc, | |
| msg | |||
| #define RTEMS_CHECK_SC_RV | ( | sc, | |
| msg | |||
| #define RTEMS_CHECK_SC_TASK | ( | sc, | |
| msg | |||
| #define RTEMS_CHECK_SC_VOID | ( | sc, | |
| msg | |||
| #define RTEMS_CLEANUP_RV | ( | rv, | |
| label, | |||
| msg | |||
| #define RTEMS_CLEANUP_RV_SC | ( | rv, | |
| sc, | |||
| label, | |||
| msg | |||
The status code variable sc will be set to RTEMS_IO_ERROR in this case.
| #define RTEMS_CLEANUP_SC | ( | sc, | |
| label, | |||
| msg | |||
| #define RTEMS_CLEANUP_SC_RV | ( | sc, | |
| rv, | |||
| label, | |||
| msg | |||
The return value variable rv will be set to a negative sc in this case.
| #define RTEMS_DO_CLEANUP | ( | label, | |
| msg | |||
| #define RTEMS_DO_CLEANUP_RV | ( | val, | |
| rv, | |||
| label, | |||
| msg | |||
| #define RTEMS_DO_CLEANUP_SC | ( | val, | |
| sc, | |||
| label, | |||
| msg | |||
| #define RTEMS_SYSLOG_ERROR_RV | ( | rv, | |
| msg | |||
| #define RTEMS_SYSLOG_ERROR_SC | ( | sc, | |
| msg | |||
| #define RTEMS_SYSLOG_WARNING_SC | ( | sc, | |
| msg | |||
