This handler encapsulates functionality which abstracts thread context management in a portable manner. More...
Files | |
| file | context_init.c |
| Initialize Context Area. | |
| #define | CONTEXT_FP_SIZE CPU_CONTEXT_FP_SIZE |
| Size of floating point context area. More... | |
| #define | _Context_Initialize(_the_context, _stack, _size, _isr, _entry, _is_fp, _tls_area) |
| Initialize context area. More... | |
| #define | _Context_Initialization_at_thread_begin() |
| This macro is invoked from _Thread_Handler to do whatever CPU specific magic is required that must be done in the context of the thread when it starts. More... | |
| #define | _Context_Switch(_executing, _heir) _CPU_Context_switch( _executing, _heir ) |
| Perform context switch. More... | |
| #define | _Context_Restart_self(_the_context) _CPU_Context_Restart_self( _the_context ) |
| Restart currently executing thread. More... | |
| #define | _Context_Fp_start(_base, _offset) _CPU_Context_Fp_start( (_base), (_offset) ) |
| Return starting address of floating point context. More... | |
| #define | _Context_Initialize_fp(_fp_area) _CPU_Context_Initialize_fp( _fp_area ) |
| Initialize floating point context area. More... | |
| #define | _Context_Restore_fp(_fp) _CPU_Context_restore_fp( _fp ) |
| Restore floating point context area. More... | |
| #define | _Context_Save_fp(_fp) _CPU_Context_save_fp( _fp ) |
| Save floating point context area. More... | |
The context switch needed variable is contained in the per cpu data structure.
| #define _Context_Fp_start | ( | _base, | |
| _offset | |||
| ) | _CPU_Context_Fp_start( (_base), (_offset) ) |
This function returns the starting address of the floating point context save area. It is assumed that the are reserved for the floating point save area is large enough.
| [in] | _base | is lowest physical address of the floating point context save area. |
| [in] | _offset | is the offset into the floating point area |
| the | initial FP context pointer |
| #define _Context_Initialization_at_thread_begin | ( | ) |
If the CPU architecture does not require any magic, then this macro is empty.
| #define _Context_Initialize | ( | _the_context, | |
| _stack, | |||
| _size, | |||
| _isr, | |||
| _entry, | |||
| _is_fp, | |||
| _tls_area | |||
This routine initializes _the_context such that the stack pointer, interrupt level, and entry point are correct for the thread's initial state.
| [in] | _the_context | will be initialized |
| [in] | _stack | is the lowest physical address of the thread's context |
| [in] | _size | is the size in octets of the thread's context |
| [in] | _isr | is the ISR enable level for this thread |
| [in] | _entry | is this thread's entry point |
| [in] | _is_fp | is set to true if this thread has floating point enabled |
| [in] | _tls_area | The thread-local storage (TLS) area begin. |
| #define _Context_Initialize_fp | ( | _fp_area | ) | _CPU_Context_Initialize_fp( _fp_area ) |
This routine initializes the floating point context save area to contain an initial known state.
| [in] | _fp_area | is the base address of the floating point context save area to initialize. |
Referenced by _Thread_Load_environment().
| #define _Context_Restart_self | ( | _the_context | ) | _CPU_Context_Restart_self( _the_context ) |
This routine restarts the calling thread by restoring its initial stack pointer and returning to the thread's entry point.
| [in] | _the_context | is the context of the thread to restart |
| #define _Context_Restore_fp | ( | _fp | ) | _CPU_Context_restore_fp( _fp ) |
This routine restores the floating point context contained in the _fp area. It is assumed that the current floating point context has been saved by a previous invocation of _Context_Save_fp.
| [in] | _fp | points to the floating point context area to restore. |
| #define _Context_Save_fp | ( | _fp | ) | _CPU_Context_save_fp( _fp ) |
This routine saves the current floating point context in the _fp area.
| #define _Context_Switch | ( | _executing, | |
| _heir | |||
| ) | _CPU_Context_switch( _executing, _heir ) |
This routine saves the current context into the _executing context record and restores the context specified by _heir.
| [in] | _executing | is the currently executing thread's context |
| [in] | _heir | is the context of the thread to be switched to |
| #define CONTEXT_FP_SIZE CPU_CONTEXT_FP_SIZE |
This constant defines the number of bytes required to store a full floating point context.
