Files | |
| file | modesimpl.h |
| Classic Modes Implementation. | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Mask_changed (Modes_Control mode_set, Modes_Control masks) |
| Checks if any of the mode flags in mask are set in mode_set. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_asr_disabled (Modes_Control mode_set) |
| Checks if mode_set says that Asynchronous Signal Processing is disabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_preempt (Modes_Control mode_set) |
| Checks if mode_set indicates that preemption is enabled. More... | |
| RTEMS_INLINE_ROUTINE bool | _Modes_Is_timeslice (Modes_Control mode_set) |
| Checks if mode_set indicates that timeslicing is enabled. More... | |
| RTEMS_INLINE_ROUTINE ISR_Level | _Modes_Get_interrupt_level (Modes_Control mode_set) |
| Gets the interrupt level portion of the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Set_interrupt_level (Modes_Control mode_set) |
| Sets the current interrupt level to that specified in the mode_set. More... | |
| RTEMS_INLINE_ROUTINE void | _Modes_Change (Modes_Control old_mode_set, Modes_Control new_mode_set, Modes_Control mask, Modes_Control *out_mode_set, Modes_Control *changed) |
| Changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. More... | |
| RTEMS_INLINE_ROUTINE void _Modes_Change | ( | Modes_Control | old_mode_set, |
| Modes_Control | new_mode_set, | ||
| Modes_Control | mask, | ||
| Modes_Control * | out_mode_set, | ||
| Modes_Control * | changed | ||
This routine changes the modes in old_mode_set indicated by mask to the requested values in new_mode_set. The resulting mode set is returned in out_mode_set and the modes that changed is returned in changed.
| RTEMS_INLINE_ROUTINE ISR_Level _Modes_Get_interrupt_level | ( | Modes_Control | mode_set | ) |
This function returns the interrupt level portion of the mode_set.
References RTEMS_INTERRUPT_MASK.
Referenced by _Modes_Set_interrupt_level().
| RTEMS_INLINE_ROUTINE bool _Modes_Is_asr_disabled | ( | Modes_Control | mode_set | ) |
This function returns TRUE if mode_set indicates that Asynchronous Signal Processing is disabled, and FALSE otherwise.
References RTEMS_ASR_MASK, and RTEMS_NO_ASR.
| RTEMS_INLINE_ROUTINE bool _Modes_Is_preempt | ( | Modes_Control | mode_set | ) |
This function returns TRUE if mode_set indicates that preemption is enabled, and FALSE otherwise.
References RTEMS_PREEMPT, and RTEMS_PREEMPT_MASK.
| RTEMS_INLINE_ROUTINE bool _Modes_Is_timeslice | ( | Modes_Control | mode_set | ) |
This function returns TRUE if mode_set indicates that timeslicing is enabled, and FALSE otherwise.
References RTEMS_TIMESLICE, and RTEMS_TIMESLICE_MASK.
| RTEMS_INLINE_ROUTINE bool _Modes_Mask_changed | ( | Modes_Control | mode_set, |
| Modes_Control | masks | ||
This function returns TRUE if any of the mode flags in mask are set in mode_set, and FALSE otherwise.
| RTEMS_INLINE_ROUTINE void _Modes_Set_interrupt_level | ( | Modes_Control | mode_set | ) |
This routine sets the current interrupt level to that specified in the mode_set.
References _ISR_Set_level, and _Modes_Get_interrupt_level().
