This encapsulates functionality related to the transparent multiprocessing support within the Classic API Barrier Manager. More...
| struct | Barrier_MP_Packet |
| The following data structure defines the packet used to perform remote barrier operations. More... | |
Enumerations | |
| enum | Barrier_MP_Remote_operations { BARRIER_MP_ANNOUNCE_CREATE = 0, BARRIER_MP_ANNOUNCE_DELETE = 1, BARRIER_MP_EXTRACT_PROXY = 2, BARRIER_MP_WAIT_REQUEST = 3, BARRIER_MP_WAIT_RESPONSE = 4, BARRIER_MP_RELEASE_REQUEST = 5, BARRIER_MP_RELEASE_RESPONSE = 6 } |
| The following enumerated type defines the list of remote barrier operations. | |
| void | _Barrier_MP_Send_process_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, rtems_name name, Objects_Id proxy_id) |
| _Barrier_MP_Send_process_packet More... | |
| rtems_status_code | _Barrier_MP_Send_request_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, rtems_interval timeout) |
| _Barrier_MP_Send_request_packet More... | |
| void | _Barrier_MP_Send_response_packet (Barrier_MP_Remote_operations operation, Objects_Id barrier_id, Thread_Control *the_thread) |
| _Barrier_MP_Send_response_packet More... | |
| void | _Barrier_MP_Process_packet (rtems_packet_prefix *the_packet_prefix) |
| _Barrier_MP_Process_packet More... | |
| void | _Barrier_MP_Send_object_was_deleted (Thread_Control *the_proxy) |
| _Barrier_MP_Send_object_was_deleted More... | |
| void | _Barrier_MP_Send_extract_proxy (void *argument) |
| _Barrier_MP_Send_extract_proxy More... | |
| Barrier_MP_Packet * | _Barrier_MP_Get_packet (void) |
| _Barrier_MP_Get_packet More... | |
| Barrier_MP_Packet* _Barrier_MP_Get_packet | ( | void | ) |
This function is used to obtain a barrier mp packet.
| void _Barrier_MP_Process_packet | ( | rtems_packet_prefix * | the_packet_prefix | ) |
This routine performs the actions specific to this package for the request from another node.
| void _Barrier_MP_Send_extract_proxy | ( | void * | argument | ) |
This routine is invoked when a task is deleted and it has a proxy which must be removed from a thread queue and the remote node must be informed of this.
| void _Barrier_MP_Send_object_was_deleted | ( | Thread_Control * | the_proxy | ) |
This routine is invoked indirectly by the thread queue when a proxy has been removed from the thread queue and the remote node must be informed of this.
| void _Barrier_MP_Send_process_packet | ( | Barrier_MP_Remote_operations | operation, |
| Objects_Id | barrier_id, | ||
| rtems_name | name, | ||
| Objects_Id | proxy_id | ||
This routine performs a remote procedure call so that a process operation can be performed on another node.
| rtems_status_code _Barrier_MP_Send_request_packet | ( | Barrier_MP_Remote_operations | operation, |
| rtems_interval | timeout | ||
This routine performs a remote procedure call so that a directive operation can be initiated on another node.
| void _Barrier_MP_Send_response_packet | ( | Barrier_MP_Remote_operations | operation, |
| Thread_Control * | the_thread | ||
This routine performs a remote procedure call so that a directive can be performed on another node.
