Red-Black Tree Heap API. More...
Files | |
| file | rbheap.c |
| Red-Black Tree Heap implementation. | |
| struct | rtems_rbheap_chunk |
| Red-black heap chunk descriptor. More... | |
| struct | rtems_rbheap_control |
| Red-black heap control. More... | |
Typedefs | |
| typedef struct rtems_rbheap_control | rtems_rbheap_control |
| typedef void(* | rtems_rbheap_extend_descriptors) (rtems_rbheap_control *control) |
| Handler to extend the available chunk descriptors. More... | |
| rtems_status_code | rtems_rbheap_initialize (rtems_rbheap_control *control, void *area_begin, uintptr_t area_size, uintptr_t alignment, rtems_rbheap_extend_descriptors extend_descriptors, void *handler_arg) |
| Initializes the red-black tree heap control. More... | |
| void * | rtems_rbheap_allocate (rtems_rbheap_control *control, size_t size) |
| Allocates a chunk of memory of at least size bytes from the red-black tree heap control. More... | |
| rtems_status_code | rtems_rbheap_free (rtems_rbheap_control *control, void *ptr) |
| Frees a chunk of memory ptr allocated from the red-black tree heap control. More... | |
| void | rtems_rbheap_extend_descriptors_never (rtems_rbheap_control *control) |
| Chunk descriptor extend handler that does nothing. | |
| void | rtems_rbheap_extend_descriptors_with_malloc (rtems_rbheap_control *control) |
| Chunk descriptor extend handler that uses malloc(). | |
The red-black tree heap provides a memory allocator suitable to implement the malloc() and free() interface. It uses a first-fit allocation strategy. In the red-black tree heap the administration data structures are not contained in the managed memory area. Thus writing beyond the boundaries of a chunk does not damage the data to maintain the heap. This can be used for example in a task stack allocator which protects the task stacks from access by other tasks. The allocated and free memory parts of the managed area are called chunks. Each chunk needs a descriptor which is stored outside of the managed area.
| typedef void(* rtems_rbheap_extend_descriptors) (rtems_rbheap_control *control) |
This handler is called when no more chunk descriptors are available. An example implementation is this:
| void* rtems_rbheap_allocate | ( | rtems_rbheap_control * | control, |
| size_t | size | ||
The chunk begin is aligned by the value specified in rtems_rbheap_initialize().
| [in,out] | control | The red-black tree heap. |
| [in] | size | The requested chunk size in bytes. |
| NULL | Not enough free space in the heap. |
| otherwise | Pointer to allocated chunk of memory. |
References rtems_rbheap_control::alignment, rtems_rbheap_control::chunk_tree, and rtems_rbheap_control::free_chunk_chain.
| rtems_status_code rtems_rbheap_free | ( | rtems_rbheap_control * | control, |
| void * | ptr | ||
| [in] | ptr | The pointer to the chunk of memory. |
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_INVALID_ID | The chunk of memory is not a valid chunk in the red-black tree heap. |
| RTEMS_INCORRECT_STATE | The chunk of memory is not in the right state. |
References RTEMS_SUCCESSFUL.
| rtems_status_code rtems_rbheap_initialize | ( | rtems_rbheap_control * | control, |
| void * | area_begin, | ||
| uintptr_t | area_size, | ||
| uintptr_t | alignment, | ||
| rtems_rbheap_extend_descriptors | extend_descriptors, | ||
| void * | handler_arg | ||
| [in] | area_begin | The managed memory area begin. |
| [in] | area_size | The managed memory area size. |
| [in] | alignment | The minimum chunk alignment. |
| [in] | extend_descriptors | The handler to extend the available chunk descriptors. |
| [in] | handler_arg | The handler argument. |
| RTEMS_INVALID_ADDRESS | The memory area is invalid. |
| RTEMS_NO_MEMORY | Not enough chunk descriptors. |
