| #define | SERIAL_MOUSE_DEVICE_PS2 "/dev/psaux" |
| Standard device file path for a PS2 mouse device. | |
| #define | SERIAL_MOUSE_DRIVER_TABLE_ENTRY |
| This macro defines the serial mouse device driver entry points. More... | |
| rtems_device_driver | serial_mouse_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| The initialization of the serial mouse driver. More... | |
| rtems_device_driver | serial_mouse_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Open device driver entry point for the serial mouse driver. More... | |
| rtems_device_driver | serial_mouse_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Close device driver entry point for the serial mouse driver. More... | |
| rtems_device_driver | serial_mouse_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Read device driver entry point for the serial mouse driver. More... | |
| rtems_device_driver | serial_mouse_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| Write device driver entry point for the serial mouse driver. More... | |
| rtems_device_driver | serial_mouse_control (rtems_device_major_number major, rtems_device_minor_number minor, void *arg) |
| IO Control device driver entry point for the serial mouse driver. More... | |
| bool | bsp_get_serial_mouse_device (const char **name, const char **type) |
| Obtain serial mouse configuration information. More... | |
| #define SERIAL_MOUSE_DRIVER_TABLE_ENTRY |
| bool bsp_get_serial_mouse_device | ( | const char ** | name, |
| const char ** | type | ||
This method is implemented by the BSP or application and tells the driver what device to open() and what type of mouse is connected.
| [in] | name | will point to a string with the device name of the serial port with the mouse connected. |
| [in] | type | will point to a string with the type of mouse connected. |
| This | method returns true on success and false on error. |
| rtems_device_driver serial_mouse_close | ( | rtems_device_major_number | major, |
| rtems_device_minor_number | minor, | ||
| void * | arg | ||
This method implements the Close device driver entry point for the serial mouse driver.
| [in] | major | is the mouse device major number |
| [in] | minor | is the mouse device minor number |
| [in] | arg | points to device driver arguments |
| rtems_device_driver serial_mouse_control | ( | rtems_device_major_number | major, |
| void * | arg | ||
| rtems_device_driver serial_mouse_initialize | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method initializes the serial mouse driver.
| rtems_device_driver serial_mouse_open | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method implements the Open device driver entry point for the serial mouse driver.
| rtems_device_driver serial_mouse_read | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method implements the Read device driver entry point for the serial mouse driver.
| rtems_device_driver serial_mouse_write | ( | rtems_device_major_number | major, |
| void * | arg | ||
This method implements the Write device driver entry point for the serial mouse driver.
